Re: Fan winds up max speed for a second on startup
2017/10/09 15:41:37
Yeah, the problem is the winding up isn't even showing up on the HW monitor or on the regular fan meter at all. I can't replicate it on demand but listening to it when I set it to 100%, I'd say the winding up is a bit higher pitch than 100%. One more thing I'll try is disconnecting my rear case fan to make sure it's not that, but I doubt that's where the sound is coming from. And I know it's not from my cooler, because I know how those sound and their speed isn't changing either. I'd hate to have to install a custom bios although I'm sure it's not too bad. I can try reinstalling precision or my nvidia drivers though. It seems to only do it when precision is set to fan curve mode and using their aggressive preset, and it always happens after precision has loaded. I'll try taking it off startup and see what happens
