Helpful ReplyEVGA 2080 XC Ultra LED Not Working
Re: EVGA 2080 XC Ultra LED Not Working Thursday, October 25, 2018 2:45 AM (permalink)
Since you deleted the old download all you need to do now is to uninstall the old precision version from add/remove programs. After that you can install the new one I linked.
#31
zrstoddart
Re: EVGA 2080 XC Ultra LED Not Working Saturday, October 27, 2018 1:13 AM (permalink)
I've followed this thread so far to fix this problem. I am actually running 2 cards and my NVLink bridge hasn't arrived yet so its a bit different for me.
When I put them in they both lit up, running the old precision X didn't change the colors, so I researched, found Precision X1 and downloaded it. Upon running it, both cards went dark.
I installed the batch file and the new 0.3.3.1 beta version listed earlier in the thread and this fixed the top card but the bottom is still dark. I get the feeling that even after getting this bridge in the mail and hooking it up, this will not resolve.
Anyone have any ideas other than the painfully obvious "wait for the NVLink Bridge"?
#32
Re: EVGA 2080 XC Ultra LED Not Working Saturday, October 27, 2018 1:38 AM (permalink)
zrstoddart
You'll need to remove the first card from your system, and then insert the second card into the first pci-e slot to update it with the .bat file.
#33
EVGA_JacobF
  • Ribbons : 26
Re: EVGA 2080 XC Ultra LED Not Working Saturday, October 27, 2018 1:43 AM (permalink)
#34
leo8815
Re: EVGA 2080 XC Ultra LED Not Working Sunday, October 28, 2018 5:12 AM (permalink)
Hi, I have the EVGA 2080Ti Ultra XC and need the proper firmware and bat exe to fix my LED issue. Please help. Part Number: 11G-P4-2383-KR
#35
Re: EVGA 2080 XC Ultra LED Not Working Sunday, October 28, 2018 7:34 PM (permalink)
leo8815
https://forums.evga.com/FindPost/2869911
#36
saloo95
Re: EVGA 2080 XC Ultra LED Not Working Monday, November 12, 2018 7:03 PM (permalink)
Thanks for the help guys!
#37
NeigoR
Re: EVGA 2080 XC Ultra LED Not Working Wednesday, December 12, 2018 4:52 PM (permalink)
I have the same probleme with my 2080 Ultra XC and Precison X1 0.3.10.0. I tried to install that "2080_XC_Ultra_E196.zip" but it did not change anything.
post edited by NeigoR - Wednesday, December 12, 2018 4:55 PM
#38
tplocinski
Re: EVGA 2080 XC Ultra LED Not Working Monday, December 17, 2018 10:37 PM (permalink)
NeigoR
I have the same problem with my 2080 Ultra XC and Precision X1 0.3.10.0. I tried to install that "2080_XC_Ultra_E196.zip" but it did not change anything.
I have the same card, and the same problem. Tried the MCU update and latest precision x1 - my card is not dark, but I can't change the LED color.
  • Ribbons : 282
Re: EVGA 2080 XC Ultra LED Not Working Monday, December 17, 2018 10:55 PM (permalink)
NeigoR
Go back to 0.3.9 and do not set PX1 to start with the OS
post edited by bcavnaugh - Monday, December 17, 2018 10:57 PM
#40
  • Ribbons : 282
Re: EVGA 2080 XC Ultra LED Not Working Monday, December 17, 2018 10:56 PM (permalink)
tplocinski
NeigoR
#41
tplocinski
Re: EVGA 2080 XC Ultra LED Not Working Tuesday, December 18, 2018 4:22 AM (permalink)
That fixed it, thanks!
#42
NeigoR
Re: EVGA 2080 XC Ultra LED Not Working Tuesday, December 18, 2018 9:45 AM (permalink)
Okok, I will try to return at 0.3.9
#43
  • Ribbons : 282
Re: EVGA 2080 XC Ultra LED Not Working Tuesday, December 18, 2018 7:38 PM (permalink)
NeigoR
Let us know it works after.
#44
NeigoR
Re: EVGA 2080 XC Ultra LED Not Working Wednesday, December 19, 2018 12:08 AM (permalink)
It works! thank you!
I'm a french guys, sorry for my bad english :p
#45
  • Ribbons : 282
Re: EVGA 2080 XC Ultra LED Not Working Wednesday, December 19, 2018 9:17 PM (permalink)
NeigoR
#46
AngelCc19
Re: EVGA 2080 XC Ultra LED Not Working Thursday, May 30, 2019 3:54 AM (permalink)
i have the same problem with my rtx 2070 xc, i never modify the light of the logo since I did not know it was rgb I thought it was only blue, then I saw that with the evga precision x1 could be modified then I saw that if the logo is rgb, I just modified it a couple of times and I did not want turn on later, try reinstalling the software but it does not work
#47
OldZealot
Re: EVGA 2080 XC Ultra LED Not Working Saturday, October 19, 2019 8:11 PM (permalink)
Sprigum
Heisenburg,
I have a similiar issue - I don't believe it is the LEDs as they worked perfectly fine initially, but I wanted to change the blue to white. Once I installed Precision X1 they seem to have stopped working. I've tried uninstalling and reinstalling the program to no avail. I did receive some sort of error on the initial install that mentioned the LED. Now there isn't even an option to change the color.
Same problem on EVGA 2080 Super XC Gaming 08G-P4-3182-KR. I suppose that I need some .bat file to turn LEDs on again. Is there any way to find such file for 2080 SUPER card? Or should I just use .bat file posted by ? I havn't tried to reinstall Presicion X1 yet, since I'm affraid that can make things worse :) All I did - tried to change LED color.
Upd: False alarm) Just needed to update LED Firmware as required by Presicion X1 when starting the programm
post edited by OldZealot - Sunday, October 20, 2019 9:54 AM
#48
Paddy32
Re: EVGA 2080 XC Ultra LED Not Working Sunday, August 09, 2020 6:19 PM (permalink)
I have the same problem on my GTX 1070 Ti. Even with Nvidia LED Visualizer 1.3, when i turn the white LED on, nothing happens. I tried installing EVGA Precision XOC and EVGA Precision X1 but nothing has worked, I simply can't get the white LEDs on the side to light up. Would anyone have an idea on how to fix this ??
MB : MSI X570 TOMAHAWK WIFI CPU : Amd Ryzen 9 5900X CPU Cooler : Noctua NH-D15
GPU : EVGA RTX 3080 FTW3 (Undervolt : 1905MHz 875mV)
PSU : Seasonic Focus 850W Platinum RAM : 16Gox2 3200Mhz
Pictures of my build
#49
  • Ribbons : 123
Re: EVGA 2080 XC Ultra LED Not Working Sunday, August 09, 2020 7:58 PM (permalink)
Paddy32
what is the EVGA part number of your GPU ?
OS ?
#50
Paddy32
Re: EVGA 2080 XC Ultra LED Not Working Sunday, August 09, 2020 8:03 PM (permalink)
OS ?
Part Number = 08G-P4-5671-KR
Description: EVGA GeForce GTX 1070 Ti SC GAMING, 08G-P4-5671-KR, 8GB GDDR5, ACX 3.0 & Black Edition
OS = Fresh install of Windows 10
#51
  • Ribbons : 123
Re: EVGA 2080 XC Ultra LED Not Working Sunday, August 09, 2020 8:06 PM (permalink)
Paddy32
OS ?
OK
  Black Edition ... you mention above Would Not have those LEDs
 I see you started your Own thread for this issue:  https://forums.evga.com/FindPost/3068962
--> Best not to post all over the EVGA Forums in years old threads .... Your Thread is the best place for you to get help
All members Replies to this issue should be in your thread - link above
#52
Nazarus
Re: EVGA 2080 XC Ultra LED Not Working Tuesday, August 11, 2020 8:02 AM (permalink)
I had this same issue.  Had to pull the video card out, shut down, put the card back in reboot.
Associates: RQAORCJB8JNEFOB/Affiliate:  YTOQRPH9OK
#53
Paddy32
Re: EVGA 2080 XC Ultra LED Not Working Tuesday, August 11, 2020 8:41 AM (permalink)
Nazarus
Are you suggesting that I pull the GPU out of the motherboard whilst the PC is ON, then shut down the PC, put back card, and reboot ?
#54
