Heisenberg726
After plugging in my 2080 XC Ultra, downloading the latest nvidia drivers, downloading the latest precision X1, and fiddling around with the led and rgb settings, I still cannot seem to get my card's led to work. It doesn't even turn on. Is there anything that can help fix this, or should I just RMA the card?
Sprigum
Re: EVGA 2080 XC Ultra LED Not Working
Saturday, October 20, 2018 1:09 AM
Heisenburg, I have a similiar issue - I don't believe it is the LEDs as they worked perfectly fine initially, but I wanted to change the blue to white. Once I installed Precision X1 they seem to have stopped working. I've tried uninstalling and reinstalling the program to no avail. I did receive some sort of error on the initial install that mentioned the LED. Now there isn't even an option to change the color.   " />
arcaderadio
Saturday, October 20, 2018 1:44 AM
Just installed X1 on my new XC 2080ti and I have the same issue as Sprigum above, error on the initial install and everything.
EVGA_JacobF
- Ribbons : 26
Saturday, October 20, 2018 1:48 AM
EVGA_JacobF
- Ribbons : 26
Saturday, October 20, 2018 1:49 AM
Sprigum Heisenburg, I have a similiar issue - I don't believe it is the LEDs as they worked perfectly fine initially, but I wanted to change the blue to white. Once I installed Precision X1 they seem to have stopped working. I've tried uninstalling and reinstalling the program to no avail. I did receive some sort of error on the initial install that mentioned the LED. Now there isn't even an option to change the color. " />
This error is likely related to the MCU update failing. What card do you have?
EVGA_JacobF
- Ribbons : 26
☄ Helpfulby Heisenberg726 Sunday, October 21, 2018 7:06 PM
Heisenberg726 After plugging in my 2080 XC Ultra, downloading the latest nvidia drivers, downloading the latest precision X1, and fiddling around with the led and rgb settings, I still cannot seem to get my card's led to work. It doesn't even turn on. Is there anything that can help fix this, or should I just RMA the card?
Can you try this update? Run the .bat file 2080 XC ULTRA = http://storage.cdn.evga.com/driver/MCU/2080_XC_Ultra_E196.zip
arcaderadio
Saturday, October 20, 2018 1:54 AM
Sure, that gets the LEDs working. Starting up Precision X1 kills 'em again
thomas.balint1992
Saturday, October 20, 2018 2:47 AM
Yeah , i did the same. Led came back.Precision X1 killed it..
Sprigum
Saturday, October 20, 2018 2:55 AM
EVGA_JacobF
I have an RTX 2080 XC Gaming 08G-P4-2182-KR I did try to uninstall and reinstall the software to no avail.
Saturday, October 20, 2018 2:58 AM
Sprigum
EVGA_JacobF
Try this one... http://storage.cdn.evga.c...r/MCU/2080_XC_E196.zip
thomas.balint1992
Saturday, October 20, 2018 3:10 AM
Sprigum
EVGA_JacobF
Try this one...
That brings the lights back but once you open Precicion X1 lights out again.
Saturday, October 20, 2018 3:26 AM
Did you restart your computer after running the file?
Sprigum
Saturday, October 20, 2018 3:29 AM
Sprigum
EVGA_JacobF
Try this one...
This worked for me, thank you.
Saturday, October 20, 2018 3:31 AM
thomas.balint1992
Saturday, October 20, 2018 3:59 AM
Heisenberg726
Sunday, October 21, 2018 7:07 PM
EVGA_JacobF
Thank you so much!!! I was just about to RMA my card because I thought the leds were broken, but this completely fixed it! Seriously, the support here is top-notch. Thank you!
Kully
Sunday, October 21, 2018 7:24 PM
I have the same issue with a 2080 ultra xc. What can be done?
Heisenberg726
Sunday, October 21, 2018 7:27 PM
Kully I have the same issue with a 2080 ultra xc. What can be done?
Download and run the .bat file for your card that EVGA_Jacob posted on this thread. That's what worked for me.
josephiorio
Wednesday, October 24, 2018 10:15 PM
hello, Im in need of this same exact help! The card was lit up blue, downloaded the precision x1 app, and the light went away. Came across this and im glad there is a solution. only thing is, im a noob when it comes to understanding all of this. I normally send my rig in to get it all switched up with the graphics card but this time I wanted to do it myself. went from a 970- 1080ti in one rig. got another rig with a 1060 6gb, and jumped to the 2080 xc card. Can someone walk me through with having to download and the .bat file, step by step to make sure im doing it right? I know it sounds easy and im sure it is, but I just wanted to be on the safe side. it seems so simple. I opened what Jacob sent, and what the moderator sent. im not sure what to do after it downloads, I open it up 3 "files" are open. I try but I don't know enough to try and mess around because nothing seems to be working so I figured I messed up somehow. I'd really appreciate the help
post edited by josephiorio - Wednesday, October 24, 2018 10:28 PM
josephiorio
Wednesday, October 24, 2018 10:35 PM
Even the fans when I play PUBG, aren't running when I play. *facepalm* any help would be appreciated, if I have to send it in to get it teched up then I will.. but if I can avoid doing so then that would be cool as well. thank you for anyone that can help me out.
Wednesday, October 24, 2018 10:53 PM
Just run the .bat file after you move all three files to the desktop.
josephiorio
Thursday, October 25, 2018 0:05 PM
Sajin Just run the .bat file after you move all three files to the desktop.
josephioriothat's not very elaborate to me lol Is the Precision app suppose to be deleted when I run the .bat file? or does it matter? okay so, I did do it. Immediately after I got it, the LED lighting turned back on. Does that mean I can redownload the precision app, and should able to change the color? its blue by default, I just want it red. thank you bunches!
post edited by josephiorio - Thursday, October 25, 2018 0:10 PM
Thursday, October 25, 2018 0:09 PM
josephiorio
Thursday, October 25, 2018 0:11 PM
Sajin No.
okay so, I did do it. Immediately after I got it, the LED lighting turned back on. Does that mean I can redownload the precision app, and should able to change the color? its blue by default, I just want it red. I didn't get your no until after I saw your comment. So the precision does have to be downloaded or it doesn't? thank you bunches!
Thursday, October 25, 2018 0:15 PM
Precision doesn't need to be removed before running the .bat file. Yes, you can now download & reinstall precision and everything should work like it should.
josephiorio
Thursday, October 25, 2018 0:19 PM
Sajin Precision doesn't need to be removed before running the .bat file. Yes, you can now download & reinstall precision and everything should work like it should.
gotcha, only thing now is that it doesn't seem to let me change colors. like the option is just not there like what it did when the LED stopped working, is that suppose to fix that problem too or no?
Thursday, October 25, 2018 0:54 PM
josephiorio
Don't think so. Try this version... https://www.evga.com/EVGA...on_X1_0.3.3.1_BETA.exe
josephiorio
Thursday, October 25, 2018 1:07 AM
josephiorio
alrighty, should I delete the other download first before I download this one?
Thursday, October 25, 2018 1:11 AM
josephiorio
josephiorio
Delete the old download & uninstall the old version before installing the new version.
josephiorio
Thursday, October 25, 2018 2:40 AM
josephiorio
josephiorio
so I deleted the old download, but I don't see it to uninstall the old version. and that's the download you were just referring to, not the precision app, correct? please be specific if you don't mind lol EDIT: after downloading that, I realized you meant the precision (obviously lol) so I uninstalled the other download anyways, then I deleted the old download for precision, downloaded the new one you told me to download, and right away I knew a difference because it was like a purple, but changed to a bright blue. I went in and changed the color and it immediately went to red. without even having to download that other download up above, so that's cool! thank you bunches for your patience lol
post edited by josephiorio - Thursday, October 25, 2018 2:49 AM
