Sniper_3001
Hey guys. I just bought an EVGA Z390 dark mb with a 9900ks cpu. I also paired it with a Corsair 150i AIO water cooler. Yesterday I decided to stress test it with Real Bench. CPU was set to hit 5.0ghz all cores (which is stock) with auto VCore. Ran the test for 30min. The test passed but temps were hitting over 100 degrees. I was wondering if this was normal for these CPUs? Or is there something wrong with my cooling? Any advice
coolmistry
- Ribbons : 45
Re: CPU temps help
2019/12/12 04:43:07
Hello and Welcome to the Forum We need to know what is your FULL spec of your PC and What OS Windows are you using! That definitely not accept over 100c temp! It Tjunction MAX 100c What is the voltage reading in your BIOS setting for CPU which is left Auto it will reach high voltages! May need change to manual voltage? Did you use thermal pasta for your CPU? Checking your cooler pump seat firm properly?
Windows 11 Home 64bits up to Dated i9 11900K 5,275 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || 2 x Nvidia RTX 2080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3800mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
bob16314
- Ribbons : 761
Re: CPU temps help
2019/12/12 05:01:56
Be sure you have the latest BIOS available for your board in the EVGA Download Center. You need to see what the Vcore is under load using CPU-Z or similar utility. And check you cooler mounting.
post edited by bob16314 - 2019/12/12 05:05:31
Sniper_3001
Re: CPU temps help
2019/12/12 05:29:54
9900ks Evga z390 dark 16gig gskill 4133mhz (running no OC) Corsair 150i Samsung 1TB m.2 drive Windows 10 latest version Gelid thermal paste
What is default voltage for the 9900ks? 1.2 volts?
coolmistry
- Ribbons : 45
Re: CPU temps help
2019/12/12 05:35:43
How come hit 100c for 1.2 voltage??? Thanks for your Full spec and put on in your MOD RIGHave you check your CPU Water Cooler AIO pump? EDIT> Have you update your BIOS what Bob send you link above?
post edited by coolmistry - 2019/12/12 05:38:20
wmmills
- Ribbons : 40
Re: CPU temps help
2019/12/12 05:54:53
bob16314 Be sure you have the latest BIOS available for your board in the EVGA Download Center. You need to see what the Vcore is under load using CPU-Z or similar utility. And check you cooler mounting.
+1... yeah this sounds like its a temp bug with a outdated bios or the utility you were using maybe. What gpu? Were you benching the gpu too?
coolmistry
- Ribbons : 45
Re: CPU temps help
2019/12/12 06:13:54
Can you tell us what is CPU Cooler water? which series of Corsair?
RainStryke
The Advocate
- Ribbons : 60
Re: CPU temps help
2019/12/12 06:18:04
I would double check your thermal paste application and make sure the CPU is properly mounted to the CPU socket and applying the full pressure. I had a i9 9900KS for a day or so and ran a bunch of tests on it for about a 4-5 hour run... It got pretty hot under my custom loop... 75C was the max temps I saw and it would only be for a moment before it would drop back into the 60C range.
Main PC | Secondary PC Intel i9 10900K | Intel i7 9700KMSI MEG Z490 ACE | Gigabyte Aorus Z390 MasterASUS TUF RTX 3090 | NVIDIA RTX 2070 Super32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17SuperFlower Platinum SE 1200w | Seasonic X-1250Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GBCougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5 3DMark Results:Time Spy|Port Royal
Re: CPU temps help
2019/12/12 07:35:37
Run CPU-Z while testing to monitor your CPU Auto voltage is known on All MB to allow more voltage than is probably needed So if your cooler is mounted & working as designed .. I'd manually set the BIOS to control voltage
vegajf51
Re: CPU temps help
2019/12/12 07:43:21
The 9900ks is generally a hot running CPU so don't expect it to ever run cool with an AIO, that said 100C is way to hot. It appears you have a decent AIO cooler so make sure you are on a updated bios and try re-pasting the cooler.
Sniper_3001
Re: CPU temps help
2019/12/12 08:00:32
Thx for the replies. I have a Corsair 150i. 360mm AIO. I have it in a push pull config too. I also am running an Evga 2080ti ftw3. I will do everything that was stated tonight when I get home and see what happens.
coolmistry
- Ribbons : 45
Re: CPU temps help
2019/12/12 08:11:12
No problem and Your CPU cooler water is perfect no worry!!!
bob16314
- Ribbons : 761
Re: CPU temps help
2019/12/12 09:07:15
Yes, those CPUs do inherently run on the hot side, but shouldn't get that hot at stock settings. Also be sure the fan header that you connect the pump to set to 100% manual speed in the BIOS, not Smart Mode..I thought there may be an AIO_PUMP header on that board but I'm not seeing one.
RainStryke
The Advocate
- Ribbons : 60
Re: CPU temps help
2019/12/12 10:13:31
Sniper_3001 Thx for the replies. I have a Corsair 150i. 360mm AIO. I have it in a push pull config too. I also am running an Evga 2080ti ftw3. I will do everything that was stated tonight when I get home and see what happens.
Now thinking about it, when I was messing around with my AIO on my 2nd PC I ran into 100C temps on my processor, it took a few minutes for it to get that hot... but I found out that when I put the side panel back on, it somehow disconnected the SATA power that goes to the pump... Once I corrected the problem, my temps were back down to the low 30's almost immediately. As Bob mentioned, make sure the pump is working. You should be able to feel a slight vibration on the CPU block.
apsese
Re: CPU temps help
2019/12/12 11:39:26
The AIO might be not enough for this CPU under prolonged stress. If the AIO wouldn't work at all, as some have stated, your PC would meltdown .
finally a signature without that associate code
d.burnette
- Ribbons : 17
Re: CPU temps help
2019/12/12 13:06:47
I use the Corsair H150i Pro 360 mm AIO on my 9900k and it does a decent job for me. My cores certainly do not get that hot, usually in upper 60's low 70's. Running 5.2 GHz on all cores with voltage set to override at 1.318v and -75% vdroop. I would take a good look at re-seating that cooler. Definitely stay away from auto voltage, I would not even use adaptive, use override.
post edited by d.burnette - 2019/12/12 13:10:10
Don EVGA Z390 Dark MB | i9 9900k CPU @ 5.2 GHz all cores | EVGA RTX 3090 FTW3 Ultra | 32 GB G Skill Trident Z 3200 MHz CL14 DDR4 Ram | Corsair H150i Pro Cooler | EVGA T2 Titanium 1000w Power Supply | Samsung 970 Pro 1TB m.2 Nvme | Samsung 970 Evo 1TB m.2 Nvme | Samsung 860 Evo 1TB SATA SSD | EVGA DG 87 Case |
kelkel1
Re: CPU temps help
2019/12/12 13:16:30
The Dark really, really, overvolts on Auto. Without knowing the load voltage, hard to say if that is the problem or not.
joeymir
Re: CPU temps help
2019/12/12 17:22:47
While I do not own a 9900K, from general reading since release, they do seem to run HOT, but not nearly THAT HOT. Sounds like your voltage is way to high, or it's very possible your AIO has some air pockets in there. I had fought with a Corsair H80 a while back where somehow some air found itself in the CPU block and refused to leave. The CPU temps would spike and system would shutdown. The pump & fan both showed normal operation, so I knew something strange was going on. Upon inverting the chassis of this computer, you could hear air start moving through the radiator & tubing, and CPU temps dropped to normal levels almost instantly and stayed that way. CPU temps were about 20-30C high, and that was on a old Phenom II X4 965 system(still chugging along).
Gigabyte X570 Aorus Master | Ryzen 9 5900X | 32GB Crucial Ballisitx DDR4 3600MHz | MSI Radeon 6900 XT | Samsung 950 Pro 512GB | 2x Crucial MX500 1TB Raid-0 | 2x WD Velociraptors 500GB Raid-0 | Seasonic Focus Platinum 850W | Lian-Li PC-O11
JimBeamBlack
Re: CPU temps help
2019/12/12 18:20:10
I have the SAME exact problem with my 9900k, to get the cpu to run at stock I have to set everything to auto, then, on the cpu "OC" tab/page, change the voltage to "override" at a target of 1.198v and -75% vdroop, to get it to run LinX and keep the temps under 80c under extreme full loads. Also, try to use CPUID HWMonitor to keep an eye on everything. I can run this 24/7 and it runs perfect. But you can try higher voltage "override" with a target of "up to" about 1.25v with the 75% vdroop and see how it does. good luck. OH ONE MORE THING, for running the cpu at stock (or as close as your going to get..lol) if you run the "Extreme Power Profile" in windows 10 pro, you need to set the minimum cpu setting to like 95% IN that profile, it will let it clock down to about 3200 when the cpu is not being used, OR you can just use the balanced profile. However, IF you are going to "overclock" use the Extreme Power Profile and set all CPU setting to 100%.
post edited by JimBeamBlack - 2019/12/12 18:36:53
EVGA Z590 Dark ; i9 11900k ; 32gig Corsair Vengeance DDR4 3600 ; EVGA 3080 FTW Ultra3 ; Creative AE-7 ; Win 11 64bit Pro : EVGA 1200 Plat PSU
Sniper_3001
Re: CPU temps help
2019/12/12 19:45:05
ok guys so I found a couple of things. Number one was I was running a push/pull config but I probably ran the fans the wrong way. Removed the fans. Second I noticed that the 150i pro was plugged into the AUX port and not the CPU_FAN port as stated in the manual. 3rd I noticed that one of the fins from my rad is bent pretty badly. Just ran a stress test for 15 min at 100% cpu work load at 5.0ghz at 1.2volts. Max temp hit was 84 degrees with it roughly jumping around in the 70s. Not sure if this is normal or bad. Also how much impact will the bent fan from the rad have on cooling?
bob16314
- Ribbons : 761
Re: CPU temps help
2019/12/12 21:06:13
The CPU cooler fans should be oriented so that they're sucking in outside air. You should be running the fans (including case fans) and pump at full speed with Corsair Link (in Downloads) when stress testing/benchmarking. Just straighten out the radiator fin as best you can, no biggie. But i'm calling the core temps in normal range now for that CPU/Cooler, but some BIOS (make sure you have the latest version) CPU Voltage/Vdroop (LLC) tweaking might get them down some..RealBench is pretty stressful..I'm seeing pretty much identical core temps as you (81C max) and that's with my 8700K OC'd to 5.2GHz, delidded and using Thermal Grizzly Conductonaut TIM.
Sniper_3001
Re: CPU temps help
2019/12/13 03:21:32
What is the newest bios version for the z390 dark? Is it 1.07 September release? Also would upgrading the fans say from 47cfm 1400rpm stock fans to 75cfm 2000rpm fans make any difference in cooling? Would I see lower temps?
post edited by Sniper_3001 - 2019/12/13 03:24:02
bob16314
- Ribbons : 761
Re: CPU temps help
2019/12/13 04:04:53
1. Yeah, 1.07 is the latest 2. Maybe a little, probably not much, I dunno Like I said, you might be able to get the Vcore/Temps down more by manually adjusting the CPU Core Voltage and Vdroop. Try running the Intel Processor Diagnostic Tool, or IntelBurnTest for for a quick and dirty stability test for the CPU..There's Unigine Superposition for a good gaming benchmark.
coolmistry
- Ribbons : 45
Re: CPU temps help
2019/12/13 05:43:50
'Also would upgrading the fans' it will not much different really but I did change my silent fans on my EVGA CPU Cooler radiator from EVGA fans are more loud noise!! For your EVGA Z390 Dark motherboard there some fans pins! I recommend to put Cooler Pump on to PWR FAN on motherboard and those three spilt fans pin for radiator you can connect from your CPU cooler! The Cooler pump must need full speed and the cooler fans for radiator you can adjust speed in Corsair Link what bob said!
castrator86
Re: CPU temps help
2019/12/13 06:40:37
Always make sure you tighten down your retention bracket in an X pattern (top left, lower right, top right, lower left) to get the best contact on the CPU lid. After that check voltages and as you already stated, where things are plugged in to headers on the board.
kelkel1
Re: CPU temps help
2019/12/13 13:34:14
Sniper_3001 ok guys so I found a couple of things. Number one was I was running a push/pull config but I probably ran the fans the wrong way. Removed the fans. Second I noticed that the 150i pro was plugged into the AUX port and not the CPU_FAN port as stated in the manual. 3rd I noticed that one of the fins from my rad is bent pretty badly. Just ran a stress test for 15 min at 100% cpu work load at 5.0ghz at 1.2volts. Max temp hit was 84 degrees with it roughly jumping around in the 70s. Not sure if this is normal or bad. Also how much impact will the bent fan from the rad have on cooling?
Ambient temps can have a significant effect on water cooling temps as well. And, you did not say which stress test you ran (RealBench?), obviously some are more stressful than others. Also, what AVX offset? VCCSA and VCCIO voltages may add to temps.
Sniper_3001
Re: CPU temps help
2019/12/13 17:02:37
Yes Realbench. No AVX offset and no vccio or vccsa voltages (auto)
kelkel1
Re: CPU temps help
2019/12/14 04:10:19
My Dark sets the voltages too high on Auto, I would suggest using Adaptive or Override to manually set VCore, Vccsa, Vccio. You did not mention what your ambient temps are.
d.burnette
- Ribbons : 17
Re: CPU temps help
2019/12/14 05:28:38
Sniper_3001
Re: CPU temps help
2019/12/17 16:49:38
So I managed the following settings after stability tests:
5.2ghz @ 1.32 volts AVX offset - 2 Vccio - 1.15 Vccsa - 1.15 4000mhz ddr4 19-19-35
The temps are still crazy high at 100% load. Aka around low to high 90s. I find that 9900k is affected by voltage big time. I was able boot up 5.2ghz at 1.21 volts but only lasted about 5 min of stress test. But the temps were in the 60s. My 7700k wasn’t affected by voltage as much. Gaming temps are around 60s to 70s. I’m pretty happy with the results. Would an ek custom loop lower temps any more compared to my Corsair 150i pro? Worth the upgrade?
