CPU temps help
kelkel1
Re: CPU temps help 2019/12/17 17:47:29 (permalink)
Temp-wise
Custom loop might do better.
Direct die would probably do better.
Lower ambient temps definitely do better.
Z390 DARK, 9900K, 2080 FTW3 ULTRA, GSKILL 4500, 960EVO M.2
https://valid.x86.fr/52sqs5
#31
RainStryke
The Advocate
  • Ribbons : 60
Re: CPU temps help 2019/12/17 20:01:12 (permalink)
A custom loop would do a lot better, the more radiators you can add the better. It does require a good chunk of time... The video tutorials create a bit of an illusion that it's fairly quick and easy, it's not and it takes more planning. You can buy a EK kit that will have everything picked out for you if you are not sure what to buy. It doesn't include a drain port which can be kind of expensive to add on... but entirely necessary if you want to maintain your custom loop. So keep that in mind if you are looking.
Main PC | Secondary PC
Intel i9 10900K | Intel i7 9700K
MSI MEG Z490 ACE | Gigabyte Aorus Z390 Master
ASUS TUF RTX 3090 | NVIDIA RTX 2070 Super
32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17
SuperFlower Platinum SE 1200w | Seasonic X-1250
Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GB
Cougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5
3DMark Results:Time Spy|Port Royal
#32
browns72
Re: CPU temps help 2019/12/17 21:12:34 (permalink)
kelkel1
Temp-wise
I wouldn't recommend a Direct Die Contact on the 9900ks for beginning users as the 9900ks is soldered. It depends on your chip and your voltage, but since the 9900ks is binned for 5GHz all turbo, it for sure shouldn't get to 100 c unless you're having a cooler problem. For starters re-apply your paste and re-seat the cooler. Depending on your overclocking experience, I would start at around 1.3V with a -50% vdroop, run stability test adjusting your voltages until you find something that's stable and then start adjusting the vdroop to be lower. It's all in silicon lottery, I've had chips that can undervolt and hit high clocks, and I've had some at 1.4 volts that barely maintain 5GHz.
If you're temps are still high after that, a different cooling solution may be needed. There also may be other settings you can adjust like your PL's and the such that someone may chime in eventually on this post.
#33
RainStryke
The Advocate
  • Ribbons : 60
Re: CPU temps help 2019/12/18 06:17:40 (permalink)
9900KS's are not binned. They are a i9 9900K with a higher power limit to attain 5GHz on all cores. That's also why they run so hot.
#34
