Any memory temp over 55c causes fan to max out (FTW3 Hybrid)
MrEWhite
2018/09/22 12:45:53 (permalink)
So, I just installed the hybrid cooler, and using Precision, I can see the memory fan max out over 55c. While it isn't audible as I'm pretty sure the memory fan does nothing due to the hybrid cooler, why is it maxing out over 55c in Precision?
15 Replies Related Threads
    • Ribbons : 135
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 12:51:52 (permalink)
    MrEWhite
    Do you have a setting in Precision that is causing the Memory temp to control the fan speed? There isn't a 'memory fan'. That fan is to cool the PWM.
    MrEWhite
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 12:54:37 (permalink)
    MrEWhite
    Well, as I said, since this isn't a FTW3 Hybrid card straight off the bat, it still shows the original fan controls. This un-connected fan (the memory one) maxes out whenever the temperature goes above 55c.
    post edited by MrEWhite - 2018/09/22 12:59:51
    • Ribbons : 123
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:00:59 (permalink)
    Your Stock BIOS still thinks you have a stock cooler on your card
    You would have to flash the FTW3 Hybrid BIOS to make this change / behave like an FTW3 Hybrid
    MrEWhite
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:01:43 (permalink)
    But why would it show the fan maxing out if nothing is connected?
    Also, is it safe to flash the FTW3 Hybrid bios over the stock one?
    • Ribbons : 123
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:03:08 (permalink)
    Flash the correct FTW3 Hybrid, BIOS ---> Only to the Second "Slave" (number 2) BIOS position
    It is "Telling the fan to run"  not measuring the fan probably as it does not physically exist any more
    MrEWhite
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:03:54 (permalink)
    Alright, I'll give it a shot.
    Edit: Do you know where to find it? I can only find the master BIOS on techpowerup.
    • Ribbons : 135
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:06:13 (permalink)
    MrEWhite
    MrEWhite
    I got that you installed the Hybrid...I've done a couple. But you can see why I asked.
    MrEWhite
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:09:49 (permalink)
    MrEWhite
    MrEWhite
    Well, no. It's just completely stock settings with some overclocking.
    post edited by MrEWhite - 2018/09/22 13:14:12
    • Ribbons : 135
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:13:49 (permalink)
    MrEWhite
    MrEWhite
    MrEWhite
    Well, no. It's just completely stock settings with some OC tuning.
    Yes, but I don't know that until I ask and well many years...at least a decade or two before joining here, I learned to avoid assuming what anyone has done with their system. Some have used the other fan headers on the GPU to control the PWM fan or control a rad fan. So, I ask.
    • Ribbons : 123
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:17:17 (permalink)
    MrEWhite
    Check this thread:  https://forums.evga.com/FindPost/2693145
    if its not in the above link; you could check this link (its long - not sure its in there)
    https://forums.evga.com/FindPost/2721450
    • Ribbons : 135
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:20:00 (permalink)
    MrEWhite
    Actually I wonder if he plugged the VRM fan into the memory fan header....I've not done an FTW3 Hybrid...is that possible?
    • Ribbons : 123
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 13:23:51 (permalink)
    That a valid possibility -- if the member is seeing RPM displayed
    My two FTW3 Hybrids are factory cards in my AIO Folding Rig (see signature for link), never had the cooler off of them
    On the BIOS, you can contact CS and request they email you one.  Make sure your cad is registered first.
    https://www.evga.com/about/contactus/
    MrEWhite
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 16:49:33 (permalink)
    Just Precision being Precision I guess.
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 16:53:16 (permalink)
    MrEWhite
    Re: Any memory temp over 55c causes fan to max out (FTW3 Hybrid) 2018/09/22 16:54:09 (permalink)
    https://forums.evga.com/FindPost/2736412
    Found my problem just to be Precision just messing up the display, as shown above.
