This has been driving me nuts. Unacceptable fan behaviour and should be fixed.
I don't like running control software but I have to to fix the fans on this card. This is my current solution:
Observations:
Fan controllers spin fans up quickly with a burst and then slows them down.
Like others have communicated in the threads I listed in my previous reply, fan 3 behaves differently than fan 1 and 2.
Fan 1 starts and stops up to about 12% then seems to be able to sustain a smooth rotation around 340 RPM
Fan 2 starts and stops up to about 14% then seems to be able to sustain a smooth rotation around 428 RPM
Fan 3 starts and stops up to about 12% where it starts continuously pulsing and ticking around 432 RPM
Fan 3 continues to pulse (~1 pulse per second) until 32% then seems to be able to sustain a smooth rotation around 952 RPM
Running the fan at a higher RPM then moving it lower you can achieve a slower constant RPM
All fans make a tick/click sound when speeds change dramatically suddenly. I think on the deceleration.
What I desire:
Would like to see the fan controller start up the fan and run it longer before throttling down to the set speed which would allow lower RPMs
Would like to see fans not cycle on and off, stay off at healthy temperatures or prefer to run at their lowest possible constant RPM
Would like to see pulsing and odd behaviour of fan 3 go away above 12% and be able to run the fan without it below 30%
Would like this to happen without having to install Precision X1 and have it load on startup
NOTE: Can't insert an image in firefox. Get a 5XX error and then it puts a text blob in my post.
post edited by parawizard - 2022/02/09 18:40:01
