3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin
nergetic
2020/09/28 15:06:17 (permalink)
My GPU (3080 XC3 Ultra) is idling around 57 to 59 degree and the fan are not spinning. Is this normal temperature for the GPU to be at when just browsing the internet (not watching videos), using Microsoft Word, Excel, and Outlook? And is it normal for the fans to not spin around those temperatures?
10 Replies Related Threads
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/09/28 15:12:07 (permalink)
    Fans don't kick on until 60-65c. Idle temps are a bit high, but shouldn't cause any problems. Load temps are what you should be concerned with.
    post edited by Sajin - 2020/09/28 15:18:38
    nergetic
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/09/28 15:17:58 (permalink)
    Thank you Sajin for the quick reply!
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/09/28 15:18:48 (permalink)
    No problem.
    liud21
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/09/28 15:56:22 (permalink)
    adjust the fan curve..
    sinewave
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/09/28 16:36:51 (permalink)
    I had to raise my min fan speed to 60% to get a desktop idle under 50c. The clocks don't seem to drop at idle, regardless of power management settings.
    CPU: 9700k @4.8ghz
    GPU: 3080 XC3 Ultra
    PSU: Corsair RM850X
    RAM: 2x16gb G.Skill TridentZ
    SSD: Samsung 970 Evo 1 TB
    MOBO: Asus Z390-i
    CASE: Corsair Crystal 280X
    wkwwong
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/12/02 06:07:29 (permalink)
    Do I have to start the precision X1 app on every startup if I want the card to run at the adjusted fan curve?
    arestavo
    • Ribbons : 76
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/12/02 07:18:59 (permalink)
    wkwwong
    Yes. Fan curves are not saved to the card. If you set a fixed %, you can close out of PX1 and have it continue to work at that fixed %, again only after opening PX1.
    dragomirc
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/12/02 07:30:09 (permalink)
    wkwwong
    Yes, and be sure to check Fan Curve Control box.
    post edited by dragomirc - 2020/12/02 07:43:31
    kacan22
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/12/02 14:39:48 (permalink)
    I think nvidia driver is problem here. Thats why card idle 60C insted of 40-45C like 2080ti
    Game Ready Driver Important Open Issues
    [G-SYNC][NVIDIA Ampere GPU architecture]: GPU power consumption may increase in idle mode on systems using certain higher refresh-rate G-SYNC monitors. [200667566]
    wkwwong
    Re: 3080 XC3 Ultra Temps at 57-59 Degree and Fans Won't Spin 2020/12/02 18:25:13 (permalink)
    arestavo
    wkwwong
    Sometime I only use the computer for watching YT Netflex, is it safe (in long run) to keep the idle temp. at 60c?
    Or should I have the PX1 startup with the OS to keep the idle temp. low at all time?
