Jaz11Is this a common problem?
Is there a way to fix?
grabibusThe only way is to flash with a 2x8 pin bios as the KFA2. 390W bios.It bypasses the power limit and you can boost with expected frequencies and voltages.At your own risk of course...
Jaz11I've barely tried games yet. Just run benchmarks assuming they would push the card as hard as possible.But yeh haven't seen it over 400w
Jaz11Ahh I see. Don't know how I missed that. Hmmmm sounds pretty risky
EndworldWould be nice if EVGA just put out a properly fixed BIOS to deal with the issue.
ty_ger07EndworldWould be nice if EVGA just put out a properly fixed BIOS to deal with the issue.I don't think that it is possible. The power balancing is not directly controlled by the BIOS. The BIOS tells the voltage regulator what the limit is, but can't tell the voltage regulator how to do its job. If it is the voltage regulator's problem, the only way to allow PCI-E #3 to reach 150 watts is to allow PCI-E #1 and #2 to reach 200 watts (for example). If EVGA tried to release a BIOS with high limits which exceeded ATX specifications, 1) it would be liable for failures and fires, and 2) NVIDIA would probably never approve the BIOS in the first place.
donnie123ty_ger07EndworldWould be nice if EVGA just put out a properly fixed BIOS to deal with the issue.I don't think that it is possible. The power balancing is not directly controlled by the BIOS. The BIOS tells the voltage regulator what the limit is, but can't tell the voltage regulator how to do its job. If it is the voltage regulator's problem, the only way to allow PCI-E #3 to reach 150 watts is to allow PCI-E #1 and #2 to reach 200 watts (for example). If EVGA tried to release a BIOS with high limits which exceeded ATX specifications, 1) it would be liable for failures and fires, and 2) NVIDIA would probably never approve the BIOS in the first place.I don't know if you read, but lucky for us it seems it's not the lower quality voltage controller that's the issue, because it has now been discovered that the same issue of power balance happens on the 3090 Kingpin PCB also, which is top notch quality. SO, one of the forum members with a kingpin that was limited to 430w and had very weak plug 3, in the other thread, has discovered that if you use classified tool and raise the msvdd to 1.1v, this fixes the balancing issue and card then pulls full power. Seems this works also on other cards. In turn also Jacob announced on twitter there will be update on this issue in next few weeks. Judging by both news its indeed possible to fix.
Jaz11OP here. I'm still stick under 400w on the 450w bios. Still pcie3 not drawing more than 70w. More often than not I'm "power limited" at 350-380w I'm told...I haven't updated to the newer xoc bios with resizable bar update. Have you done that 1?
rjbarker^^^^ Is there anything further with this?I just installed an EK Block on my FTW3 Ultra and exact same issue as the OP!! Flashed to XOC BIOS - GPU-Z confirms 450w available.+160 Core / +725 Memory118% Power LimitGPU Voltage to Max (around 1.09v - 1.1v)Fairly steady Boost 2130 MhzRunning all kinds of Benchmarks but Power Draw never exceeds around 380w t0 390w !!!!PCI-E Slot around 45wPCI-E #1 & #2 get to around 148w - 155wPCI-E #3 is sadly never more than 1/2 the other 2 connectors, maybe 62w
jankersonJaz11I've barely tried games yet. Just run benchmarks assuming they would push the card as hard as possible.But yeh haven't seen it over 400wFlash it again.
Jaz11Just played some cyberpunk on new bios. No luck. Still didn't see power go over 390w. Clocks still the same etc. I'm getting maybe a few more fps from the resiable bar though so that's cool.If you go into the original xoc bios thread on the newest pages the manual bios install is linked there. I didnt use precisionYeh I feel like EVGA wouldn't even replace anyway. I don't think it's worth the effort to pull down loop. Reassemble cooler, send back, maybe get replacement, then build GPU block and loop again to maybe get the same thing.Plus how long will that take...I've just accepted it and looked on the bright side. I actually got a 3080 and before the price rises. Thankful for that.
