bmwm3smgWell, as far as I understand everything, I'd much rather have one of my GPU power cables pulling an extra 8 watts, as opposed to my PCIE slot overdrawing. At least this way if something fries, I think it will be limited to the 8-pin power cable and possibly the PSU, not the motherboard... I'm not sure if the GPU would be damaged if the 8-pin fried, anybody know?Thanks guys! :)
FeklarI don't get it. All these 3090 FTW3 card use identical design and components. Why is there such a difference in plug power usage between cards even when the power supply is not the issue. Bad design? Bad components?
mberohnGPU PCIe +3.3V Input Power (est) is also holding firm at 0.336W. Is this too low, or is the HWiNFO64 showing the decimal in the wrong place?
sparetimepcIt's been a known problem with this model card, most people are having the same issue.
Turbo-12RTo those who are having the issue, have you tried swapping the placement of the PSU cables to see if its always on #3?
ty_ger07 Yes, they have. The problem cards have the problem consistently until the card is either replaced or an unofficial BIOS is used. I understand blaming users and systems, but, no offense, too much blame is being put on users. I don't understand why users are being blamed when there is a mountain of evidence to the contrary.
Turbo-12Rty_ger07 Yes, they have. The problem cards have the problem consistently until the card is either replaced or an unofficial BIOS is used. I understand blaming users and systems, but, no offense, too much blame is being put on users. I don't understand why users are being blamed when there is a mountain of evidence to the contrary.Using the word "some" vs. "most" is not blaming. It's merely being factual. Not everyone has this issue.
ty_ger07 Read the part of your quote I was replying to. It's not a cable or power supply issue.
Turbo-12RYet mine and others work as intended.
Turbo-12RBecause I am not jumping on the "EVGA 3090's are a bunch of junk" bandwagon, somehow I am belittling people? Heh...quite the stretch there buddy. I think it's more inversely that you are getting irritated with me because I do not have any issues. I'm just here saying that not "ALL" of us are having these issues. Get it?
Turbo-12RI think it's more inversely that you are getting irritated with me because I do not have any issues.
Dabadger84*eats popcorn whilst enjoying a 3090 that knows how to power balance properly*
