- Ribbons : 270
Re: 3090 FTW3 Ultra Uneven Power Draw Across 8-pin cables?
2021/02/17 07:32:59
donnie123 Would you mind explaining where could I find some information about "BIOS" helping with the issue of plug 3 limitations?
Posted in a different similar thread: grabibus The only way is to flash with a 2x8 pin bios as the KFA2. 390W bios.
It bypasses the power limit and you can boost with expected frequencies and voltages.
At your own risk of course...
Since I don't own the card, obviously I can't validate that it works. That's just what has been reported. If the bios is able to fix this issues, why doesn't EVGA try to fix this with their own bios fix?
It doesn't really fix the issue. It just breaks power monitoring of PCI-E plug #3. It's hacky. BIOS is reviewed and authorized by NVIDIA. If EVGA wanted to release an official BIOS which breaks power monitoring of plug #3, I don't think that NVIDIA would ever approve.
moadib2k
2021/02/17 08:36:39
Another "me to" post. Power 1: 117 Power2: 130 Power 3: 34 GPU Load 100%. Power Consumption: 87% PerfCap Reason Pwr I am confused by the support response from earlier. Are they saying this is not an issue?
Video Card: 24G-P5-3987-KR - RTX 3090 FTW MB: ASUS Rog Crosshair Hero VIII Memory: 64GB Corsair Vengeance DDR4 3600 PSU: Corsair HX850
MDG73
2021/02/17 08:43:13
moadib2k Another "me to" post. Power 1: 117 Power2: 130 Power 3: 34 GPU Load 100%. Power Consumption: 87% PerfCap Reason Pwr I am confused by the support response from earlier. Are they saying this is not an issue?
That is what support basically told me with my 3070 FTW3. Which I almost do not believe or which is kooky considering I got my daughter a Asus Strix 3060Ti and has proper balancing between the two 8-pin power plugs. I don't understand why both wouldn't be used equally if other board manufacturers can do it, why can't EVGA?
9900k OC 5.0GHz Lian-Li Galahad 360 ASUS Z390-E Gaming MB Corsair Vengeance Pro 32Gb 3200MHz EVGA 3080 Ti FTW3 Ultra 12GB LG 34GP950G-B Monitor Samsung 500GB & 1TB 970 EVO Plus M.2 Drives Samsung 870 EVO 2TB SSD Team Group CX2 2TB SSD EVGA SuperNOVA 1300 P+, 80+ PLATINUM Corsair 5000D Airflow Affiliate Code: U6E1FWAKJI
moadib2k
2021/02/17 08:45:58
MDG73
If I am characterizing this correctly, my GPU is at 100% and so should be drawing full power. Also curious by GPUz would say there is a performance cap. I am a bit new to this so it could also be my understanding.
- Ribbons : 270
2021/02/17 08:53:35
Oof! That is absolutely terrible! I would RMA it. 100% If EVGA won't approve the RMA, fight them. Their warranty covers defects in design and manufacturing. If EVGA still refuses, you could try returning it to whomever you bought it from for a refund, or sell it to someone who doesn't care, and try buying another one and hoping for better luck.
donnie123
2021/02/17 13:34:04
I guess I'll live with my 430w power draw and 100w plug 3 limit :) It works pretty well in games anyway. Maybe EVGA will find a way to fix it in a bios update or something one day.
ClowReed
2021/02/17 16:20:10
bmwm3smg Any ideas on what is going on with the 8-Pin #3 Power draw on my new 3090 FTW3? These were the max numbers on my first Port Royal run on my card. Default settings (no OC), running the OC Bios (same results with the Normal Bios). Power Supply is a 1300 G2. Please let me know if I missed any pertinent info that you guys need.
Thanks! Lester
Man, sorry for crashing in... Maybe this is old news already, but after seeing your post I made some tests here with my 3090... In Furmark the 3rd 8 pin cable stayed at around 70W and total board power around 320... Cables 1 and 2 was getting 120W give or take. Ok... I installed OCCT and used their stability test for vga... well... now things got a lot more interesting... Total card power raised to spikes of 450W (I'm using the stock "OC Bios" switch) and all three 8 pin power were using full 150W. So... Maybe it's by design... The third one is the last one requested, just in case of extreme power usage. Just my 2 cents... Sorry if this was already mentioned. I hope it helps.
MDG73
2021/02/17 16:59:16
ClowReed
Thanks! Lester
Just tested your theory and I still get a discrepancy of 30 to 40w difference even in OCCT with Perfcap of PWR. Power draw on pin #1 12.0v on pin #2 11.9v. wonder why the dip on pin 2? Damn, I was hoping that was the case for me.
zeejay
2021/02/17 18:55:05
Add my 3090 FTW to the list. Getting about 140, 150, 75, Where's my other 75 watts evga? Card still runs ok but it could be better if the 3rd 8pin wasn't gimped. I wonder if this is even fixable without some sort of hacked bios or using a 2x8 pin as bios as a work around. Such a shame that they can't get it right.
- Ribbons : 270
2021/02/17 21:43:49
Hot take: If the power balancing works properly, it should be able to balance throughout the entire range of loads and applications. I realize that it doesn't really matter until you reach the max on any individual input, but it is silly if it can't power balance at lower loads either. Observing that it doesn't power balance properly in Furmark but can power balance properly in OCCT is kind of silly. This is just another indicator of power balancing which isn't effective. Like I say, I realize that it doesn't really matter until you reach a max where a power limit is being imposed, but, you see this is an indication of an implementation limitation.
donnie123
2021/02/17 23:20:53
It doesn't power balance correctly in OCCT either. Maybe the guy who mentioned it is just lucky and his works as intended but mine and several others can't push more then 98-100W on plug 3 no matter what's the test. My OCCT has it Slot 50W, Plug #1 135, Plug #2 157W Plug #3 98.6W resulting in 440w max. I've observed however the avg is above 400w, and during the test my card is fluctuation from 405-440 often.. (throttling most likely). There is a theory this was done in the newer rev. cards to help mitigate the issue of cards dying and crashing. To be honest it would be fair if EVGA at least gave out some statement? I know the card is able to push stock limits but many times we get Pwr capped even at 380+W if the damn rail overshoots the 150w mark..
liweichen6
2021/02/18 17:14:16
3090 KPE here, could this be the reason that I sometimes see power limit when the card is drawing only ~400W?
Bozhemoy
2021/02/19 06:38:42
Hi all, I've used nothing but Radeons in my past 10 builds so this is my first Nvidia card since like 2002 and my first EVGA card ever. I noticed that I was also experiencing the low power in pin 3 but pin 1 and 2 are also inconsistent. Figured I'd add my results to this thread (I'm not sure if this difference is detrimental to the card in anyway, it seems to run everything at 1440p just fine at stock). I've updated the XOC BIOS and had my OC set to +400 mem, +100 clock and 119% power. It seems like I'm capping out at 480W. Not sure if this is something that's RMA worthy. Here are my stats/results for Time Spy: Looks like it won't let me post an image but my PCI-E power maxed out as follows: P1: 149.821 P2: 168.906 P3: 93.283 With the above overclock I'm getting a 16065 score in Time Spy with a R5 3600, temps hovering around 68 degrees. GPU score alone is 20679. Since I'm not too used to Nvidia cards, does this seem par for the course?
donnie123
2021/02/19 13:35:24
I don't think they'll rma it for that. Yours doesn't look that bad. Has anybody tried with different PSU's and see if there's a difference?
- Ribbons : 270
2021/02/19 14:17:08
donnie123 Has anybody tried with different PSU's and see if there's a difference?
Yes, this has been tested using different PSUs, different cables, etcetera. Also, testing different cards, using the same PSU and same cables shows that cards behave differently; each card has its own behavior. This is page 3 of this thread. There are 2 pages before this one. The power balancing is on the card. If the card can't power balance effectively, there is nothing external to the card which can change that.
post edited by ty_ger07 - 2021/02/19 14:23:03
professordumbdumb
2021/02/19 15:46:28
This issue exists on the kpe 3090 as well - however we've managed to overcome the limit by increasing the msvdd with classified tool. This increases the internal clocks of the cache (as far as I know the higher voltage it runs increases the frequency with an internal v/f curve) which is finally able to feed the rendering pipeline with less latency per clock. With a low msvdd - the card even at 2200mhz will not post scores consistent with other brands of card, but increasing msvdd by a small amount (have to play with to find the right number for certain external gpu clocks) - results in substantial performance increases - and also solves the power balancing issue. Pre-msvdd tweaking - the card will run to the limit at 430w. After msvdd - 540w and massive increase in performance. I suspect that msvdd is power throttling the card far sooner than the global power limit would suggest.
donnie123
2021/02/19 16:34:00
That would explain why the power throttles sometimes happen at watts below the global power limit. But maybe the higher msvdd is not safe?
Kylearan
2021/02/19 21:12:58
Another issue on the non kingpin bios is the SRC Power limit linked to the 8 pin rail. While all of the 8 pins have a "global" power limit, which is only one value which is related to TDP (8 pin + PCIE Slot power limit= TDP), Each 8 pin has a "SRC" rail linked to it, which is usually 150W default, 175W max, and this limits the max 8 pin power draw (the 8 pin power limit doesn't, the SRC power limit for that rail does). So there are 3 SRC's for three 8 pin cards.
syu1087
2021/03/13 12:29:45
I also have this question but for a 3080, I'm currently using 3 separate pcie cables and undervolted which helped, but will get random black screens from using firefox or just having my computer idle showing the desktop. #1 shows around 65w #2 shows around 104w #3 shows around 21w psu is a seasonic priime px-850 Thanks
post edited by syu1087 - 2021/03/13 12:34:19
rjbarker
- Ribbons : 21
2021/04/03 17:54:33
Appreciate all the great info here guys (the ones that actually provided some info vs the "kids n trolls"! My 3080 FTW3 Ultra exact same thing with gimped power from PCI-E #3 plug. Power is about 1/2 from Plug #3 vs #1 & #2. With XOC 450w bios only can reaxh 395w! btw psu Corsair AX1600i.
Intoxicus
2021/04/29 08:49:48
Thanks! Lester
Are you using 3 separate power cables or are you using any of those splitters?
"Humans are not rational animals, humans are rationalizing animals." -Robert A Heinlein
funkdoobi
2021/05/08 15:30:55
add me to the list now of uneven power draw. I can't even play games now. I load COD and from the FPS capped selection screen the power draw goes stupid and my entire computer crashes. Now to RMA and remove my block and setup **** all over agian. FUN TIMES.
EK Velocity on 5900x / Crosshair VIII Hero Wifi / Optimus on FTW3 Ultra 3090 / Lian Li 011 XL / EK FLT360
mikev19
2021/05/08 15:40:51
I have been seeing more and more issues with the 3090 FTW3 cards, and for someone who has been trying to score one of these for months, I'm starting to wonder if I should consider a different card such as a 3070 or 3080 (the latter of which seems to be next to impossible to get).
mikev19
2021/05/08 15:43:17
Intoxicus Are you using 3 separate power cables or are you using any of those splitters?
I am curious about this as well. I've always heard that three separate power cables should be used and a splitter should never be used for these cards. And also have a power supply with enough connectors on it so that three separate cables could be connected without the need for a splitter.
funkdoobi
2021/05/08 15:46:33
mikev19 I have been seeing more and more issues with the 3090 FTW3 cards, and for someone who has been trying to score one of these for months, I'm starting to wonder if I should consider a different card such as a 3070 or 3080 (the latter of which seems to be next to impossible to get).
It was working perfectly fine before. Not sure what the hell happened now if I load anything that requires gpu power, it crashes basically.
Swash87
2021/07/25 07:02:29
So has anyone tried playing with the classified tool on the ftw3 3080 and 3090's too see what happens? (or is it locked to Kingpin cards only? Has anyone been able to get around that? I guess maybe on a 3090 you could flash the bios but not a 3080?) Clearly this is just another "issue" in a string of problems with these cards that just seem to be cost cut hard, for whats ment to be one of their top tier cards, they're not much better than a bottom end tier brand. As Buildzoid points out, it seems to just be a reference card overspec'ed in the wrong areas and woefully underspec'ed in others (like a good cooler, great power delivery but gimped by an cheaper caps and an analog voltage controller). Ughh, i know in gaming it probably only nets very little "gain" but it still miff's me that the card was sold with the PWR limit of 420w and mine, thats watercooled (after umming and ahhh'ing over the whole Bricking fiasco when you remove the cooler/fit a water block), running nice and cool and ready to overclock can't even hit that with the 450w bios (EXCEPT when it put under OCCT, where it'll draw 100w on that final plug #3 and hit 420w, in games you bet that im hitting the same values, sitting at 380w and gimped. Then you just know theres others who have no intention to OC or do anything other than plug it in and play (which is also perfectly fine) who probably have cards with no power issue) I'm very near just throwing caution to the wind and running the hacky bios to get full power (i mean you can always keep the OC bios from the switch on the eVGA bios and switch back if it fails....), hell if there was a decent hardware modification that'd fix this problem (such as maybe all these cards have a bad batch shunt resistors or something stupid that causes the voltage reg to read/report incorrectly?) that were removable (maybe hotglue shunt mod like Frame Chasers likes to do), i'd even consider that option Anyway, guess i'll put my name down as another Gimped 3080 FTW3 (Ultra.....) that probably won't get "fixed", just swept under the rug (i mean Jacob said stay tuned for news in a couple weeks on this issue....that was in February no?)....i wouldn't have been so worried about my card when waterblocking it if i had have known about this before....probably would have risked an EK block over a Bykski too, if it died its a decent reason to RMA it..... Only saving grace is i got this card as proper Australia MSRP ($1250 delivered) and not the $1750ish they're asking now (or higher for other brands), i guess now i know why it was so cheap?!?!?
post edited by Swash87 - 2021/07/25 07:04:10
ZachTullier2
2021/08/05 10:03:48
Add me to the list as well....
I recently purchased my 3090 FTW3 Ultra. Rev 1.0, black lips, 2114 serial #, Corsair RM850x power supply, 3 individual power cables, No daisy chains...
#1 126, #2 129, #3 82 PCIE power draw is around 56-70 relatively.
I have tried the normal bios and the OC bios switch to compare and the results resemble much of the same. #3 still lags behind.
Normal BIOS: 94.02.42.C0.05 OC BIOS: 94.02.42.C0.02
spider1701
2021/08/05 10:49:37
Prior anyone starts claiming it is faulty product keep in mind cart itself was designed as 350W. Now we are getting it unlocked to 450W normal and 500W OC. There was never any statement that those cards will reach 500W. Mine usually ranges from 485W to 510W during heavy bench on OC but I usually run it on default on 450W vBIOS on standard 420W target.
artjsalina5
2022/06/03 09:34:15
Any update ever come out of this?
Apaul82
2022/06/03 21:50:04
Nothing has been said by EVGA yet about the power balancing. Terrible so many have this same issue.
