Zange
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up
2018/11/07 12:34:35
Are you saying that the batch file part of the flashing didn't work? for me it only works when I shut down most of the taskbar hidden icon apps, run the batch file as administrator and manually uninstall both precision XOC and X1 and physically deleted the folders from program files. I haven't installed precision X1 yet , XOC will do for now, as I'm just happy to have the fans and LEDs at default settings for now and I wouldn't mind X1 coming out of beta first.
Correct, im not sure if the problem does lie with PX1 itself or its a hardware issue as the problem occurs on initial boot and stays that way until rebooted. None the less im sure EVGA is working on getting a solution out and figure out the cause. I just dont think we as the consumer should be having to do all these updates and flashes for something that was meant to come with very little issues.
Andrew_K
2018/11/07 12:37:09
Update on my two fan issue - forcing the MCU update did end up making 3 fans show up in X1 now, but precision crashes every time I try to go to the fan speed page. I've uninstalled and reinstalled (with deleting the evga folder) and it still crashes every time.
division
2018/11/07 12:38:33
Well at least things got better. Slapped in my old 1080 ti and it triggered the Nvidia drives and control panel, worked fine. Swapped the good FTW3 back in and it worked. But still problems with the card that showed the initial issue. The "working" card I was able to update the hex file. The card with the 3 lights and fan issues, still showing device not supported. Precision X1 still won't update it, flash tool won't work. About to try the 3.5.3 beta. If that doesn't work, time for an RMA.
CPU: Intel Core i9-7940X @ 4.0ghz boost Memory: 32gb DDR4 3600MHz - Corsair Vengance RGB Pro MB: EVGA x299 DARK Video: 2x EVGA 2080 Ti FTW3 in NVLink
division
2018/11/07 12:45:26
No dice on the PX1 update. Still the same issue. Is the E202 firmware update still the current one?
badboy64
2018/11/07 12:45:49
The latest beta works for and it patched the my card also plus I can adjust the the fans without crashing.
14th Intel® Core™ i9 14900KF CPU 3.2GHz@6.0ghz, Memory 2x24GB GSkill Trident Z Trident Z5 7200 mhz DDR5 Ram,4,000 GB MSI M480 PRO 4TB , Motherboard eVga 690 Dark , Operating System Windows 11 Pro 64-Bit, Msi Suprim X24G 4090, Monitor Acer CG437K, Logitech G910, Razer Lancehead Tournament Edition, Thermaltake View 91 RGB plus, eVga 1600w P2 PSU, Custom watercooling. Speed Way Score 11,055 points. https://www.3dmark.com/sw/1112818
division
2018/11/07 12:51:05
Wow, new PX1 3.5.3 crashes when you try to go to the fan speed temp adjustments. What a joke.
badboy64
2018/11/07 13:22:19
division Wow, new PX1 3.5.3 crashes when you try to go to the fan speed temp adjustments. What a joke.
Mine doesn't crash.
- Ribbons : 123
2018/11/07 13:43:10
Make sure you do a "clean install" - by removing any leftovers after uninstalling X1, - turn all Software off while installing (including Security Software.. go offline first) Make sure Fast Startup is turned Off in Windows 10
division
2018/11/07 13:56:08
I put in for an RMA. Tried everything suggested by support and the forums, no dice.
division
2018/11/07 14:00:16
lol, busy signal contacting customer service to finalize the RMA. That's not a good sign.
EVGA_JacobF
- Ribbons : 26
2018/11/07 15:24:38
☄ Helpfulby Cool GTX 2018/11/18 13:31:37
- Ribbons : 282
2018/11/07 15:30:04
@ EVGA_JacobF, Would it also help to delete this Folder C:\Users\UserName\AppData\Local\ PX18
Zange
2018/11/08 08:16:58
Is there a way to confirm if this is a hardware issue or a software issue?
Andrew_K
2018/11/08 08:24:15
Zange Is there a way to confirm if this is a hardware issue or a software issue?
I'd love to know that also. I've had numerous issues with my FTW3 that I didn't experience with an XC Ultra in the same system. I know PX1 is still broken, but the fact that I can't complete a timespy run of any kind is sort of concerning, among other things.
d.burnette
- Ribbons : 17
2018/11/08 08:27:22
Andrew_K
EVGA_JacobF For those experiencing the issue where sometimes only 2 fans are showing, please try this PX1 version: https://www.evga.com/EVGA/GeneralDownloading.aspx?file=EVGA_Precision_X1_0.3.5.3_BETA.exe
Tried this and other troubleshooting advice and it's still only showing two fans.
Did you try a power flush? Shut down system. Unplug power supply Hold power button in on computer for 30 seconds. Power system back up and see if you get your third fan back. It did this to me several days ago and the above got it back for me. Have not had the issue since.
Don EVGA Z390 Dark MB | i9 9900k CPU @ 5.2 GHz all cores | EVGA RTX 3090 FTW3 Ultra | 32 GB G Skill Trident Z 3200 MHz CL14 DDR4 Ram | Corsair H150i Pro Cooler | EVGA T2 Titanium 1000w Power Supply | Samsung 970 Pro 1TB m.2 Nvme | Samsung 970 Evo 1TB m.2 Nvme | Samsung 860 Evo 1TB SATA SSD | EVGA DG 87 Case |
aldur80
2018/11/08 10:11:10
I had this issue recently. To fix it click the Default button and then the custom fan curve page shows up.
lezus123
2018/11/16 11:18:43
Hello, I have the same issue.
1.- I installed the 2080ti FTW3 card and turned on computer
2.- Fans dont move
3.- I installed EVGA Precision X1 beta
4.- The three red LEDS appeared and the fans are running now 100%
Please help
post edited by lezus123 - 2018/11/16 12:32:31
i9 9900K @ 5.1 GHzAsus Maximus Hero XIHOF Hall Of Fame 16GB (2x8GB) @ 4000 MhzEVGA GeForce RTX 2080 Ti FTW3 ULTRA GAMINGAsus Xonar Essence STX IILepa G1000M
lezus123
2018/11/16 12:33:24
I followed these steps for FIX the FTW3 2080ti fan 100% and red led thing: FAQ ID # 59742 But when i run the batch file, it says “this device is not supported!”
post edited by lezus123 - 2018/11/16 12:48:01
ehysell
2018/11/16 14:42:21
lezus123 I followed these steps for FIX the FTW3 2080ti fan 100% and red led thing: FAQ ID # 59742 But when i run the batch file, it says “this device is not supported!”
I get the same thing. My card was working fine since I have had it, until I installed the X1 software. It said it was updating the ICX firmware, it failed and now I have the same as others, 2 fans showing, no LEDs, and the 3 red lights by the power plug. This is regardless of either bios I run on my 2080TI FTW3. I tried playing a game with the OSD on, and it showed me only getting 41 FPS. I am now wondering if this software has broken my card. I as others have stated get an error saying device not supported if I try to run the E202 firmware update.
lezus123
2018/11/16 14:52:34
My card works ehysell
I don't think the card is broken. I tried hitman 2 at 4k and had more than 100 fps with nice temps. I think the problem is the software that dont let us control the fans and the leds :(
DisplacerGoat
2018/11/16 17:40:02
ehysell
Same here...
Intel i7-8700K @ 5.2 Ghz Asus ROG Maximus X Apex EVGA 2080 TI FTW3 2x 16 GB G. Skill F4-3000C14 2x Samsung 960 Pro 1 TB m.2 EVGA Supernova 1300 G2
lezus123
2018/11/17 04:24:18
Got a mail from EVGA support and said me to Follow these steps to fix the fan 100% red led issue: - Shut down your PC
- Switch the BIOS to SLAVE on your card
- Turn your PC back on and run the 2080Ti_FTW3_E202 / flashtool
- Once it finishes updating then shut down and change the BIOS back to MASTER then test
It didn't work. Still says “this device is not supported!”
lezus123
2018/11/17 09:17:45
You can see in this video my problem:
ehysell
2018/11/17 09:29:56
lezus123 Got a mail from EVGA support and said me to Follow these steps to fix the fan 100% red led issue:
- Shut down your PC
Yeah I was hoping swapping the bios would work as well, except I started the other way. I was already on OC, and tried going back to Normal and the issue is across both bios.
jinihammerer
- Ribbons : 8
2018/11/18 03:18:16
lezus123 You can see in this video my problem:
I had this happen to me and it was my own fault. It can happen when applying the X1 LED flash, especially with the older X1 versions. What happened on mine was I was not paying attention, and after it succeeded I pressed the flash again and it failed. It left the card in the same state as yours. The fix was to use the MCU updater https://www.evga.com/supp...mmain.aspx?faqid=59742Start by uninstalling x1 then reboot. Make sure to start with a 100% fresh boot. Power down, pull the plug and press the power button to drain the power from the caps. Reboot and kill any auto start apps to make sure nothing messes with the flash. Apply the MCU. Reinstall the latest Verizon of X1 That fixed it for me.
My Affiliate Code: EB1-UCY-VA9N
lezus123
2018/11/18 03:23:50
jinihammerer
I did all those steps. But when I try to apply the MCU (2080Ti_FTW3_E202) it says: "This device is not supported!"
jinihammerer
- Ribbons : 8
2018/11/18 03:41:33
The batch file needs to be run as administrator and since it is a batch file I extracted all the files into a folder on the root of C:
Don't know that it had an effect but it's worth a shot.
The other thing I did was used a local administrator account rather than a Microsoft linked account.
lezus123
2018/11/18 03:49:10
jinihammerer The batch file needs to be run as administrator and since it is a batch file I extracted all the files into a folder on the root of C:
I just tried it. It does not work. :(
jinihammerer
- Ribbons : 8
2018/11/18 03:54:00
Sorry. Am just tossing out my scenario and how I got it to work.
Wish it would have worked for you as well
lezus123
2018/11/18 04:04:17
jinihammerer Sorry. Am just tossing out my scenario and how I got it to work.
I'm waiting for EVGA to send me a file that can fix that. Meanwhile, all help is welcome. Thank you!
