PhunkSession
So randomly last night the led on the slide for the gpu went out. After 30 mins messing with it, comes back on. I launch P1 to change the color, after 5 mins with the new color selected it turns back off. Anyone have this issue before and have a fix for it? Breathing and Pulse can't be selected also.
PhunkSession
Re: 2070 ULTRA XC, led lights went out
2019/12/31 10:44:01
- Ribbons : 123
2019/12/31 10:47:25
Have you tried rebooting the PC Tried different Colors ? Is Windows 10 Fast Startup OFF ?
PhunkSession
2019/12/31 10:51:16
Cool GTX Have you tried rebooting the PC Tried different Colors ? Is Windows 10 Fast Startup OFF ?
Have you tried rebooting the PC - Yes Tried different Colors ? - Yes Is Windows 10 Fast Startup OFF ? Fast boot is enable...
- Ribbons : 123
2019/12/31 11:01:19
PhunkSession
2019/12/31 11:08:21
Cool GTX Was asking if a True Cold Boot was happening "Windows 10 Fast Startup OFF" Kill Fast Startup if it is On .... Windows Central - Fast Boot is before the OS ... should not be an issue .... unless you added New Hardware or Firmware I'm still not sure if it is hardware or software:
I did just add 1tb ssd on sunday. Ill try killing the fast boot this evening after work and report back. Thanks for replying, much appreciated!!
- Ribbons : 123
2019/12/31 11:12:09
Happy to Help
Maybe other Forum Members have something to share on this issue Give an update when you can.
GTXJackBauer
- Ribbons : 48
2019/12/31 11:12:40
Also check and make sure the cable isn't loose on the side of the GPU.
PhunkSession
2019/12/31 11:13:23
Cool GTX Happy to Help
Will do, thanks!
PhunkSession
2019/12/31 11:15:13
GTXJackBauer Also check and make sure the cable isn't loose on the side of the GPU.
So there is a cable for the lights? I was wondering this, easy to access? I'll check this evening and also report back.
post edited by PhunkSession - 2019/12/31 11:19:31
PhunkSession
2020/01/03 15:33:24
Update, i disabled fast boot on my mobo and it fixed the lighting issue.
- Ribbons : 123
2020/01/04 09:17:39
PhunkSession Update, i disabled fast boot on my mobo and it fixed the lighting issue.
that is good news
PhunkSession
2020/01/04 09:36:15
that is good news
Thanks for your help, happy i didn't have RMA it. Have a great weekend!
- Ribbons : 123
2020/01/06 20:43:29
Happy I could Help
