alexquiet
Hello everyone, lastly I have a problem my graphics card does not have the same performance as before, and I just found the problem, it only consumes 180w instead of 270w I have a gtx 1080 ti, the problem can come from the power supply ???
Re: problem with EVGA Supernova 850 G2L, 80 Plus GOLD
2019/03/20 10:06:24
Welcome to the EVGA Forums, congrats on your First Post The Power (Watts) consumed by the GPU will change as the load (software) demand changes PC Specs ? What are you running when observing the 180W ? Is Nvidia Control Panel set for Performance & is Windows set to Performance ?
alexquiet
2019/03/20 10:21:53
hello thanks for your answer and take the time for my problem yes Nvidia panel set performance and power supplz mode on windows set hight, I get 180w when I play video games like metro exodus or black ops 4 and apex, which is very little for a gtx 1080 ti
2019/03/20 10:41:57
What resolution is Your Monitor ? Game setting to Max ? Is your CPU overheating ? Room Temp ? GPU temp ?
alexquiet
2019/03/20 11:33:45
What resolution is Your Monitor ? 2k 1440p Game setting to Max ? yes Is your CPU overheating ? no Room Temp ? 50° GPU temp ? 60°
2019/03/20 13:34:24
So the issue occurred after swapping in the new 850w G2L?
- Ribbons : 115
2019/03/20 18:09:57
alexquiet
2019/03/20 18:26:00
no it's been 1 years that I am with this power supply all work well, but now I do not know why it gives not enough power
alexquiet
2019/03/20 18:27:05
XrayMan I did not understand, what did you mean
2019/03/21 02:50:41
What clocks are gpu running at when you notice the low draw?
alexquiet
2019/03/21 03:06:22
the GPU runs at 100% in 1987 mhz constant, but the problem seems not to come from the power supply, because when I try Heaven Bench, my graphics card consumes between 230-260w so the power works well, I think rather that the problem comes from windows optimization or motherboard
