Hot!pinout for 850 gt power supply
cmil6199
2024/08/01 13:51:04 (permalink)
I have an 850 gt power supply that is missing the 18+10 to 24 pin cable.
I need to build a compatible cable, but the supernova pinouts that I have found do not appear to be correct for the 850 gt.
Thanks,
Chris
1 Reply Related Threads
    • Ribbons : 123
    Re: pinout for 850 gt power supply 2024/08/03 11:06:50 (permalink)
    The GT line does have a different 24 pin MB cable
    Contact EVGA
    Support@EVGA.com
    Maybe they can sell you a new cable or provide the needed information?
    Another option, would be to buy a new cable designed for your PSU, from a third party custom cable company
    Share an update, once you get something
