so i have a clc 240 and what i want is to use it for VGA with nzxt g12 . the problem is i couldnt take the intel mount bracket off. i tried to follow the instruction in "press/push down and turn the bracket counter clock wise" but it is too tight, not as easy as nzxt x62 i also have.
plz advise...what should i do..
