evga supernova g2 1300 watt, need help with setting up cables.
nickdino
2014/04/05 10:38:31 (permalink)
hi, i have received 2 supernova g2's, 5 sapphire 280x vapor tri-x's an asrock h81 pro btc mobo, 5 (powered) usb risers, and the rest.
evga.com/Products/Product.aspx?pn=120-G2-1300-XR
sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1227&pid=2131&psn=&lid=1&leg=0
asrock.com/mb/Intel/H81%20Pro%20BTC/index.nl.asp
I'm thinking of using one supernova for three 280x's and the other for two 280x's and the mobo with everything attached. This system is for mining and i want to set it up for optimal mining performance, the vapor tri-x has two 8 pin slot, will i get better performance if i use 2x 8 pin than 1x 8 pin and 6 pin?
Between the supernova's, the mobo and the gpu's, i don't know which cables go where. I don't want to mess this up, please help me out, sharing any part that you are certain of will help.
post edited by nickdino - 2014/04/05 10:50:51
3 Replies Related Threads
    HayzBaby
    Re: evga supernova g2 1300 watt, need help with setting up cables. 2014/04/05 14:48:00 (permalink)
    Most power supplies are labeled now so the cables can be even for the load on the specific rails. But just match up the ports for what you need. Easy
    LFaWolf
    Re: evga supernova g2 1300 watt, need help with setting up cables. 2014/04/16 22:00:29 (permalink)
    Your video card requires 2 8pin PCIe power input, the SuperNova 1300 G2 comes with 6 8pin PCIe power input, so you can power 3 video cards with 1 G2.
    The best thing to do to calculate your power requirement, is try this website -
    http://www.extreme.outervision.com/psucalculatorlite.jsp
    Do not plug the 6pin PSU power into the 8pin slot for the video card.
    Gomez99
    • Ribbons : 14
    Re: evga supernova g2 1300 watt, need help with setting up cables. 2014/04/17 09:41:07 (permalink)
    HayzBaby
    The evga 1300g2 is a single rail design so load doesn't need to be balanced across rails
