A few more details on the SR-X thanks to some fine details on the photos that have been released:
We already know the PCIe setup is as follows:
[x16/x8, x8, x16/x8, x8]=connected via x16 lane using a PLX PEX 8747 PCIe 3.0 switch (
http://www.plxtech.com/pr.ucts/expresslane/pex8747 ), x16/x8, x4, x8
Another x4 lane connects to the South Bridge for SAS support, using all 40 lanes from the primary CPU.
Now looking at the pictures, I have a better idea what chips are connected to the South Bridge:
Ethernet Controllers: 2x Intel 82574L Gigabit Ethernet Controllers
http://ark.intel.com/prod...it-Ethernet-Controller Reasoning: We know that the board uses Gigabit Ethernet. Looking at pictures of the board, you will find 2 Intel Gigabit Ethernet controllers, both of which are connected via 64-pins. Looking at Intel's site, there are only three Single Gigabit Ethernet Controllers that interface via PCIe that use a 64-pin design: 82574IT, 82583V, and 82574L. 82574IT is the industrial version of the 82574L, so that can't be it. The 82583V is not a product I normally find in dual Intel Gigabit motherboards, the 82574L is, leading me to think the 82574L is used. In addition, the 82574L supports Jumbo Frames, something a highend motherboard like SR-X would probably support.
eSATA controller: 1x Marvell 88SE9220
http://www.marvell.com/st...92xx-Product-Brief.pdf Reasoning: This one was easy. Looking at the board, you will find a Marvell chip right behind the eSATA ports. The fact that it is a Marvell chip is easily identified by the logo. Looking closely, you will notice that the chip uses only 56 pins. Luckily, only one of Marvell's SATA controllers uses 56-pins, the 88SE9220. One thing to note about this controller is the ability to connect it via x1 or x2 PCIe 2.0 connection. Most likely EVGA used a x2 connection considering that they have an abundance of PCIe 2.0 connections on this motherboard. There simply would be no reason not to. This would guarantee 500MB/s speeds on both those eSATA ports if both are being equally maxed.
Back Panel USB 3.0 Controller: 2x ASMedia ASM1042
http://www.asmedia.com.tw...=100&cate_index=98 Reasoning: After examining the photos for a little bit, I spotted the ASMedia logo (first looked like a C-Media logo which would be impossible because the board already uses Realtek for an audio codec). The controller is located in between the 2 Intel Ethernet controllers, just behind the USB 3.0 ports. I couldn't find much information on the controller, but I think it only supports 2 ports. I was able to find the second chip below the secondary processor's DIMMs.
Onboard USB 3.0 Controller: 1x ASMedia ASM1042
http://www.asmedia.com.tw...=100&cate_index=98 Reasoning: There are no good photos of the onboard USB 3.0 controller chip on the SR-X, but the logo looked similar to the back panel chip and there is no reason to use different controllers.
Onboard Firewire Controller: 1x TI XIO2213B
http://www.ti.com/product/xio2213b Reasoning: Again, the photos of the bottom of the board are not that great, but this is what I have. The logo on the controller appears to be a TI logo. I cannot spot a PCI bridge on the motherboard, indicating that the Firewire controller should be able to connect via a PCIe interface. TI makes 2 Firewire Controllers that connect via PCIe, the XIO2213B and the XIO2200A. According to the X79 Classified manual, 1394b is optional, indicating that the controller used on that motherboard is one that supports 1394b. The XIO2200A only supports 1394a, leaving only the XIO2213B to be used on the X79 Classified. I assume the chip used on the X79 Classified will be the same one used on the SR-X.
Audio Codec: Realtek ALC898
Reasoning: The audio codec is definitely Realtek, supports 8-channel audio, and uses a 48-pin connection. That really doesn't limit the options. I say it probably is the ALC898 since that is what the X79 Classified uses.
In short, I currently count the use of all 8 out of the 8 available PCIe 2.0 links from the South Bridge. (x2 for the dual Gigabit, x2 for the eSATA, x2 for the 4 external USB 3.0 ports, x1 for the 2 internal USB 3.0 ports, and x1 for the internal Firewire.) Of course, I could be wrong on a few of the chips. Whoever gets this board should be able to verify which chips are used. As a note of reference, I used the Photosynth photos of the board located here:
http://photosynth.net/vie...4f50-ae10-a25d35d33d73 I also used Jacob's leaked photo of the SR-X on Twitter located here:
http://twitpic.com/73bm7z
post edited by Aggressor Prime - 2012/02/29 00:57:25
