Hot!eVGA SR-X (SR-3)
Page: << < ..67 Showing page 7 of 7
Post
mvidart2401
Re: eVGA SR-X (SR-3) 2024/03/06 18:54:08
Halibut King
Some good news, I re-seated the CPU, took out the 2 RAM sticks with issues and blew 2 DIMM-slots clean with my mouth for good luck, and guess what, all DIMMs works :D
I believe it was the CPU, because I tried re-seating the RAM many times before and already cleaned the DIMM slots out, but who knows ;)
congratulations !! good news !!
Re: eVGA SR-X (SR-3) 2024/03/06 23:44:11
Halibut King
Good to hear. Glad this is working.
Halibut King
Re: eVGA SR-X (SR-3) 2024/03/08 02:46:01
mvidart2401
Halibut King
Ty.
For some reason I cannot send PM's yet. But I will notify you, dont worry =)
Only waiting for a SSD, scooped a 8tb used for cheap so now that is solved too. Was hoping to be able to boot directly from NVME and nothing more, but that failed. Then its time to crunch some numbers.
Also I see no reason why 96gb should be max with ECC ram as in specs? will try with 16gb sticks later this weekend or maybe I wait until SSD comes around Tuesday.
Have other boards such as x99 chipset say they support X-amount, but that is always more with ECC ram.
Really love the feature where u can disable DIMM and PCIE slots with manual switches too. This is a really fun board to tinker and build with. Lots of possibilities. The only negative part I can think of is how 1 CPU controls all PCIE lanes and you cannot get x16 speed on more than 2 slots. Not end of the world because I will use 3060, but if you are on multiple 3090 GPUS u probably get skimped some.
//Halibut King
post edited by Halibut King - 2024/03/08 02:47:21
bertanari
Re: eVGA SR-X (SR-3) 2024/03/09 20:17:42
Howdy all, has anyone here have an old version of the SR-3 bios? I am trying to make the board working with ES chips. For some reason w3175x is still expensive and it seems like this is the only board that doesn't work with ES chips due to BIOS lock.
mvidart2401
Re: eVGA SR-X (SR-3) 2024/03/10 07:00:51
bertanari
BIOS 1.06
https://cdn.evga.com/BIOS/W999/W999_flashtool_106.zip
BIOS 1.05
https://cdn.evga.com/BIOS/W999/W999_flashtool_105.zip
Re: eVGA SR-X (SR-3) 2024/04/08 08:14:05
Halibut King
Ty.
Your post count had not reached the minimum to send PM; you should be good to go with 11 posts to your account Now
Halibut King
Re: eVGA SR-X (SR-3) 2024/04/08 13:50:03
Halibut King
Ty.
Awesome, I have read the rules.
Thank you. Pm seems to work now =)
