Hot!eVGA SR-X (SR-3)
Page: < 12345.. > >> Showing page 4 of 7
Post
Cyras
Re:eVGA SR-3 2012/02/06 04:45:23
XEON E5-2600 Series doesn't have BCLK strap, it only can set bclk=100 strap!
So we need to wait for the Ivy Bridge-E or a Extreme Model!
post edited by Cyras - 2012/02/06 05:56:21
debs3759
Re:eVGA SR-3 2012/02/06 09:26:02
Did you read that somewhere official, or is it based on someone's results using an ES chip? I don't think EVGA would be investing a lot of money in an overclocking board if the chips can't be overclocked, it wouldn't make good business sense.
Cyras
Re:eVGA SR-3 2012/02/06 09:45:15
It comes directly from ASrock, we had tried to overclock several Xeon E5 Series, about the Strap.
First try 6 Core Xeon:
h10.abload.de/img/x79extreme9withxeonljox0. jpg
Second try 8 Core:
Fail
E5-Serie release saved.im/mtg2odyzetkw/xeonpreise. jpg
Why?:
Anscheinend hat der Xeon der E5-2600 Serie keine "paths"/profiles im PCH um verschiedene Multiplikatoren einzusetzen. Das PCH definiert nämlich welche Tacktung-SRC, was steuert. Dieses läuft dann über das ICC.
Leider scheint es so als würde das ICC die Ausgabe verweigern oder keine Daten beinhalten, die das Motherboard abrufen kann.
post edited by Cyras - 2012/02/06 09:48:22
fugatron78
Re:eVGA SR-3 2012/02/06 12:04:19
Hello all,
the photo on start of page is a final product or just "pre-final" stage of board - need a LOT of ram and the Single thread performance - (the Multi too but with conjunction with xGPUs )  so need a  lot of RAM slots - at least 256 GB (16x16 GB modules )
Brocasta
Re:eVGA SR-3 2012/02/06 13:08:31
It's not going to have 16 slots.
pyrebuilder
Re:eVGA SR-3 2012/02/06 17:51:59
Even Jacob has said it'll have 16 slots, any source or reason why you say that it wont?
edit- misread, im entirely on too many drugs for my broken arm, my brain read 12 slots.
post edited by pyrebuilder - 2012/02/06 18:22:55
EVGA_JacobF
Re:eVGA SR-3 2012/02/06 18:20:53
Sorry, what is meant by 16 slots?? If memory slots you can see from the various pictures posted that it has 12 slots for memory.
pyrebuilder
Re:eVGA SR-3 2012/02/06 18:23:17
sorry edited my post
Brocasta
Re:eVGA SR-3 2012/02/06 20:04:08
Now we just need a launch date.
Brad_Hawthorne
Re:eVGA SR-3 2012/02/06 20:22:30
I see no reason why not to call it unofficially as the SR-3. Technically speaking the E762 was the SR-1.
Brocasta
Re:eVGA SR-3 2012/02/06 21:25:28
Brad_Hawthorne
If it were meant to be the SR-1, they would have called it that.
The SR-X would have to have 3 sockets in order to be called the SR-3, technically.
Brad_Hawthorne
Re:eVGA SR-3 2012/02/06 21:35:07
Brocasta
Brad_Hawthorne
So, by your logic an SR-X has 10 sockets?
Brocasta
Re:eVGA SR-3 2012/02/06 21:39:56
Only if they had called the SR-2 the SR-II instead...
I had this exact same argument on OCN a while back. That's weird.
Brad_Hawthorne
Re:eVGA SR-3 2012/02/06 21:42:59
Brocasta
Reiterating opinion does not make an opinion any more or less valid. Especially with something as unofficial as a nickname.
Gratuitous
Re:eVGA SR-3 2012/02/06 22:46:59
Brad_Hawthorne
Brocasta
Brad_Hawthorne
what? I think i missed something. where did this random argument come from?lol
Brad_Hawthorne
Re:eVGA SR-3 2012/02/06 23:24:01
Gratuitous
Brad_Hawthorne
Brocasta
Brad_Hawthorne
It's the internet. It's not supposed to make sense.
chillernr1
Re:eVGA SR-3 2012/02/07 03:20:55
Cyras
Second try 8 Core:
Fail
Why?:
you're pics are not working, like to see them
Cyras
Re:eVGA SR-3 2012/02/07 04:01:20
Delete the Space between " . and jpg, than it should work. Or look here
Here you see a Xeon LGA 2011 with a Strap / 1.25.
and here a 8 Core Xeon, but without any Profiles in the PCH for the ICC.
Price in Euro (first release):
post edited by Cyras - 2012/02/07 04:23:01
sweetalice79
Re:eVGA SR-3 2012/02/07 07:48:07
im looking at geting a srx simply becase the stuff i do.  i use a lot programs that are cpu intisive.  for media encoding and such.  the srx also looks like it has 2 sas conectors for 8 sata iii drives.  plus 2 onboard sata iii so 10 sata iii drives and 4 sata ii devices.  but being evga  will allow me gaming with a good gpu like the 580 clasified air cooled and still alow me plenty room for something like the zonar zense, Hauppauge's Colossus, & Hauppauge's WinTV-HVR-2250.  so im building it as a hybrid gaming/encoding/storage system.  my question is has anyone found any kinds of specks on it as of yet???
chillernr1
Re:eVGA SR-3 2012/02/07 07:48:48
it still need to be released
sweetalice79
Re:eVGA SR-3 2012/02/07 07:53:41
well thnking for what i do it would be good im afrade howmuch cpus will cost me though.
sweetalice79
Re:eVGA SR-3 2012/02/07 10:24:56
would the SR-X witha good gpu like the 580 clasified air cooled and still alow me plenty room for something like the zonar zense, Hauppauge's Colossus, & Hauppauge's WinTV-HVR-2250. alow me good work to do encoding with storage and decent gaming or would u all recommend a regular 3gb 580 or the new gen 3 gpu when it releases as well?
Edit: i wonder if the SR-X can use dual EVGA Superclock CPU Coolers
post edited by sweetalice79 - 2012/02/07 10:28:47
slash-2cpu
Re:eVGA SR-3 2012/02/07 10:53:34
Cyras
That 6-core CPU-Z shot is an Engineering Sample i7 3960X. Multipliers, cache sizes, core count all match the 3960X. It could also be an E5-1660, which is not a 2-way capable part.
Every E5-2600 I've had my hands on(4 of them) is locked multi, locked strap. Depending on the board, most refuse to boot when you enter strap or multi higher than the locked maximum. That HWiNFO screenshot is very typical of Engineering Sample Xeons. 106 MHz BCLK and turbo multi's. 107 MHz BCLK rarely works, and it's almost never stable for long periods.
Question remains, what CPU's will this board support? i7 = No multi-socket. Xeon = Locked.
Brocasta
Re:eVGA SR-3 2012/02/07 11:27:15
Not exactly; the ES Xeons are locked. Unless you have your paws on retail/OEM samples? Not sure if I've seen any of those tested.
That said, I'm interested to to see how this pans out. Hopefully the 2650/2660 range will OC at least a little bit.
lehpron
Regular Guy
Re:eVGA SR-3 2012/02/07 11:48:32
Attempting to give hope to those of you fearful of an expensive SNB dual-socket setup:
FWIW, best I can tell based on a combination of CPU specs and rumored prices, the E5-2600's doesn't entirely succeed the Xeon 5600's, at least not all of them.  It looks like the higher end of the 5600's are being replaced by E5-2600 (thus higher average prices), but the lower-end is being replaced by E5-2400 (thus lower average prices) using LGA1356 and it appears later in the year.
LGA1356 parts still have up to 8-cores up to 2.4GHz; except you get triple-channel DDR3, 24 lanes of PCIe 3.0 each and no overclocking; unless EVGA makes a junior SR-X or SR-L for light.  Even if a vendor did make an overclockable version that barely reaches the speeds of stock E5-2600's, at least it is a cheaper route than going for the E5-2600's.
You just have to wait another 6-8 months for it.
sweetalice79
It has been brought up in the seven pages of this thread, not like you're the only one asking, just start digging-- or look here or here.
The board will debut officially around when the CPU's debut, which will be next month.  Intel has been pretty consistent, their Xeon 5600, 5500 and 5400 have all debuted the month of March.
post edited by lehpron - 2012/02/07 12:00:44
slash-2cpu
Re:eVGA SR-3 2012/02/07 12:10:11
I haven't seen or heard of OEM/retail parts yet. Everything thus far has been ES, and all fully locked.
I hope the vanilla E5 Xeons allow BCLK strap changes. That was the beauty of the SR-2 was you could buy a pair of sub-$1000 chips and really get something out of them.
Requiring an Extreme Xeon would be unattractive.
darkagentj007
Re:eVGA SR-3 2012/02/07 12:13:05
newegg just Deactivated the SR-2..cant wait for the SR-X
nikkocortez
Re:eVGA SR-3 2012/02/07 14:35:52
NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Brocasta
Re:eVGA SR-3 2012/02/07 15:07:05
darkagentj007
It begins.
linuxrouter
Re:eVGA SR-3 2012/02/07 17:52:02
debs3759
If the retail chip ends up being BCLK locked, the only thing I can think of is waiting for an unlocked multiplier or at least partially unlocked Xeon from Intel. I would not hold my breath on that at least not right away. Intel makes the most money off selling these processors to businesses that need them and buy them in large quantity such as businesses with data centers not off the relatively few enthusiasts that buy these processors for overclocking.
Brocasta
Re:eVGA SR-3 2012/02/07 18:19:44
In that same vein, intel sells so many CPUs to non-enthusiasts that it doesn't make much sense to put out the effort to neuter them just so we can't overclock them.
Cyras
Re:eVGA SR-3 2012/02/08 06:14:38
The "CPU Strap" Profiles are locked, but you can help us, to show us why!
Please download HwInfo32 v3.92, Build 1520 (Added support of Intel Integrated Clock Control (ICC): reporting of clock capabilities and monitoring of actual status.) AND show us the ICC Profiles from your E5 ES Sample.
 Mainboard -> Intel ME -> Intel ICC (Intel HECI/ME Driver must be installed)
rhussain
Re:eVGA SR-3 2012/02/09 08:18:10
I like this board a lot but when will there be news about a possible release date?
debs3759
Re:eVGA SR-3 2012/02/09 20:23:45
slash-2cpu
Cyras
Check the codename. It's a Sandy Bridge-EP/EX, which means it has to be either an E5-1660 or an E5-2600 that hasn't been announced :)
Brocasta
Re:eVGA SR-3 2012/02/09 21:13:40
More than likely, that's an E5-1660.
Brocasta
Re:eVGA SR-X (SR-3) 2012/02/10 12:20:43
Nice. Pair a couple of those up with one of these:
http://www.macmall.com/p/...no~8955462~pdp.gjicaec
HDTVdevil
Re:eVGA SR-X (SR-3) 2012/02/12 02:44:18
I have these available for use in a new system: G.Skill RipjawsZ F3-10666CL9Q2-64GBZL (8Gx8)
any chance they would be supported?
H.D
post edited by HDTVdevil - 2012/02/13 08:32:39
Brocasta
Re:eVGA SR-X (SR-3) 2012/02/13 13:17:24
linuxguy
Re:eVGA SR-X (SR-3) 2012/02/13 13:48:30
Nice looking board.  It looks a lot more modern than the SR-2
gatecrasher
Re:eVGA SR-X (SR-3) 2012/02/13 14:00:33
Hot diggity darn, that is what I will be getting
lehpron
Regular Guy
Re:eVGA SR-3 2012/02/13 14:53:31
debs3759
The i7-3800 and i7-3900 have the same -EP/-EX subcodename because they use the LGA2011 socket.  The only other subcodename is -EN, but that's for LGA1356.
pyrebuilder
Re:eVGA SR-3 2012/02/14 10:07:07
the only thing i wish they had was the 90 degree power connector
trevormacro
Re:eVGA SR-3 2012/02/14 10:10:52
Amazing Motherboard :)
lollygag
Re:eVGA SR-3 2012/02/14 10:16:26
pyrebuilder
 Normally I'd say that would be bad for a board this size that already is challenging to fit in a case.. but it has the SAS connectors right angled anyways.
Brocasta
Re:eVGA SR-3 2012/02/14 10:18:44
I have never seen vertical SAS connectors unless they are attached to a vertical PCB. The cable coming out of the SAS port is more flexible than the garden hose that is the 24 pin loom.
Gratuitous
Re:eVGA SR-3 2012/02/14 10:27:32
pyrebuilder
yah, I am sure because of the width of this board they decided to keep vertical to save that inch or so. might make a big diferance for some cases to fit or not.
chillernr1
Re:eVGA SR-X (SR-3) 2012/02/14 11:58:46
matt.hobson
because it's newer maybe ? :p
EVGA_JacobF
Re:eVGA SR-3 2012/02/14 13:37:36
lollygag
pyrebuilder
Yup, but using the SAS connectors are optional in a way... 24pin is mandatory. Plus the SAS connectors are a bit more flexible. Right angled 24pin would extend the PCB about 1-2 more inches out.
pyrebuilder
Re:eVGA SR-3 2012/02/15 12:09:53
EVGA_JacobF
lollygag
pyrebuilder
makes sense
Brocasta
Re:eVGA SR-3 2012/02/23 23:27:38
The Asus dual LGA 2011 board is up for pre order:
http://ncix.com/products/...S&manufacture=ASUS
Your move, EVGA. Let's do this.
linuxguy
Re:eVGA SR-3 2012/02/24 08:32:01
Brocasta
Hmm, can't seem to find any info on this?  Anyone seen any specs?  Other than the generic specs in the product title.  Overclockable?  Or just a WS board?
Edit:  Answered my own question: http://www.techpowerup.com/158373/ASUS-Dual-Socket-LGA2011-Motherboard-Pictured.html.  Seems like it is a WS only board, but still worth taking a look at.
post edited by matt.hobson - 2012/02/24 08:40:23
Sleinous
Re:eVGA SR-X (SR-3) 2012/02/25 11:13:38
fugatron78
see guys what i found
http://www.lambda-tek.com/BX80621E52620-Intel-2-30GHZ-E5-2620-XEON-PROCESSOR-6-CORE~cs/B838087&origin=skinflint10.9
This has me interested especially as they are quite cheap. Tray price is meant to be $406. Usually the conversion itno GBP/EUR is 1:1 :/
However I thought the E5 2620 was meant to be a 2.0Ghz chip?
pazza3169
Re:eVGA SR-X (SR-3) 2012/02/26 03:12:52
If you check XS news section you will find the ASUS board has many overclocking features within the bios. Including multiplier and BLK strap adjustment. But NO cpu so far supports them!!!
This link explains abit more:
http://vr-zone.com/articles/asus-z9p...ard/14894.html
Brocasta
Re:eVGA SR-X (SR-3) 2012/02/26 11:28:00
We're like a week and a half away from the launch of the CPUs. Everybody, please keep your pants on until the afterparty.
Sleinous
Re:eVGA SR-X (SR-3) 2012/02/27 05:39:09
I have this information for you all:
I have contacted the distributor of the item and they have advised me that this item is currently available. They also added:
"They are boxed processors and the description for it is 2.30GHZ E5-2620 XEON PROCESSOR 6 CORE"
I am afraid this is all the information we were provided with ourselves.
I hope this helps!
Kind regards,
Lambda-Tek Sales Team
So maybe the E5-2620 is indeed a 2.30Ghz chip & the release specs we have seen so far are wrong? (E.g. not 2.0Ghz for the E5-2620).
post edited by Sleinous - 2012/02/27 12:10:53
beaker7
Re:eVGA SR-X (SR-3) 2012/02/27 11:44:03
Brocasta
You guys are wearing pants?
Brocasta
Re:eVGA SR-X (SR-3) 2012/02/27 12:17:58
beaker7
Brocasta
I'm wearing those break-away pants that chippendale dancers wear.
Gratuitous
Re:eVGA SR-X (SR-3) 2012/02/27 12:22:35
Brocasta
beaker7
Brocasta
wow this is to much information! I am sure glad you guys don't have live webcams! (typing this while sitting in boxers before getting ready for work) lol
lollygag
Re:eVGA SR-X (SR-3) 2012/02/27 12:39:06
Im picturing the release date coming,  Brocasta's pants flying off as he starts into the gyro grind..
