AnsweredZ390 and iCue won't display motherboard sensor info.
newfiend
2019/12/31 07:16:27 (permalink)
Anyone know why corsair's iCUE software wont display any sensor information from the z390 Dark or have a fix?
thanks,
newfiend
kelkel1
Re: Z390 and iCue won't display motherboard sensor info. 2019/12/31 09:33:53 (permalink)
Because it is iCUE?
Z390 DARK, 9900K, 2080 FTW3 ULTRA, GSKILL 4500, 960EVO M.2
https://valid.x86.fr/52sqs5
  • Ribbons : 123
Re: Z390 and iCue won't display motherboard sensor info. 2019/12/31 10:12:42 (permalink)
your running the latest version of iCue ?
Is Windows 10 Fast Startup OFF ?
You read through the Corsair iCue forums
https://forum.corsair.com...forumdisplay.php?f=280
HE4THEN
Re: Z390 and iCue won't display motherboard sensor info. 2019/12/31 10:19:59 (permalink)
Just installed iCue (for testing) to see if it's maybe an issue with your system config but it is same for me. No Z390 Dark readings.
https://forum.corsair.com/v3/showthread.php?t=188485
EVGA Z390 DARK / i9 9900KS / EVGA 2080 Ti FTW3 Ultra
Ballistix 2x8GB 4000MHz / EVGA CLC 280 / EVGA DG-86
Re: Z390 and iCue won't display motherboard sensor info. 2019/12/31 11:39:37 (permalink)
Sounds like you need hwinfo.
newfiend
Re: Z390 and iCue won't display motherboard sensor info. 2019/12/31 11:53:33 (permalink)
I have the latest version installed yes. Everything else is working fine just no information from the z390 sensors in iCUE. It seems others with z390 boards also are having the same problem. iCUE uses the CPUID SDK so it's not just me with the problem. So who to contact  CPUID, Corsair or both?
newfiend~
d.burnette
  • Ribbons : 17
Re: Z390 and iCue won't display motherboard sensor info. 2019/12/31 17:18:37 (permalink)
I use the Icue software as I have an H150i Pro, I thought it was just for monitoring the cooler and controlling the lighting and fans along with any other Corsair peripherals?
Don
EVGA Z390 Dark MB | i9 9900k CPU @ 5.2 GHz all cores | EVGA RTX 3090 FTW3 Ultra | 32 GB G Skill Trident Z 3200 MHz CL14 DDR4 Ram | Corsair H150i Pro Cooler | EVGA T2 Titanium 1000w Power Supply | Samsung 970 Pro 1TB m.2 Nvme | Samsung 970 Evo 1TB m.2 Nvme | Samsung 860 Evo 1TB SATA SSD | EVGA DG 87 Case |
bob16314
  • Ribbons : 761
Re: Z390 and iCue won't display motherboard sensor info. 2019/12/31 17:54:26 (permalink) ☼ Best Answerby newfiend 2020/01/01 10:36:06
d.burnette
I have tried iCUE too with my H80i but it also reports my (Z370) mobo sensor info..I think maybe it's probably not quite compatible with the Z390 yet..Word is that there's a new version coming out soon, stay tuned.
Corsair iCUE Software Forum
newfiend
Re: Z390 and iCue won't display motherboard sensor info. 2020/01/01 10:34:38 (permalink)
d.burnette
It is, however you can setup the dashboard in iCUE to display all kinds of information. Except motherboard info for some reason is not working.
