Will my power supply cut for SLI? GTX 570 SC
redfield0009
Tuesday, February 22, 2011 3:03 AM (permalink)
Hey guys, wondering if my power supply will cut it for SLI. I got one GTX 570 SC and would like to get another. I have a kingwin 1000w power supply. So far frame rates in heaven have been great and I have been able to play all my games at the highest settings and they run as smooth as butter. Vantage scored P24K which is higher than my previous 260 SLI set up. I'd really like to try two of these cards and see how far I can push my system.
System specs are
790i Ultra
q9400 OC'd to 3.8ghz
GTX 570 SC
GTX 260 core 216 for PHYSX
2G of Patriot Viper 2000
KIngwin 1000w PSU
Raven 2
13 Replies Related Threads
    71stpsde
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 3:13 AM (permalink)
    Your good. Two 570's can run on 750 watts. Once you start overclocking, then you'll want 850 watts. So your 1000 watts is more than enough.
    redfield0009
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 3:16 AM (permalink)
    Sweet! I guess I'll be grabbing another this Friday!
    logan801
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 3:33 AM (permalink)
    See this thread
    Alucard666
    • Ribbons : 12
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 5:27 AM (permalink)
    71stpsde
    Really think so? he also has a 260 he has for phsyX. I'd say you're cutting it close there bud, get a AX1200 and don't look back
    AMD Ryzen 7 3700x | 32GB Crucial Ballistix PRO RGB 3600mhz| ASUS RTX 3080 TUF OC | ASUS X570i STRIX | 2TB Sabrent Rockit M.2 SSD| NZXT H1 w Ghost Sheets Mesh Front | Noctua 140mm & 2 40mm | Samsung Odyssey G7 32" | Logitech G Pro Wireless | Logitech G915 | SteelSeries Arctis Pro Wireless | Logitech G560 RGB Speakers |
    HosakaBlood
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 5:40 AM (permalink)
    Your PSU is OK
    NZXT Noctis 450
    Mice Logitech G700 KB Corsair k70 RGB
    Core i7 4790k @4.8Ghz Cooler Corsair H110i GT
    MSi Z97 Gaming 7
    16GB KingStoneHyperX Beast 2400MHZ
    256GB SSD OCZ Vertex 4
    512GB Samsung OEM SSD
    2x500GB SeaGate 7200Rpm
    THermaltake grand power 750w 80G
    2x EVGA GTX 1070 FE
    dukenuke88
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 5:49 AM (permalink)
    do you plan to use the 260 for physx along with your two 570s?
    redfield0009
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 5:52 AM (permalink)
    I was going to drop the 260 once I went SLI. From what I gathered it could act as a bottleneck and the two 570's should be able to do the physX just fine.
    • Ribbons : 135
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 6:21 AM (permalink)
    redfield0009
    Nope. In titles such as Mafia II or Batman AA for example, you'll see about a 20% or better increase in frame rates using the 260 as a dedicated PhysX GPU. In games that don't use GPU PhysX, it will sit there idle and not do anything. In either case, unless you were doing some ridiculous overclocks on your CPU and GPU your PSU is fine.
    RBIEZE
    • Ribbons : 12
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 6:42 AM (permalink)
    Irs rated at 80 amps total combined on the 12v rail(s) so you should be fine.
    just make sure to put 1 -570 on rail #4 and the other on #5
    Look at the spec plate in this link to see what im saying...
    http://www.newegg.com/Pro...ector%20Power%20Supply
    They say opposites attract. I hope you meet someone who is good-looking, intelligent, and cultured.
    http://www.youtube.com/watch?v=W2WsPN-rr9o
    Evga X58 4Way sli,W'Cooled i7 950 @3.8, Mushkin redline mem @6-7-6-18 1600Mhz,
    2-Evga GTX770 Sli, Evga Gtx460 Physx, Corsair Neutron 120GB SSD,Samsung 240SSD, W.D Black 640GB /Corsair TX950 Psu, Hanns-G 28" Lcd, Logitech G540 5.1 Surround
    My Affiliate Code: EECLVEDV7Z
    photopro818
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 7:12 AM (permalink)
    You are fine I was ruining 2 580s over clocked and a gtx 285 on a 1000w PSU
    EVGA X58 Classified 760
    Intel I7 950 (Oc 4.0GHZ)
    EVGA GTX 580 FTW SLI
    EVGA GTX 285
    Corsair Dominator 12gb
    OCZ Vertex 2 120gb x2 RAID 0
    Corsair 800D
    Cooler master 1000w PSU
    redfield0009
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 12:53 AM (permalink)
    RBIEZE
    Well I'm glad to know I can run all 3 cards on this power supply, but how would I know what power cables are attached to what rail?
    mwparrish
    • Ribbons : 23
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 1:00 PM (permalink)
    redfield0009
    RBIEZE
    You're fine at 2x 570s. If you run 2x 570s + 1x 260 (which I recommend for Mafia II, for example), then you'll be loading the PSU to about 93-94% of it's capacity before any OC is factored in.
    I strongly recommend an AX1200 if you're going to run all three cards. For just 2x 570s, your 1000W is fine.
    2x EVGA GTX 780 Ti SC  |  BenQ XL2420TX - 1920x1080 120Hz LCD  |  Logitech G9x  |  Corsair Vengeance 1500
    5x Crucial 128GB SSD  |  LG BD-R Drive  |  Danger Den Torture Rack  |  Enermax Galaxy EVO 1250W
    redfield0009
    Re:Will my power supply cut for SLI? GTX 570 SC Tuesday, February 22, 2011 1:05 PM (permalink)
    Damn, just got this PSU in December too, lol. Well I guess I'll just stick with either 2 570's and save up to upgrade the PSU...and by save up I mean wait two weeks, lol.
    Guess once I have enough posts I'll just sell the kingwin in the marketplace.
    Thanks for all the help guys.
