Where is the Guide for 90-degree Hard Acrylic Tubing between CPU block/chipset/Vreg
movieman
2014/07/21 13:25:45 (permalink)
I have been searching and I cannot find a guide to show me what to buy and how to put together this setup. I have found videos, but they do not say what to buy and where to get it. Please help. My concern is what exactly to buy. With multiple blocks on the mobo an different heights, i would have to get extenders. In the videos I saw, there were different extenders used to get the height equal. However, do the heights have to be exact?? In the pic below the person is using different 90 degree fittings...Why?
Anyway, I am just looking for a how to guide to learn more about this setup.
thank you, :)
I am trying to figure which way I want to go.
Either something like this
or....
this, which I am pretty confident I can do.
post edited by movieman - 2014/07/21 13:40:15
NZXT B550   AMD 5950X
EVGA 3080Ti Hydrocopper
WD Black 2TB NVME
Corsair 64GB (4 x 16GB)
Alienware AW3418DW 34" UW
Corsair HX 850          Corsair 5000X(white)
Windows 10               HEATWARE
6 Replies Related Threads
    • Ribbons : 282
    Re: Where is the Guide for 90-degree Hard Acrylic Tubing between CPU block/chipset/Vreg 2014/07/21 20:01:56 (permalink)
    I would rather have the water flow into the CPU first then the rest.
    movieman
    Re: Where is the Guide for 90-degree Hard Acrylic Tubing between CPU block/chipset/Vreg 2014/07/21 20:17:32 (permalink)
    I agree. I just found the above pics to show the types of tubing configurations I was interested in.
    NZXT B550   AMD 5950X
    WD Black 2TB NVME
    Windows 10               HEATWARE
    Speedrookie
    Re: Where is the Guide for 90-degree Hard Acrylic Tubing between CPU block/chipset/Vreg 2014/07/23 21:47:02 (permalink)
    Use EK Cooling Configulator to find out what water blocks you need and just browse through FrozenCPU.com and go to water cooling and take a look around and search up things you want to know.
    CPU: Intel® Core i7-6700K OC @4.6GHz
    GPU: EVGA GeForce GTX 1070 SC
    RAM: 16GB G.Skill TridentZ @ 3600MHz CAS 16
    SSD: Samsung 850 Pro 240GB
    HDD: Seagate 2TB 7200 RPM SSHD
    Headset: Astro A40
    Mouse: Logitech G502 Spectrum RGB
    Keyboard: Corsair K70 Cherry MX Red
    • Ribbons : 270
    Re: Where is the Guide for 90-degree Hard Acrylic Tubing between CPU block/chipset/Vreg 2014/07/24 13:52:47 (permalink)
    A guide. Others are on YouTube.
    http://www.overclock.net/...crylic-pipebending-101
    Did you ever bend acrylic sheets in shop class in highschool to make picture frames and stuff? Same concept. Heat it up and bend it over a form and leave it there until it cools.
    movieman
    Re: Where is the Guide for 90-degree Hard Acrylic Tubing between CPU block/chipset/Vreg 2014/07/24 14:48:55 (permalink)
    thank you for your response. I see how my OP might have not been as clear as it should have been.
    In the first pic. The person is using 90 degree fittings to go from block to block. However, if you look they are different. One of them has a logo on it, the other does not. I don't know why they are different?
    Also, there are different heights associated with each block (RAM blocks vs CPU block vs VRM block). I have looked all over frozencpu.com for extenders to create a straight and level shot from one 90 degree fitting to the next. Unfortunately, I have not found anything. Is it even possible to get a exact level straight shot for each tube. If not, how much "play" does one have between each block?
    Using many 90 degree fittings can cost a bit, so before I buy, I want to make sure that I buy the right ones. I just like the look of the 90 fittings on the blocks that are very close together and I think it will be a better overall look.  For the longer runs between rads/pumps/res's I will just use the regular tubes and bend them accordingly.
    Thanks for the links/help :)
    NZXT B550   AMD 5950X
    WD Black 2TB NVME
    Windows 10               HEATWARE
    movieman
    Re: Where is the Guide for 90-degree Hard Acrylic Tubing between CPU block/chipset/Vreg 2014/07/24 19:16:13 (permalink)
    I found what I was looking for. I came across this and it help me locate the parts.
    NZXT B550   AMD 5950X
    WD Black 2TB NVME
    Windows 10               HEATWARE
