talon951
Re: When will EVGA sell replacement Thermal Pad kits?
2022/01/02 08:35:45
Actually the 2mm Gelid Ultimates work really well on the hybrid at least. I did put paste on them. Although at this point I would try the Kritical 20 W/mk pads.
Intoxicus
2022/01/03 10:04:29
"Humans are not rational animals, humans are rationalizing animals." -Robert A Heinlein
redteamgo
2022/01/03 11:51:09
transdogmifier Put a replacement kit in with they hybrid kits "just in case" or accept RMAs without the pads/putty being replaced. End of story.
couldnt have said it better. Cheers all.
CPU: Intel 12900K EK 1700 Quantum Mag AcetelGPU: EVGA 3090 KPHCMB: EVGA Z690 DarkPSU: EVGA SuperNOVA 1600 P+Memory: G.SKILL Z5 6600mhz XMP3NVME: Samsung 980 Pro Gen 4 1TB, Gen 3 970 1TBCooling: MO-RA3 420 P/P 8x200mm Noctua HS PWM, Dual D5Case: Fractal Design Define 7 MOD Rigs!!!
Kingofroam
2022/01/03 12:41:10
redteamgo
Yeah, I personally don't understand why EVGA promotes modifying cards. If you need to RMA it you need to put oem pads and putty. I don't claim to know a lot on pads and putty, but does it matter? You'd be able to tell if improper pad/paste replacement cause card failure right?
24G-P5-3998-KR 05/24/2021 3:46:31 PM PT Yes Passed 12G-P5-3969-KR 06/03/2021 9:05:24 AM PT Yes Bought CASE: Phanteks Eclipse p600s | COOL: NZXT Kraken x72, ftw3 hybrid kit CPU: Ryzen 5600x | GPU: EVGA 3080ti FTW3 Hydro Copper PSU: Corsair RM850x | MOBO: Asus Prime x470-pro Don't use my associate code.
arthurz21
2022/01/19 16:39:22
Not sure if anyone mentioned before, EVGA does allow orders for stock thermal pads. I called their tech support today and they told me they do sell but it is kind of special order. I tried to order one today but they told me it is out of stock now...
staypuft
- Ribbons : 31
2022/01/20 13:10:19
arthurz21 Not sure if anyone mentioned before, EVGA does allow orders for stock thermal pads. I called their tech support today and they told me they do sell but it is kind of special order. I tried to order one today but they told me it is out of stock now...
Yep, I bought a few kits last fall. They are not complete if you intend to replace ALL pads. 1) No pads are included for the backplate, 2) No pads are included for areas where putty is used (at least for my 3070Ti XC3 GPU VRM chokes), More info here.
Interested in a discount on EVGA products? Click here for details and enter this Associates code at checkout >> 2ILPLQQ8IWY8DPN 2021 Build: Gigabyte Z590 Ultra | Core i7-10700K | be quiet! Dark Rock Pro 4 | 32GB G.Skill Trident Z DDR4-3200 EVGA RTX 3080 FTW3 Ultra | Samsung 970 EVO 500GB | Seasonic Focus GX-850 | Fractal Design Meshify C | Asus TUF VG27AQL1A
arthurz21
2022/01/20 17:47:52
staypuft
Yep, I bought a few kits last fall. They are not complete if you intend to replace ALL pads. 1) No pads are included for the backplate, 2) No pads are included for areas where putty is used (at least for my 3070Ti XC3 GPU VRM chokes), More info .
How long did it take for them to arrive after u order and how much does one set cost if u don't mind me asking?
acupalypse
2022/01/20 19:06:26
talon951 So do 2mm pads not work in place of the 2.25mm stock pad? Has that been proven?
The (better) aftermarket ones are stiffer, so in theory, 2mm should be the right replacement for 2.25 - IMO. And I'm gonna try it out.
arthurz21
2022/01/20 19:17:06
acupalypse
I think 2mm probably will be better too. I tried 2.5mm on all locations that were supposed to be 2.25mm just today, specifically the gelid ones. My chip cannot even touch the copper plate after fighting the x thingy on PCB.
acupalypse
2022/01/20 19:19:28
arthurz21
acupalypse
I honestly tried 2.5 on 2.25, with pads a bit softer than Gelid. They're fine but GPU temps were 8-10 C higher than normal hybrid because the chip wasn't touching the base plate close enough. Still lower than air-cooled though.
staypuft
- Ribbons : 31
2022/01/20 19:28:57
arthurz21
staypuft
Maybe a week. $10 per kit.
arthurz21
2022/01/20 22:16:13
acupalypse
arthurz21
acupalypse
What pads did u try with? Gelid is just so stiff for me, and when I compress it, it becomes kinda brittle and easy to break apart.
arthurz21
2022/01/20 22:18:52
staypuft
arthurz21
staypuft
Hopefully, they will have stock again sometime soon. Thanks for the info!
nomoss
- Ribbons : 7
2022/01/20 22:27:47
First thing I did was replace the backplate pads. Didn't keep the OG. Oops
rsclfans
2022/01/21 10:39:54
https:// kriticalpads .com/Custom-GPU-sets_c_11.html
Asus ROG Strix X570-E GAMING WIFI II AMD Ryzen 7 5800X G.Skill 32GB (2x16GB) DDR4 3600MHz CL17 be quiet! Silent Loop 2 360mm (3x Noctua NF-A12x25 Chromax) EVGA RTX 3080 XC3 Ultra Gaming Samsung 980 Pro M.2 1TB + Samsung 860 Pro 2TB be quiet! Straight Power 11 850w 80+ Platinium be quiet! Silent Base 802 Black
Intoxicus
2022/02/08 08:00:53
That is new.
bzabrown419
2022/02/09 07:10:39
arthurz21
2022/03/21 20:31:10
Just to let everyone know that EVGA has thermal pads back in stock again. The limit (at least for my 3080 ftw3 LHR) is three sets. I ordered two sets about 2 weeks ago.
bzabrown419
2022/03/22 06:35:19
arthurz21 Just to let everyone know that EVGA has thermal pads back in stock again. The limit (at least for my 3080 ftw3 LHR) is three sets. I ordered two sets about 2 weeks ago.
Hey Arthur do you have a link for these thermal pads or is it something I have to call customer support to order? Any help appreciated. Thanks.
arthurz21
2022/03/22 09:26:03
bzabrown419
Hey, just send a service ticket to evga and they will make the payment available on your account page.
Hoggle
2022/03/22 11:05:34
It's a pretty good idea to have the thermal pads for sale since I could see a lot of people wanting them and even if someone owns another brand of card I could see them rather get a thermal pad from a company that makes video card over someone unknown to them.
bzabrown419
2022/03/23 03:45:07
Thanks Arthur. I will definitely do that. I appreciate the info. Take care.
NecroRAM
2022/05/08 10:57:21
Hoggle It's a pretty good idea to have the thermal pads for sale since I could see a lot of people wanting them and even if someone owns another brand of card I could see them rather get a thermal pad from a company that makes video card over someone unknown to them.
I dont think think they make them, probably subcontracted from somewhere in China lol.
nhannguyen1
2022/10/14 01:23:46
Guys. Sorry to bother. But is anyone have the size of thermal pads for FTW3 3090 Ti Ultra.
lastsamurairick
- Ribbons : 6
2022/10/14 05:33:41
Yea it be great EVGA sold the pads themself it would money saving and time saving.
Intel 10900k @ 3.7 Stock EVGA Z490 Dark EVGA GEFORCE RTX 3070Ti FTW3 G SKILL TRIDENT Z ROYAL 32GB EVGA 1000G5
