What is the max 3080 FTW3 power draw
Zorgis
Thursday, September 10, 2020 10:07 PM (permalink)
Do you have any idea how much power the 3080 ftw will draw (once oc)?
I have a 9900k and a 750w seasonic platinum. I'm a bit worry it won't be enough once fully overclock, the 9900k draw 220w under prime95 (I know it's not real workload but I take that as the max it could draw by accident for a second).
83 Replies Related Threads
    • Ribbons : 123
    Re: What is the max 3080 FTW3 power draw Thursday, September 10, 2020 10:13 PM (permalink)
    Until EVGA lifts the curtain on their new 30 series cards
    my best guess 350W
    Nvidia recommends the 750W PSU for both their 3080 & 3090
    Zorgis
    Re: What is the max 3080 FTW3 power draw Thursday, September 10, 2020 10:16 PM (permalink)
    The 3080 FTW3 has 3x8pin, it won't be higher?
    kevinc313
    • Ribbons : 22
    Re: What is the max 3080 FTW3 power draw Thursday, September 10, 2020 10:20 PM (permalink)
    Zorgis
    I've got a 338w bios and was actually just playing around with running prime95 and Unigine Heaven at the same time the other day, had to cut the Prime down to like 5 or 6 threads to get Heaven to run at full GPU power, so the CPU was at about 150w and the GPU was peaking up to 340w.  This is on a 650w gold EVGA PSU.
    Even if the 3080 FTW3 bios is 40% over reference as it was with Turing, so 450w on the 3080 FTW3, I'm pretty sure you'll be OK with any real world loads with the 750w.  Might want to run low lag vsync or set appropriate power limit when gaming though, just for the long term health of the gpu.
    post edited by kevinc313 - Thursday, September 10, 2020 10:28 PM
    • Ribbons : 123
    Re: What is the max 3080 FTW3 power draw Thursday, September 10, 2020 10:29 PM (permalink)
    Zorgis
    Newegg has some (Specs) information up on their site
    EVGA GeForce RTX 3080 FTW3 ULTRA GAMING Video Card, 10G-P5-3897-KR
     EVGA GeForce RTX 3080 FTW3 GAMING Video Card, 10G-P5-3895-KR
      (excerpt)
    System Requirements750W or greater power supply.
    PCI Express, PCI Express 2.0, PCI Express 3.0, or PCI Express 4.0 compliant motherboard with one graphics slot.
    jsteedman
    Re: What is the max 3080 FTW3 power draw Thursday, September 10, 2020 10:51 PM (permalink)
    Zorgis
    Yes it should be over 375 for 3x8 pins so my guess is 3080 is at least 400.
    kcthebrewer
    Re: What is the max 3080 FTW3 power draw Thursday, September 10, 2020 11:30 PM (permalink)
    jsteedman
    Zorgis
    Each 8 pin officially supports 150 watts
    With the PCIe slot (75 watts) -- these cards should support 525 watts
    8 pins can support much higher but not officially so it can likely pull more.
    I really wish they would have just used the new NVIDIA 12 pin which is about the size of 1 8 pin and officially supports up to 600 watts
    jsteedman
    Re: What is the max 3080 FTW3 power draw Friday, September 11, 2020 0:53 PM (permalink)
    kcthebrewer
    I agree it would have been nicer, especially oriented the normal way and not the nvidia way. For the higher wattage cards though it might have been too soon to support or worry about having to do customer support on such a thing.  I doubt that the chip itself can handle 525watts max power into the card at least on air, but it would be awesome if they did.
    vulcan1978
    Re: What is the max 3080 FTW3 power draw Friday, September 11, 2020 1:54 AM (permalink)
    kcthebrewer
    jsteedman
    Zorgis
    I could be mistaken but it actually does NOT support 600w. It technically, officially supports 300w. Just like 2x8 pin it can draw much more than that but it's not rated for 600w.
    8700k @ 5.1 GHz - 0 AVX @ 1.386v Dynamic Offset w/ EK Monoblock + Delid | Gigabyte Z370 Aorus Gaming 7 | EVGA 2080 Ti XC2 Ultra @ 2130 Mhz core, 7950 MHz memory @ 1.063v w/ 375W FTW3 vbios + Phanteks Glacier Block  | EK CE 420 + EK XE 360 | 2x16GB G-Skill Trident Z Royal 3600 MHz 17-20-20-38 | 2 TB Sabrent Rocket | Corsair RM1000x | Thermaltake View 71 | Alienware AW3418DW + Asus ROG Swift PG278Q (for 3D Vision) on Amazon Basics Arms | Win10 Pro 1809
    philosophersbunker.blogspot.com
    jsteedman
    Re: What is the max 3080 FTW3 power draw Friday, September 11, 2020 1:34 PM (permalink)
    vulcan1978
    This might be true, i think the 600w figure came from a review that it could in theory if gauged properly be up to 600watts, but I haven't seen anything official eitherway other than seasonic saying it should be used by a 850watt powersupply, which would indicate theirs is rated for more than 300watts. Also the pins are kind of small.  It certainly can be fed 600 watts by most powersupplies in a 2x8pin, but hopefully we never end up with 675watt GPUS to every need something like that anyway.
    kevinc313
    • Ribbons : 22
    Re: What is the max 3080 FTW3 power draw Friday, September 11, 2020 5:46 PM (permalink)
    Bear_drinks_cider
    Re: What is the max 3080 FTW3 power draw Sunday, September 13, 2020 12:12 AM (permalink)
    I'll have a 3080 FTW please, I'll swap my beloved 1080ti KiNGPiN for it
    have a good 1      cheers
    rjbarker
    • Ribbons : 21
    Re: What is the max 3080 FTW3 power draw Sunday, September 13, 2020 9:04 PM (permalink)
    kevinc313
    Zorgis
    Running an OC'd 9900K power draw obviously depends on vcore and load .......for example all 8c/16t oc'd to say 5.1Ghz w 1.325v under full P95 w AVX enable can draw up to 375w CPU alone.....if your playing around with higher vcore say up to 1.4v the load will go up exponentially....also bear in mind the ideal load on your PSU is to stay in that 65% efficiency peak (in the curve)......also quieter......with all that being said you wil never fully load your CPU and GPU simultaneously (even running most benchmarks).......
    I9 12900K EK Velocity2 / ROG Z690 Apex/ 32G Dominator DDR5 6000/ Evga RTX 3080Ti FTW3  EK Vector / 980 Pro 512G / 980 Pro 1TB/ Samsung 860 Pro 500G/ WD 4TB Red / AX 1600i /  Corsair 900D & XSPC 480 * 360 * 240 Rads   XSPC Photon 170 Rez-Vario Pump Combo - Alienware 3440*1440p 120Hz/ W11
    Zorgis
    Re: What is the max 3080 FTW3 power draw Sunday, September 13, 2020 10:00 PM (permalink)
    Yes, I think I will go with the FE and won't overclock.
    Sixie
    Re: What is the max 3080 FTW3 power draw Saturday, September 19, 2020 12:03 AM (permalink)
    Zorgis
    Maybe this answers the question?
    https://twitter.com/TechNoodleTV/status/1306756154496700416
    420W
    Zorgis
    Re: What is the max 3080 FTW3 power draw Saturday, September 19, 2020 12:22 AM (permalink)
    I already received my 3080 FE but thank you for the information.
    It's a really good gpu.
    axtoxic
    Re: What is the max 3080 FTW3 power draw Thursday, September 24, 2020 2:27 PM (permalink)
    420W for FTW3
    aj_hix36
    Re: What is the max 3080 FTW3 power draw Thursday, September 24, 2020 10:25 PM (permalink)
    420w for 3080 FTW3
    440w for 3090 FTW3
    R3L3NTL3SS
    Re: What is the max 3080 FTW3 power draw Thursday, September 24, 2020 11:21 PM (permalink)
    Is there any software that can monitor the wattage draw at least semi accurately?
    Aurummorituri
    Re: What is the max 3080 FTW3 power draw Thursday, September 24, 2020 11:58 PM (permalink)
    440W seems to be it. The founders somehow can do 400W despite basically using two 8-pins merged into that new connector. That's really fudging spec for a standard BIOS, but the card really needs it. Asus Strix card is also 400W and they want as much as the FTW3 for it! Lame.
    Poss273
    Re: What is the max 3080 FTW3 power draw Friday, September 25, 2020 0:15 PM (permalink)
    This is probably a really stupid question, but coming from someone that has never overclocked before, what is the real benefit? A few extra frames? Or just for the sake of competition and benchmark numbers? Doesn't this wear out the components more quickly?
    IRanNaked
    Re: What is the max 3080 FTW3 power draw Friday, September 25, 2020 10:39 AM (permalink)
    Few frames with a lot more power draw. Not worth it at all
    Aurummorituri
    Re: What is the max 3080 FTW3 power draw Friday, September 25, 2020 11:54 AM (permalink)
    Poss273
    It depends on the component. 900 series? The 980Ti boosted around 1100MHz, but could overclock to 1500MHz. You could literally squeeze more than 40% more performance out of it. You were a butthead wasting performance if you did not OC. Now? Cards are clocked and boost close to their power limits out of the box. Not too much to gain. And no, it does not wear them out faster. Voltage kills cards and crazy temps. Also lots of dust. You cannot boost voltage on new cards 'cuz they don't want you frying them.
    #23
    stroker425
    Re: What is the max 3080 FTW3 power draw Friday, September 25, 2020 3:27 PM (permalink)
    Maybe gamers Nexus has a vid about this
    #24
    Zorel86
    Re: What is the max 3080 FTW3 power draw Tuesday, October 06, 2020 10:16 PM (permalink)
    EVGA 3080 FTW3 max power limit 400W. Why? As seen above, this was previously communicated to 420W.
    Asus Strix - 450W. Come on EVGA! Please have a bios update with higher power limit.
    #25
    kevinc313
    • Ribbons : 22
    Re: What is the max 3080 FTW3 power draw Wednesday, October 07, 2020 1:05 AM (permalink)
    Zorel86
    https://www.overclock.net.../page-43#post-28645178
    #26
    Axejess
    Re: What is the max 3080 FTW3 power draw Wednesday, October 07, 2020 4:42 PM (permalink)
    Zorel86
    I asked jacob on twitter he says it's 420
    #27
    kevinc313
    • Ribbons : 22
    Re: What is the max 3080 FTW3 power draw Wednesday, October 07, 2020 5:32 PM (permalink)
    Axejess
    Zorel86
    Can someone with a 3080 FTW3 ULTRA and/or 3080 FTW3 (non-ultra) please check the GPU-Z bios readout for the NOMINAL power limits?
    #28
    Zorel86
    Re: What is the max 3080 FTW3 power draw Wednesday, October 07, 2020 8:38 PM (permalink)
    EVGA RTX 3080 FTW3 ULTRA:
    post edited by Zorel86 - Wednesday, October 07, 2020 8:40 PM
    kevinc313
    • Ribbons : 22
    Re: What is the max 3080 FTW3 power draw Wednesday, October 07, 2020 8:59 PM (permalink)
    Zorel86
    DUN DUN DUN.........!
    Thanks man!!!
    #30
