Speedrookie
Re: WATERCOOLED PC DESK MOD WITH BUILT IN CAR AUDIO SYSTEM!!
2014/07/25 21:50:17
Nice work i'll be sure to take a look at this in 15 years when I can do this myself!
CPU: Intel® Core i7-6700K OC @4.6GHz GPU: EVGA GeForce GTX 1070 SC RAM: 16GB G.Skill TridentZ @ 3600MHz CAS 16 SSD: Samsung 850 Pro 240GB HDD: Seagate 2TB 7200 RPM SSHD --------------------------------------------------- Headset: Astro A40 Mouse: Logitech G502 Spectrum RGB Keyboard: Corsair K70 Cherry MX Red
imfaceroll
- Ribbons : 10
2014/07/25 22:49:16
imfaceroll
- Ribbons : 10
2014/07/25 22:52:19
So.. I managed to fill the loop yesterday and ran into some problems. I filled the loop and had it running for around 2 hours when i noticed liquid all over the motherboard. Straight away i turned the pumps off and had to take everything apart to clean the motherboard and dry it off. I drained the loop to do just that. When everything was taken out of the desk i took apart the Asus maximus VI formula motherboard to dry it out and observe where the source of the leak had occurred. This is what i found.. As you can see in the image above, the motherboard water block looks as if the coolant has leaked through the seal, so i decided instead of returning the product for a new one, i might try tighten the seal and dry out the motherboard. The picture above is of the motherboard with the back plate and thermal armor removed as well as all of the thermal blocks and the CPU. It was essential that all of the liquid was dried and removed so it was necessary to remove all of these components to prevent a short circuit when i powered the PC on. I wired up a fan to a small 12v power adapter and placed it over the CPU and RAM slots to dry out any liquid that found its way into the gaps. I also borrowed my sisters hair drier to speed up the drying process. Above is testing the components to see if they all still work after letting everything dry for 8 hours or so. I had removed the CPU water block to let the CPU slot dry so when it came to testing whether the components worked or not i had to reinstall some thermal grease on my delidded CPU and on the thermal copper plate and use the stock air cooler. The PC powered up fine and everything worked. While i had the computer on i decided to check the CPU temperatures because i had delidded the CPU and put my own thermal grease on. Previous core temperatures ranged from 34-37 degrees Celsius, the new temperatures ranged from 18-21 degrees Celsius with the stock cooler, so i was very happy with them results. The picture above is of the refill and previous leak area, so far so good. Another possible cause of the leakage around that area is where the fittings screw into the motherboard water block. I have since installed some extender fittings into the motherboard and then screwed the compression fittings into those. The reason for this is the compression fittings are a lot wider and i believe that the design of the motherboard water block was preventing them from screwing down all the way, therefore creating a leakage area. I have highlighted the problem areas below. These areas are sticking up preventing the compression fitting from screwing in all the way. As of this moment i have put everything back into the desk and i am leak testing overnight, so far the problem areas have been fixed. I will be uploading more progress very shortly.
bdary
- Ribbons : 116
2014/07/26 11:15:02
Amazing build...
Amarantha
2014/07/26 14:55:45
Holy cow! That's a really cool mod. Need mawr pics. MAWR!
makuwaido
2014/07/27 16:31:42
That is an awesome build and some mad skills.
Iceblade
2014/07/28 09:53:51
This is awesome ! Great build and great skill
Xantac
2014/07/29 18:56:25
- Rig 1: Rampage5/w 6850K g.skill 3200 cas15 16gb, High-speed PC HPTX Bench w/ GTX 980
- Rig 2: RIVE/3930k /w Koolance mobo/cpu blocks/16gb 2133 c9, EVGA 1080 Ti Sli EK Nickel Blocks & a 78MH/s Eth
- Rig 3: asus rog crosshair vii hero (wi-fi)/2600x, g.skill 3200 cas15 16gb, gt 730
- Acer Predator Monitor
- Xantac's Heatware
imfaceroll
- Ribbons : 10
2014/07/31 01:35:04
Thank you to everyone for your support. More updates coming tomorrow or the day after.
Havalynii
2014/07/31 02:33:03
Very nice! Just curious, is there anything holding your drives in place or are they just kind of sitting loose on top?
imfaceroll
- Ribbons : 10
2014/07/31 03:59:49
Thank you =)
post edited by imfaceroll - 2014/07/31 04:02:33
imfaceroll
- Ribbons : 10
2014/07/31 04:02:11
Havalynii Very nice! Just curious, is there anything holding your drives in place or are they just kind of sitting loose on top?
Na they are stuck in place =)
imfaceroll
- Ribbons : 10
2014/07/31 22:13:58
schmorblatz Cool ! But be carefull with bass volume. I bricked a disk while testing a pair of bookshelf speakers on the desk, near to an external HDD. (5 inch bass/medium)
haha yea dont worry, im in a house the bass wont be thumping like it would in a car =) that would be stupid. Thank you for the kind comment =D
imfaceroll
- Ribbons : 10
2014/07/31 22:19:33
So, progress has been made with the desk. A few days have past, i have my 24 hour leak test complete and so far no dramas. Next phase of the build is to put the three 27 inch monitors up on the monitor stand i purchased from USA. I open the monitor stand box only to find that the wrong stand had been sent out to me. Instead of a free standing stand that i ordered, i received a stand with a clamp screw to hold the monitor mount onto the desk, which is a bit of a problem... The clamp cannot open wide enough to fit the thickness of my desk due to the desk being a hollow box roughly 200mm thick. Thoughts.... I came up with a solution that only Albert Einstein himself would think of, okay that's a lie it didn't take much to come up with the idea. I had to create a wooden stand that the monitor mounting stand could clamp onto and the stand had to screw into the back section of the desk, pretty simple... Went to Bunnings warehouse and scored myself three 1m lengths of wood for free (who would have thought..). I cut each length down to 800x150mm and cut a small piece to screw on top of the three side pieces. This top piece acted as the base for which the monitor mount would clamp on to. By creating the stand it also relieves the desk of all weight and prevents any possible bowing of the wood. The stand turned out well as you can see. I covered it in some left over carbon fibre wrap and now i can attach all three of my monitors and run either a nvidia surround setup or run with the 3 seperate screens with the two gtx 780 ti GPU's in SLI mode. Also by having only the 3 sides and an open back it acts as a place to hide cables which makes everything look neater and well managed. My desk is up and running now so updates will be posted very shortly within the next few days. Again, please help me out by liking my Facebook page, subscribe to my YouTube where i will be posting regular videos of game footage and desk mods. It would really help me out, i appreciate the support Cheers. YouTube: https://www.youtube.com/user/ImfacerollPCGamingFacebook: https://www.facebook.com/Imfacerollgaming
imfaceroll
- Ribbons : 10
2014/08/03 09:23:18
nikkocortez
- Ribbons : 14
2014/08/06 04:40:03
Very nice! I'm assuming that is MDF you used in the construction? And if so did it have a finished side to it or was there a lot of finishing work you had to do?
imfaceroll
- Ribbons : 10
2014/08/06 11:59:31
nikkocortez Very nice! I'm assuming that is MDF you used in the construction? And if so did it have a finished side to it or was there a lot of finishing work you had to do?
yea I had to do some finishing work =)
imfaceroll
- Ribbons : 10
2014/08/07 00:08:52
thanks for all of the positive comments
Iceblade
2014/08/07 06:24:55
nateman_doo
- Ribbons : 56
2014/08/07 08:15:50
It is absolutely beautiful. The one thing I can't live without telling you is... put some sort of foam gasket where the glass mates with the inner lip of the table. I would hate to hear that you were gaming all night, and knock over your drink and it spills into everything (or if you have a cat that jumps on it and knocks over any drinks you may forget). It can't be more then $5.00 for that kind of piece of mind. It really is a remarkable build. I kind of want to do the same thing now.
raw2dogmeat
- Ribbons : 7
2014/08/09 16:47:49
I'm thoroughly impressed, inspired and even more than a little jealous. Congrats, man!
Cooler Master Cosmos SI7 4930K @ 4.4 GHz Asus Rampage IV Black 4 x 4 gb G.SKill - 2133 9-11-10-28-2T Corsair 1200w Sandisk Extreme II 240 gb (Windows 7, 64 bit) Velociraptor 1 tb (games) 980 Ti SLIXSPC Raystorm - XSPC Razer - EK Rampage IV Black Edition blocks
imfaceroll
- Ribbons : 10
2014/08/11 03:14:31
nateman_doo It is absolutely beautiful. The one thing I can't live without telling you is... put some sort of foam gasket where the glass mates with the inner lip of the table. I would hate to hear that you were gaming all night, and knock over your drink and it spills into everything (or if you have a cat that jumps on it and knocks over any drinks you may forget). It can't be more then $5.00 for that kind of piece of mind. It really is a remarkable build. I kind of want to do the same thing now.
Haha cheers, I dont drink or eat at this desk =)
imfaceroll
- Ribbons : 10
2014/08/11 03:22:12
nateman_doo
- Ribbons : 56
2014/08/11 10:19:10
imfaceroll
I wouldn't either... BUT... a few dollars for a bit of foam has gone a long way with my over the years. Remarkable build you have there
imfaceroll
- Ribbons : 10
2014/08/18 23:04:45
nateman_doo
imfaceroll
Thanks mate appreciate it =)
- Ribbons : 84
2014/08/19 03:47:33
imfaceroll
- Ribbons : 10
2014/08/21 19:02:13
rjohnson11 Outstanding work
Thank you very much =)
imfaceroll
- Ribbons : 10
2014/08/21 19:05:23
notfordman
- Ribbons : 28
2014/08/24 19:39:59
Wow, I love the build...looks like a lot of fun!! Checked out your utube , liked and commented. And facebook is evil! lol Very nice job, I want! Did you do the sleeving?
LCRava
- Ribbons : 8
2014/08/28 17:23:26
I N C R E D I B L E !
MY AFFILIATE CODE: X6EXZ64PSH "I don't always GAME in 4K, but when I do, I prefer 4 TITANS"
