nateman_doo
- Ribbons : 52
konohahokage
Re:P67 Full Chipset Waterblock
2011/03/03 14:52:04
Sure. Make one with either an EVGA in the copper or Classified.
nateman_doo
- Ribbons : 52
2011/03/03 15:21:08
I was thinking about the E, but wasn't sure what the radius of the "E"
2011/03/03 16:19:52
Go Nate, go...... On the Classy NF200 will be where?
nateman_doo
- Ribbons : 52
2011/03/03 16:25:04
I have been looking all day for a naked picture of the new Classy. If you can find one... HOOK ME UP! :) Even the base model would be nice. Can't find many good ones.
konohahokage
2011/03/03 16:34:03
nateman_doo
- Ribbons : 52
2011/03/03 16:56:34
Yup, thats the one, but I need a picture without the heatsinks ("naked")
konohahokage
2011/03/03 17:02:57
Hmm.. not sure if a naked shot is out. I would think only EVGA would have a naked shot.
nateman_doo
- Ribbons : 52
2011/03/03 17:16:59
well, if anyone was testing the board, they might in some sort of review. "Speculation of course"
2011/08/03 08:34:45
☄ Helpful
Thanks Nate! I was going to put a note I my post but this is better it is from you! I am all in!
EVGA X79 DARK w/ the VRM's & Chipset W/C'd by Natemandoo, i7 3930 OC 4.2 W/C'd, Gskill 16 GB 2400, 2 EVGA GTX 780 OC's in SLI W/C'd, GTX 580 W/C'd as PhysX Card, OMEGA ECARLO Sound Card, 2 240 GB OCZ Vertex 260's in RAID 0, 2 120 Intel 530's in RAID 0, 2 120 GB OCZ Solids 3 in RAID 0, 2 WD VRaptors 250's in RAID 1 as File drive, 1 WD 1 TB Back Drive Back Up Drive, LG Bluray CD/DVD DVDRW Drive, Cooler Master Silent Pro Gold 1200 PSU, Coolermaster 935 stacker case with two 915's for the two 360 RADS, Thermaltake TR2 430, For Rads and Pumps, WIN 7 64 Ultimate.
nateman_doo
- Ribbons : 52
2011/08/03 10:13:22
I need a new public affairs officer, cause the one I got (me) needs to be fired =P
As soon as I get the board, I will start the design process.
2011/08/03 11:48:43
I saw some one asking about removing the HS on the one with the EVGA logo on it and saw Matt and Jacob say that it should not be removed or it coulndt be removed. check into it...
EVGA P67 / 2600K @ 4.5ghz @ 1.3v / Corsair H80 Corsair Vengence 8gbs 8-8-8-24 @ 1.5v / EVGA 960GTX 3GB / X-FI Fatality Pro WD SSD / WD Caviar 750GB SONY 32" EX500 / Cooler Master HAF 932 Custom Case .
2011/08/03 12:16:02
I believe they were referring to the mobo being ran without the heatsink on the NF200, I am pretty sure you can remove all of the heat sinks on the motherboard, I saw a review that had them all removed, I will try to find that real quick. I am at work right now, or I would pop the other side off of my case and check it out, will do it when I get home.
Project Name: "Dragon Slayer" /Case: Cooler Master HAF-X /CPU: Intel i7-2600k @ 4.8Ghz /MoBo: EVGA P67 FTW E679 w/ ECP /CPU Cooling: Corsair H70 w/ Gentle Typhoon AP-15's /RAM: 8GB G.Skill RipJaws @1600Mhz (Red) /GPU: 2xEVGA GTX 660ti FTW Signature 2 SLI /GPU Cooling: Additional 120mm EverMax fan /Sound Card: Creative SB X-Fi Titanium /PSU: Corsair AX1200 /Optical Drive: ASUS DVD/CD R/RW; Samsung Blu Ray Drive /SSD: Intel 520 Series 120GB SSD SATA III (OS) / Intel 320-series 40GB (Data) / HDD: 1TB Samsung SpinPoint F3 7200kRPM /Monitor: Acer P236H (1920x1080)
2011/08/03 12:57:10
The heatsinks on the motherboard should all come off. Jacob didn't want them removed because.. well, why would you want to remove a heatsink. It's there to dissipate heat. If you swap all the sinks with waterblocks an give it a third party cooling it will be okay.
ESOOGYERG
2011/08/03 14:37:37
Blizzie The heatsinks on the motherboard should all come off. Jacob didn't want them removed because.. well, why would you want to remove a heatsink. It's there to dissipate heat. If you swap all the sinks with waterblocks an give it a third party cooling it will be okay. Can anyone confirm if the P67/Z68 will share the same layout? Would be awesome if they do, cause then these blocks would fit both boards.
nateman_doo
- Ribbons : 52
2011/08/03 14:50:23
Rumor has it, that it will (but I wouldn't know until I have one of each in hand). That will be win for everyone. Even if its "slightly" different, holes can be re-programmed, or extra extrusions can be added for various components such as caps & coils.
nateman_doo
- Ribbons : 52
2011/08/04 07:23:02
☄ Helpful
I need input: How many of you use SLI on this board, and what are your configurations? As in, which slots do you use for SLI? watercooled GPU's or air cooled?
2011/08/04 07:57:30
I gonna use tri-sli of GTX 275 OC (watercooled) and 2600K OC @ 4.5-5 GHz (watercooled too) in 2 loop: Res - D5 - Nova 1080 - GPUs (EK-WB) - Res and Res - DDC 18W - BlackIce GTS 240 - EK suprem HF - BI GTS 120 - BI GTS 120 - Res For tri-sli I'll use PCIe #1 3 and 5, I guess. Maybe I'll switch Nova and the 3 BlackIces
post edited by LOurs - 2011/08/04 08:10:01
LOurs's P67 first i7 2600K @ 4.4 Ghz on air 4x Caviar Green 2To Raid5 2x Evga GTX 275 Corsair AX1200W 2x Velociraptor Raid0 Antec Nine hundred two
nateman_doo
- Ribbons : 52
2011/08/04 08:59:31
It is a delicate balance with using air, and water cards. Since most waterblocks are much thinner then huge stock air coolers, I can probably fit a barb directly over the P67 chip, and your hose will come up inbetween the cards, but this setup may only accommodate Tri-SLI watercooled, not air.
2011/08/04 09:04:43
all cards are watercooled, and with card WB, not just GPU WB. I'll use one CPU WB, tree videocards WB and your mobo's WB (nothing for my velociraptor/HDD)
nayaland
2011/08/04 09:11:43
I have CPU-370 and GTX 580 3GB Hydro 2 in single loop. 1st PMP 400 pump -> 2nd PMP 400 pump -> CPU-370 -> BLACK ICE 280 -> GTX 580 -> BLACK ICE 360 -> RP-401X2 Reservoir. It would be nice if I could get the P67 FTW Full Water Block. NAYA
EVGA P67 FTW, SB 2600K 5.2GHz, CPU-370 8GB G. SKILL RIPSJAW X DDR3 1866 VERTEX 3 240GB RAID 0, WD 2TB RAID 0 CORSAIR AX1200, 360 & 280 RADIATORS GTX 580 3GB HYDRO 2 SLI, CORSAIR OBSIDIAN 800D GTX 285 dedicated PhysX
ESOOGYERG
2011/08/04 09:49:25
Using slots 2 and 5 in SLI is perfectly fine, And you'd easily be able to sneak a barb just below the first card even with an air cooler and still clear the card in slot 5.
post edited by ESOOGYERG - 2011/08/04 10:06:30
nateman_doo
- Ribbons : 52
2011/08/04 10:57:19
What is your slot population?
nateman_doo
- Ribbons : 52
2011/08/04 11:46:41
ESOOGYERG Using slots 2 and 5 in SLI is perfectly fine, And you'd easily be able to sneak a barb just below the first card even with an air cooler and still clear the card in slot 5. Thats sort of the plan, but then the Tri-SLI people can't use that third card.
2011/08/04 11:55:27
I think that best plan is: Hose over NF200 and 2 loop: one passing trough mofset etc and a small one passing over p67 chipset. This way any multi-card build can fit. Or maybe an input at right mofset and the output over NF200 after a trip over p67.
post edited by LOurs - 2011/08/04 11:57:36
nateman_doo
- Ribbons : 52
2011/08/04 12:37:15
Can anyone measure that choke point between that cap, and the bendy thing of the 1st pci-e slot? Thats what it all comes down to.
ESOOGYERG
2011/08/04 15:51:57
Oh wow, I misread your post this morning my bad.
nateman_doo
- Ribbons : 52
2011/08/04 18:04:26
2011/08/04 18:08:29
Nate, Nice work on your previous builds.
2011/08/04 18:53:00
Nate, I was looking at the lever and put my old 295 in for you camera's battery died but it needs to move about 1/8th inch.
