Hot!Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's
warcobra
2018/07/07 22:05:18 (permalink)
I just wanted to start this up to give my self some motivation to Finnish this Desk PC Sooner. This is the hardest thing I have tried doing in a long time. This will be a Overkill Water Cooling Setup. It is made Entirely of finished plywood and will be either stained or painted black. This has been a month into the building of it so far and got another couple weeks to go. So I cant wait to reveal the progress when I have more time.  Specs will be Below.
Monitor's
Main: Alienware 34" 3440x1440 UltraWide 120Hz
Server: Asus 24" 1920x1080 60Hz
Secondary: Seiki 42" 19201080 60Hz
Main PC
MotherBoard: Asus X99 Deluxe
CPU: Intel i7 5820k OC 4.5Ghz
Ram: 32Gb DDR4 Corsair Vengeance 3000mhz
Video Card: 2X Evga Titan X Hydro Copper's
PSU: Evga 1600 T2
SSD's: Samsung 850 Evo 250Gb, 500Gb
HDD's: Assortment of WD Drives
Server PC
MotherBoard: Asus Rampage Gene IV X79
CPU: Intel Xeon 2690 v2 OC 3.8Ghz
Ram: 32Gb DDR3 Corsair Vengeance 1600mhz
Video Card: Evga GTX 980Ti
PSU: Evga 850 P2
SSD's: Kingston 240Gb, Samsung Evo 850 500Gb
Cooling
Water Pumps: 3X EK Revo D5 In Series (Extra Head Pressure and Redundancy)
GPU Water Block's: 2X EK Evga Titan HydroCopper Blocks
CPU Water Block's: AlphaCool Eisbaer, Ek Supremacy EVO
Radiator's: 4X AlphaCool XT45 480mm , 1x AlphaCool ST30 480mm, 1X AlphaCool XT45 360mm
Tubing: Mayhems Crystal Clear Soft Tubing
Fluid: Mayhems XT-1 UV Blue
Fan's: 28X Corsair PWM SP120 High Performance, 2X Corsair ML120 Pro
Lighting
2X NZXT Vue+
30Ft Custom RGB led Edge Lighting
        UPDATE Final
Don't Judge to hard at the moment I am still doing finishing touches. I have to also take the glass back off and clean the inside from left over modification's that I have done. I will be posting more picture of it's special cable routing and features that I built into it later when I get more time to build a good profile of it and dig through pictures from that last 2-3 months of building. For now enjoy the no so good Iphone pictures and light reflecting off glass lol. Also Cable management inside and outside will get better. Don't worry it will be better soon. Till then tell me what you think. Thanks!
post edited by warcobra - 2018/10/28 02:46:56
:5820k @4.5ghz 22c Idle 55c Load
:Custom Water Loop
:ASUS X99 Deluxe/3.1
:Corsair Vengeance LPX 16gb DDR4 @ 3000mhz
:WD 2TB / Samsung 850 Pro 512GB
:EVGA GTX Titan X Hydro Copper SLI 1480/8000
:EVGA 1600T2
:Thermaltake core X9
:21x Corsair SP120 High Performance Fans
http://www.heatware.com/eval.php?id=102641
29 Replies Related Threads
    • Ribbons : 105
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/07/08 19:36:28 (permalink)
    Can't wait to see the pics.     =)
                My Affiliate Code: 8WEQVXMCJL
    My Heatware: https://www.heatware.com/u/117599/to
     &nbsp
    EVGA_Thomas123
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/07/09 09:24:56 (permalink)
    -drools-, definitely staying updated to this one!
    • Ribbons : 65
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/07/09 09:54:17 (permalink)
    This is going to be awesome!
    Specs: AMD 2920X Threadripper, Corsair MP510 M.2, 128GB Corsair RGB Vengeance Pro,  ASRock X399 Taichi, Corsair 1000D, EVGA RTX 2070
    warcobra
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/05 20:47:15 (permalink)
    Well I am in the final stages of getting this Desk done so that I can build into it. Sorry no pics yet. Just felt like updating. Been very busy at work and have had very little time to work on it. Most nights have been filled with working on it and have slacked a little on pictures. I should be done with it next weekend or at the latest the weekend after that. The BIG tampered glass top is coming on the 20th. Unfortunately there was an error in the custom size I had ordered. Nothing like taking order on a $500 85lb glass top that is the wrong order.....sigh. But I promise I will be done soon!!!!! Cant wait to build my systems into it!
    :Custom Water Loop
    :EVGA 1600T2
    • Ribbons : 65
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/06 12:14:12 (permalink)
    Looking forward to the pics! Really want to see that desk.
    notfordman
    • Ribbons : 23
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/06 21:32:09 (permalink)
    Sounds like a very cool project, have fun building !!
    • Ribbons : 92
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/07 08:51:52 (permalink)
    stop typing and finish the desk ...
    thanks for the update
    RTX Project EVGA X99 FTW-K-5930K, 2-EVGA2080Ti, EVGA 200P2     Rig-2 AIO Folding  X99-5930K 2-1080Ti FTW3 Hybrid, EVGA-1200P2
    Rig-3 Nibbler EVGA X99 Classy-5960X 3GPU H2O
    EVGA Forums Terms of Use
    The ultimate starter-thread for new members
    warcobra
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/26 00:38:08 (permalink)
    Ok so I just cant catch a break on running into problems. But I am very close now. I have included a sneak peak :) . Will have it done next weekend. and will have full update and pictures.
    :Custom Water Loop
    :EVGA 1600T2
    • Ribbons : 65
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/26 02:51:16 (permalink)
    That looks outstanding. Looking forward to finished pics.
    Vlada011
    • Ribbons : 10
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/26 02:57:22 (permalink)
    You use Mayhems Crystal Clear Tubing. Nice.
    People recommended to me as well. Tubes and Mayehems X1 Coolant because I wanted Red.
    Your XT-1 is newer but I decide to use X1 because positive experience of people.
    Your build will be amazing.
    You didn't tell us Compression Fitting model you plan to use.
    post edited by Vlada011 - 2018/08/26 02:59:56
    i7-5820K 4.5GHz/RVE10-EK Monoblock/Dominator Platinum 2666/ASUS GTX1080Ti Poseidon/SBZxR /Samsung 850 EVO 1TB /EVGA 1200P2/Lian Li PC-O11WXC/EK XRES D5 Revo 100 Glass/Coolstream PE360-Noctua NF-A12x25 PWM x3
    warcobra
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/27 19:16:50 (permalink)
    Yup I am using mayhems Crystal Clear Tubing and XT-1. I am also using a mix of Koolance and bitspower compression fittings with all straight, 90 degree, 45 degree, t-adapters, valves, and temp sensors. I now have quite a expensive collection of fittings.
    :Custom Water Loop
    :EVGA 1600T2
    notfordman
    • Ribbons : 23
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/08/27 19:36:11 (permalink)
    Looks like you have made a lot of progress. Fitting can definitely add up, seems you can never have enough. I'm interested in the progress and finished desk. Thanks for sharing your project with us.
    • Ribbons : 92
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/03 22:28:53 (permalink)
    looking forward to more photos as this project gets closer to the finish line
    • Ribbons : 65
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/08 01:20:44 (permalink)
    Looking forward to an update
    EVGATech_GabrielT
    EVGA Tech Support
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/13 00:42:40 (permalink)
    Same here, Cant wait to see a update.
    You can try the steps that I have outlined for the reasons I have noted
    warcobra
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/15 10:38:37 (permalink)
    Original Post Updated
    :Custom Water Loop
    :EVGA 1600T2
    • Ribbons : 92
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/15 12:07:54 (permalink)
    Very Nice
    Glass or plastic top ?
    warcobra
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/15 13:32:31 (permalink)
    tempered glass top.
    :Custom Water Loop
    :EVGA 1600T2
    warcobra
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/17 17:44:03 (permalink)
    So after I get back from my vacation ill be posting up some great picture with a real camera. This is of course my first full custom project. Hope everyone likes it. Also I am up for a bit of criticism as well just don't be to harsh haha.
    :Custom Water Loop
    :EVGA 1600T2
    • Ribbons : 92
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/17 18:36:09 (permalink)
    warcobra
    OK, I'll go easy
    Remove the blue painter tape loops from the wall & tidy-up the cable on the floor in center of desk in back
    warcobra
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/18 06:44:32 (permalink)
    haha. Yea the blue painters tape is a nightmare.
    :Custom Water Loop
    :EVGA 1600T2
    • Ribbons : 65
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/18 22:26:07 (permalink)
    Fantastic update. Looking forward to the very final pictures of the cable routing and features
    #23
    EVGATech_GabrielT
    EVGA Tech Support
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/09/19 01:49:10 (permalink)
    Yes + 1000
    #24
    CMike24539
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/10/06 00:29:25 (permalink)
    This is amazing! My only question now is how do you manage to keep it dust free! :)
    #25
    • Ribbons : 65
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/10/06 01:09:10 (permalink)
    What a fantastic update. That is a build to be proud of. Looking forward to more pics.
    #26
    warcobra
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/10/28 02:50:20 (permalink)
    Ok guys final pics are up at top. Some stuff can be better but it will always be a work in progress. Also My build is in MOD Rigs. If you guys got anything you want to ask or tell me I am all for it. Thanks
    :Custom Water Loop
    :EVGA 1600T2
    #27
    • Ribbons : 65
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/10/28 03:19:59 (permalink)
    Gave you a +1 on your mod rigs page
    #28
    Vlada011
    • Ribbons : 10
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/10/28 04:07:44 (permalink)
    Me to, +1.
    #29
    jeffro66
    • Ribbons : 8
    Re: Upcoming Over Kill Water Cooled Custom Desk PC with Dual System's 2018/10/28 08:01:31 (permalink)
    wow awesome builds man
      case;Evga DG-87,Evga Dark X299,7820X 8 core cpu,4x16 64gig gskill v,Evga clc280 aio cpu cooler,evga gtx1080 TI King Pin,Evga 1200 platinium p2 power supply,SAMSUNG 960 PRO M.2 2TB NVMe,windows10
    #30
