Turbo boost max 3.0 not kicking in with Z490 FTW & 10900K
mheavner
2020/07/20 13:32:29 (permalink)
I have a new build with a Z490 FTW (1.04 BIOS) & Intel 10900K. Running at Auto CPU settings with Intel EIST & Turboboost enabled, I'm failing to see any cores reach > 4.9GHz despite CPU temps remaining cool and running test single-threaded workloads (Cinebench single thread, hyper-pi, prime95 single threaded, etc.). Intel extreme tuning utility shows the correct multipliers for 1 or 2 core workloads, and identifies two of my cores as preferred. I'm running Windows 10 2004 and have tried both balanced and high performance power profiles.
Has anyone else had issues achieving boost speeds in single-core tests with this MB + CPU? I'm able to do a manual fixed overclock to the boost speeds, but would like to take advantage of the dynamic speeds for better thermals.
4 Replies Related Threads
    mheavner
    Re: Turbo boost max 3.0 not kicking in with Z490 FTW & 10900K 2020/07/21 09:35:12 (permalink)
    Update - I found the answer in the below thread about the same issue with a different chipset (X99). I had to change the 'CPU C-states' setting in the BIOS from Auto to Enabled. After doing so, I'm seeing turbo boost 3.0 clock speeds with certain workloads.
    Edit, it seems links cannot be posted. The thread was titled 'TurboBoost Settings' in the EVGA X299 Series & SR-3 DARK forums
    Edit by EVGATech_LeeM:  Here's the link: https://forums.evga.com/TurboBoost-Settings-m2931337.aspx
    post edited by EVGATech_LeeM - 2020/07/21 09:58:36
    EVGA_Lee
    Moderator
    • Ribbons : 14
    Re: Turbo boost max 3.0 not kicking in with Z490 FTW & 10900K 2020/07/21 09:59:24 (permalink)
    Added the link to your post.  It's just an automatic anti-spam measure for new members or members under a certain post count.  Once you get to around 11 posts, you'll be able to post links.
    • Ribbons : 122
    Re: Turbo boost max 3.0 not kicking in with Z490 FTW & 10900K 2020/07/21 13:33:00 (permalink)
    mheavner
    Thanks for sharing that information, it should help other members of the Forums
    AsimovMule
    Re: Turbo boost max 3.0 not kicking in with Z490 FTW & 10900K 2020/07/21 23:36:37 (permalink)
    Nice! Just setting this up now. Thanks for the info.
