Helpful ReplyTorq X10 double click issue
drtaylor23
2019/06/10 05:05:58 (permalink)
Just wanted to check in and see if anyone has additional solutions on constant double click problems with the X10.  Order date is Dec 2016 is that puts it to a specific problem set.  Just thought I'd see if anyone has any new thoughts before I trash it because it's gone from occasional to near 100% of clicks.
I've tried everything I could find here resetting, un/reinstall, unplug, and looked at reseating, but this is an home office use type mouse and there's no play in anything so I think taking it apart might not help the situation and left it alone since there's no outer indication that's a problem.
  • Ribbons : 122
Re: Torq X10 double click issue 2019/06/10 05:19:02 (permalink) ☄ Helpfulby drtaylor23 2019/06/10 05:40:01
3 yr Warranty
I would contact EVGA CS     https://www.evga.com/about/contactus/
Make sure its registered to your account & upload the invoice - then start a Ticket
drtaylor23
Re: Torq X10 double click issue 2019/06/10 05:41:14 (permalink)
Guess that's the best course of action.  Was just hoping for one weird trick... but it sounds like I probably exhausted those.
  • Ribbons : 122
Re: Torq X10 double click issue 2019/06/10 06:02:01 (permalink)
Sounds like it could be some sort of issue with the Micro-switch ("contact bounce") or the circuit is glitching/ interrupted & giving two outputs
Either way I'm would think replacement is the best solution
Hoggle
Re: Torq X10 double click issue 2019/06/10 09:04:02 (permalink)
Only other thing I could see is open up the top in which the weights are and make sure everything is ok inside of it. You should at that point be able to look down and see the switch itself but it might take a bit of extra light to see the switch and see if anything physically looks odd. It also could be just that the top isn't fully clicked into place.
  • Ribbons : 282
Re: Torq X10 double click issue 2019/06/10 09:07:12 (permalink)
"Order date is Dec 2016" is a little old for a Mouse, have you cleaned it up at all?
Take the Top Off and Give it a good blowing out.
Use a Q-Tip 90% Isopropyl Alcohol to clean up and then Blow it out well.
Have you set the Clicking Speed on the Left and Right Buttons in Windows?
post edited by bcavnaugh - 2019/06/10 09:10:25
MSim
  • Ribbons : 38
Re: Torq X10 double click issue 2019/06/10 15:33:14 (permalink)
Check to see if a new firmware was released for the mouse.
datgrl
Re: Torq X10 double click issue 2019/07/26 05:47:02 (permalink)
I just started having this issue in the past week,  as well.  I came here looking for insight.  I love this mouse but it's becoming increasingly frustrating to use. The most recent drivers I could find are 1.9.4 released in 2015.  I tried everything the original poster did.  I did a repair with the most recent download and so far, it has shown an improvement, but it's not 'fixed'.  A single click on a link will generate multiple things to open or display.  Or when I'm gaming, I'll click to open something like a map or the UI menu; and it flashes open/close.
post edited by datgrl - 2019/07/27 05:46:37
niopio
Re: Torq X10 double click issue 2020/09/28 12:04:49 (permalink)
Just had the same issue: random douple click, random no click, absolutly no click. I cleaned the buttons with isopropanol and now everything is fine again. Like a new mouse.
Just wanted to share, thats the latest thread i found on that issue.
EVGA SuperNOVA NEX1500 Classified
|- EVGA x79 Dark
|-- EVBot
|-- Intel E5-2697v2 (from i7-3960X)
|--- Noctua NH-D15S (from EVGA ACX CPU Cooler)
|-- Corsair Dominator GT 64GB
|-- EVGA 3090 FTW3 ULTRA GAMING (from 3x EVGA GeForce GTX 680 Classfieid with Backplate / Pro SLI Brdige)
<----------- Please vote for my RIG and tell me how to improve it!
rsabatino
Re: Torq X10 double click issue 2020/09/28 13:52:53 (permalink)
I had the same problem double-clicking with the EVGA mouse the solution is to buy a new mouse it stopped double-clicking.
Operation System   Microsoft Windows 11 Pro    Processor   AMD Ryzen 9 5950X 16-Core Processor    Memory   24.2 GB Free (31.9 GB Total)    Graphics Card   NVIDIA GeForce RTX 3070 Ti (8.0 GB)    Monitor   HP 32 Display (1920 x 1080 @ 60 Hz)    Disk Storage   5240.5 GB Free of 6542.2 GB    Audio   NVIDIA High Definition Audio    Motherboard   ASUSTeK COMPUTER INC. (ROG CROSSHAIR VIII HERO (WI-FI))    Mouse   Razer BlackWidow V3 Tenkeyless    Keyboard   Razer Viper
