AnsweredReplacement PSU power cable for EVGA SuperNOVA 650 G5 650 W 80+ Gold
strayng
2024/02/29 21:01:19 (permalink)
Where can I buy a replacement PSU power cable? Not sure of the correct name but it is the cable that goes from your PSU to the wall. My dog chewed a bit of it. It still works but it is probably not safe to run. I am not sure where I can purchase a new one.
Thanks,
  • Ribbons : 84
Re: Replacement PSU power cable for EVGA SuperNOVA 650 G5 650 W 80+ Gold 2024/02/29 23:52:06 (permalink) ☼ Best Answerby strayng 2024/03/01 21:55:38
You can find standard PSU USA power plus here as an example: https://www.amazon.com/s?k=pc+psu+power+plug&ref=nb_sb_noss  Take note of the amperage your PSU needs when choosing a cable.
If you want the original PSU cable then contact EVGA tech support
If you're in a European country Amazon sells those as well or reach out to EVGA tech support.
strayng
Re: Replacement PSU power cable for EVGA SuperNOVA 650 G5 650 W 80+ Gold 2024/03/01 21:56:58 (permalink)
You can find standard PSU USA power plus here as an example:   Take note of the amperage your PSU needs when choosing a cable.
Thank you so much. I did some research and found out the type of cable and the correct awg and what not. So, I ordered one on amazon since i dont have the right information to register the PSU on here since i bought it so long ago.
Thanks
