duggiefresh
Hello, I've been having issues all week with my RTX 3090 FTW3 Ultra card with intermittent display output issues and I guess this is breaking point. After starting a benchmark that proceeded to knocked out all my display output and cranked the fans to the max, I pressed the power button to reset the computer again and after restart, I saw the red led light up on the third PCIE port furthest from the fan + rgb header (or closest to the nvlink port). Here is what I've tried so far. - Swapped cables, didn't fix the issue
- Swapped to another port on the power supply, didn't fix the issue
- Swapped to another computer that I know is working, didn't fix the issue
This is my Mobo+CPU+PSU: - Ryzen 5800x
- x570 MSI Godlike
- EVGA 1600 T2 PSU
I've been trying to look for some sort of manual describing what these LEDs mean, but I really haven't seen anything from their manuals. I don't think they even have manuals for this series of cards specifically yet. I do have a second RTX 3090 coming in since I'm doing an SLI, so maybe that card will work in the meanwhile. This is the first time where I'm having so much issues with a computer build and any help would be appreciated at this point. Does this sound like a case RMA? Appreciate the support!
d.burnette
- Ribbons : 17
Re: RTX 3090 FTW3 Ultra Red PCIE LED ON
2020/11/26 16:14:42
Don EVGA Z390 Dark MB | i9 9900k CPU @ 5.2 GHz all cores | EVGA RTX 3090 FTW3 Ultra | 32 GB G Skill Trident Z 3200 MHz CL14 DDR4 Ram | Corsair H150i Pro Cooler | EVGA T2 Titanium 1000w Power Supply | Samsung 970 Pro 1TB m.2 Nvme | Samsung 970 Evo 1TB m.2 Nvme | Samsung 860 Evo 1TB SATA SSD | EVGA DG 87 Case |
pennyboy79
2020/11/26 16:17:41
duggiefresh Hello, I've been having issues all week with my RTX 3090 FTW3 Ultra card with intermittent display output issues and I guess this is breaking point. After starting a benchmark that proceeded to knocked out all my display output and cranked the fans to the max, I pressed the power button to reset the computer again and after restart, I saw the red led light up on the third PCIE port furthest from the fan + rgb header (or closest to the nvlink port). Here is what I've tried so far.
- Ryzen 5800x
- x570 MSI Godlike
- EVGA 1600 T2 PSU
Yes, this is pretty much what happened to my first card sadly. I had to RMA it.
ASUS Maximus XI Hero Z390 MB | i9 9900k CPU | EVGA RTX 3090 FTW3 Ultra | 64 GB G.Skill Trident Z 3200 MHz DDR4 Ram | CoolerMaster ML360R RGB Cooler | Corsair AX1200i Power Supply | Samsung 970 Evo 1TB m.2 Nvme | Samsung 970 Evo 1TB SSD | Corsair 900d Case |
duggiefresh
2020/11/26 16:31:06
Well, that sucks. How long did that RMA process take for you since the 3090 is in limited stock?
kacan22
2020/11/26 16:41:53
Can you boot into windows or you are stuck with red light?. If you can try to reflash frimware on 3090 This happend on my 2080ti ftw3 ultra in 2018. I was using 2x 2080ti ftw3 ultra on my system and i was able to boot into windows and reflash broken gpu with new frimware. It was a miracle. Card is still good and working.
post edited by kacan22 - 2020/11/26 16:44:05
IanJay
2020/11/26 18:31:51
duggiefresh Well, that sucks. How long did that RMA process take for you since the 3090 is in limited stock?
When I had to RMA my 3090 a new one was shipped out 3 days after receiving the dead one. I'm pretty sure they have stock set aside for RMAs
duggiefresh
2020/11/26 20:52:52
No, I think my card is dead for sure. None of the RGB LEDs are on and Windows can't detect the device, so I can't reflash the firmware unless there is a way to do it like in motherboards.
Baasha
- Ribbons : 5
2020/11/27 18:17:14
This is incredible - this happened to me last night and now I too have a red LED on the GPU. This is so frustrating. I hope it can be recovered - have you tried the "normal" BIOS and see if it worked then? I tried it and I still get no video signal. Looks like my card (3090 FTW3 Ultra) will have to be RMA'd as well. Ugh...
4K, 5K, and 8K gaming - ThirtyIR UberRig (C622): W-3175X @ 4.50Ghz | RTX 3090 Ti FE SLI | EVGA SR-3 Dark | Trident Z Royal 4000Mhz (96GB) | Corsair AX1600i | Asetek 690LX-PN | Intel 905P (960GB) | Sabrent NVMe (8TB) | Phanteks Enthoo Elite | Dell AW5520QF | Dell UP3017Q | Audeze LCD-X (2021) | Schiit Gungnir Multibit | Schiit Mjolnir 2 Z690 Rig (Z690): 12900KF @ 5.20Ghz | EVGA RTX 3090Ti FTW3 Ultra | ASUS MXIIIE | Arctic Liquid Freezer II 280 | Trident Z RGB 6000Mhz (32GB) | Samsung 980 Pro (1TB) | Sabrent Rocket Plus 4TB RAID-0 | EVGA 1600T2 | Corsair Carbide Air 540 | ASUS PG32UQX | Gigabyte AORUS FI32U | Sennheiser HD800 | Schiit Jotunheim 2 | Schiit Bifrost 2
Naur1
2020/11/27 18:20:33
This happened to me few days ago and currently in the RMA process. Its a bad sign if the card RGB don't even light up at all. Four day weekend to play some games and chill and here we are waiting to get a new replacement lol
duggiefresh
2020/11/27 20:32:59
Baasha This is incredible - this happened to me last night and now I too have a red LED on the GPU. This is so frustrating. I hope it can be recovered - have you tried the "normal" BIOS and see if it worked then? I tried it and I still get no video signal. Looks like my card (3090 FTW3 Ultra) will have to be RMA'd as well. Ugh...
No, I have tried both bios and it no luck. It's still getting power because there is still indicator LEDs, so something is probably preventing the GPU from booting, most likely hardware imo. I submitted a support ticket today and I hope we can debug through this when they open up tomorrow, but I don't have high hopes because I don't have the tools nor do I want to tear down the card to see what the problem is and try to fix it.
duggiefresh
2020/11/27 20:35:04
Naur1 This happened to me few days ago and currently in the RMA process. Its a bad sign if the card RGB don't even light up at all. Four day weekend to play some games and chill and here we are waiting to get a new replacement lol
Same here, I have never had so many problems before. It probably didn't help that I was building a brand new PC. I took an entire week off hoping to get some sweet gaming time, but instead, I ended up troubleshooting and pretty much wasted an entire week
schulmaster
- Ribbons : 7
2020/11/27 20:44:02
Everyone speaks so highly about EVGA, and I know their customer service is great, but remaining silent on what has to be close to a 10% RMA rate on these FTLs is customer disservice. With stock so limited, and the queue system, this can't simply be vocal-minority-forumitis. Is it better to have 1% of your customers hate your RMA process, but 99% have a useable product the first time( ahem...ASUS...cough). Where is the mea culpa from EVGA? At the very least they could say "we see concern on the forums, but we assure RMA rates are within acceptable parameters". Even if that's a platitude, silence is worse.
Case: --InWin LE S-Frame #111/500-- Board: ASUS x299 SAGE WS CPU: i9 10980XE (18C/36T) @ [4.0GHz - 4.5GHz] CPU Cooling: Noctua NHD15S RAM:64GB Vengeance PRO Quad Channel @ 3.2GHz GPU: ASUS RTX 3090 STRIX OC Edition Display:27" 2560x1440 Asus Swift 165Hz IPS GSYNC Storage: 2x 1TB Micron 1100s SSDs RAID0 (OS) 2TB Samsung 980 Pro NVMe (Steam) 4TB WD Enterprise 1TB 10000RPM Velociraptor SPU: Creative AE7 PSU: Corsair AX1600i
duggiefresh
2020/11/27 21:06:30
schulmaster Everyone speaks so highly about EVGA, and I know their customer service is great, but remaining silent on what has to be close to a 10% RMA rate on these FTLs is customer disservice. With stock so limited, and the queue system, this can't simply be vocal-minority-forumitis. Is it better to have 1% of your customers hate your RMA process, but 99% have a useable product the first time( ahem...ASUS...cough). Where is the mea culpa from EVGA? At the very least they could say "we see concern on the forums, but we assure RMA rates are within acceptable parameters". Even if that's a platitude, silence is worse.
I did feel like the quality was lower on this card for sure. Buildzoid made a video about EVGA's lackluster PCB this time for the 3080 FTW3s. For an extra $300 above MSRP, I expect it to better and at least comparable to the ROG Strix, which seems to be the best air-cooled card atm for the same price. The build quality of the card definitely felt worse compared to my old 2080ti ftw3 ultra.
stoyaan
2020/11/27 23:34:05
You're not alone. My card did the same thing today while gaming. Crashed once with 100% fans and no display. Turned back on after. After 1hr more of gaming, it crashed again, and is now completely dead. Tried new PCI slot, new cables, new power supply, ...it's dead. Guess I should have held on to my 2080Ti a bit longer. I've had the card for 2 weeks and it ran perfectly fine until today. I've been an EVGA customer for 15 years and this is the first issue I've had after 20+ products. I wonder if it's an issue with EVGA this time around or something wrong with the RTX3xxx series.
enkrypt3d
2021/01/25 12:49:48
This just happened to me!!!! omg im about to cry. waiting for support to hit me back....
AMD 5950X CPU Corsair H150i 360mm AIO EVGA 3090 FTW3 Ultra MSI X570 Prestige Creation 32GB DDR4-3600Mhz G.skill Neo Trident 4 x 2TB Samsung EVO 970 Plus in RAID0 EVGA SuperNova 1300W G2 PSU
IanJay
2021/01/25 12:51:42
I think it's about time that evga releases an official statement on this...
BTW.. My card suffered this same fate 2 months ago
enkrypt3d
2021/01/25 13:16:13
IanJay I think it's about time that evga releases an official statement on this...
how long did it take u to get a replacement ? and was it a refurb?
IanJay
2021/01/25 13:22:14
enkrypt3d
10 days from start to finish and I received a brand new card.. Not refurbished. 3 days for my card to get there 4 days for them to process the rma 3 days for the shipment to get to me (I'm in Canada)
rygaul44
2021/01/25 13:53:50
enkrypt3d
For context I'm in Florida. My card got sent on the 8th, it sat at their warehouse a full week before shipping out a new one and the replacement is supposed to be here friday. So, I'm at 21 days if it actually gets here then. That's a long time for my pc to be down. They didn't explain my options as far as cross shipping or advanced rma so it left me with having to pay the shipping which came out to 62 dollars for ground shipping and insurance. Not exactly a great experience for an almost 2 thousand dollar video card.
IanJay
2021/01/25 13:58:02
rygaul44
enkrypt3d
Damn..
enkrypt3d
2021/01/25 16:28:02
Just submitted my RMA with cross ship. We'll see how it goes. realllllly bummed out about this. luckily it happened one day before the 30 day period of having them replace it with a new one and not a refurb...
oletorius
2021/01/25 17:07:04
Wow. Not good. I suppose I need to look into the Advanced RMA for when I get mine. Hopefully you both will get this behind you soon.
z1nonly
2021/01/25 17:10:28
My first EVGA card was a 1070 with the thermal pad issue. The way EVGA handled that situation (Sending out pads on request and ensuring that warranty coverage stayed in place when we disassembled our cards to install the pads) gave me confidence to buy an EVGA 1080 Ti refurb later on, and recommend an EVGA 2070 Super Hybrid to another friend. I hope they have not changed their approach to dealing with embarrassing issues with their products.
enkrypt3d
2021/01/25 17:51:19
EVGA's support is amazing honestly... It's too bad they dont make x570 motherboards as I'd be using that too if I could. My 3090 just shipped so hopefully I'll be back up soon. My old 1070 is keeping me going for now haha I did pay for the cross ship so I'm hoping my dead gpu makes it back there intact.
rygaul44
2021/01/25 18:11:49
enkrypt3d EVGA's support is amazing honestly... It's too bad they dont make x570 motherboards as I'd be using that too if I could. My 3090 just shipped so hopefully I'll be back up soon. My old 1070 is keeping me going for now haha I did pay for the cross ship so I'm hoping my dead gpu makes it back there intact.
I'll admit its my first experience with rmaing with evga but I am honestly not too impressed sadly. The service rep didn't explain my options for rma just automatically issued a standard rma. I only learned that cross shipping was an option from reading the forums. I found out after that I was expected to pay shipping. I didn't want to delay the rma so I sent it off. I followed up and asked about shipping and specified that I already sent it off. I was told they would look into it and the next day I got a prepaid shipping label.....too late! Would have been nice to save the 62 dollars. Also was told that the rma would be processed within 3 business days. It took 6. I'm still waiting on the card to get back to me. I don't think a 3 week turnaround is acceptable. I'm really hoping I don't have to rma it again but it sounds like an awful lot of people are having to rma more than once. At least I know about cross shipping now.
enkrypt3d
2021/01/25 18:15:52
rygaul44
login to your my evga account and make sure everything is registered and you can choose what type of RMA you want. u can also do the EAR as well. I'd call CS and find out whats up
rygaul44
2021/01/25 18:20:00
It's all registered now, even the new card is auto registered. They finally shipped out my replacement on Friday, but its not supposed to be here till Friday. If it does get here, that will be 22 days since I actually started the rma process. They blamed the long processing on the rma department being backed up from the week they took off at Christmas. I'm not sure how it's that much more difficult if new product being purchased has a chance to go out same day. 3 days for processing seems like it should be more than enough time. If they are still backed up from Christmas truly then there really is a serious problem with these cards and it needs to be addressed.
post edited by rygaul44 - 2021/01/25 18:22:20
enkrypt3d
2021/01/29 14:49:25
just got my replacement cross shipped... hoping my dead one makes it back to EVGA. UPS ground is sloooooowwwwww
YanPevtsov
2021/01/30 00:07:40
Mine died in the middle of a render just now =(. Was hoping to get it done before heading of for some shut eye. It was mid edit and then screen goes black. turn the pc back on no signal and a red led on one of the pci connectors =,( Time to dust of my old card and get this done
liud21
2021/01/30 03:57:11
YanPevtsov Mine died in the middle of a render just now =(. Was hoping to get it done before heading of for some shut eye. It was mid edit and then screen goes black. turn the pc back on no signal and a red led on one of the pci connectors =,( Time to dust of my old card and get this done
Did you check your psu? Because you know? Some people here believes that's what cause your gpu to die..
