RTX 3090 FTW3 Ultra Red PCIE LED ON
YanPevtsov
Re: RTX 3090 FTW3 Ultra Red PCIE LED ON 2021/01/30 04:01:45 (permalink)
liud21
YanPevtsov
Mine died in the middle of a render just now =(. Was hoping to get it done before heading of for some shut eye.
It was mid edit and then screen goes black. turn the pc back on no signal and a red led on one of the pci connectors =,(
Time to dust of my old card and get this done
Did you check your psu? Because you know? Some people here believes that's what cause your gpu to die..
Yeah pretty sure it's the card. It's a corsair 1000w and it seems to have no problem with my other GPU that I had to put into the computer to finish the job
#31
enkrypt3d
Re: RTX 3090 FTW3 Ultra Red PCIE LED ON 2021/01/30 18:57:44 (permalink)
My 2nd 3090 just took a dump. Fans are at 100%, No RGB but card appears to be working as normal... PX1 does not detect the fans and all 3 power lights are on
AMD 5950X CPU
Corsair H150i 360mm AIO
EVGA 3090 FTW3 Ultra
MSI X570 Prestige Creation
32GB DDR4-3600Mhz G.skill Neo Trident
4 x 2TB Samsung EVO 970 Plus in RAID0
EVGA SuperNova 1300W G2 PSU
#32
Jacob2me
Re: RTX 3090 FTW3 Ultra Red PCIE LED ON 2021/03/26 16:48:57 (permalink)
My 3090 FTW3 just died aswell. One red LED and changing mobos or power cables did not fix anything.
#33
schulmaster
  • Ribbons : 7
Re: RTX 3090 FTW3 Ultra Red PCIE LED ON 2021/03/26 21:48:29 (permalink)
Jacob2me
How long have you had it?
Case: --InWin LE S-Frame #111/500--
Board: ASUS x299 SAGE WS
CPU: i9 10980XE (18C/36T) @ [4.0GHz - 4.5GHz]
CPU Cooling: Noctua NHD15S
RAM:
64GB Vengeance PRO Quad Channel @ 3.2GHz
GPU: ASUS RTX 3090 STRIX OC Edition
Display:
27" 2560x1440 Asus Swift 165Hz IPS GSYNC
Storage:
2x 1TB Micron 1100s SSDs RAID0 (OS)
2TB Samsung 980 Pro NVMe (Steam)
4TB WD Enterprise
1TB 10000RPM Velociraptor
SPU: Creative AE7
PSU: Corsair AX1600i
#34
Jacob2me
Re: RTX 3090 FTW3 Ultra Red PCIE LED ON 2021/03/26 21:49:34 (permalink)
schulmaster
Jacob2me
Got it in near the end of January.
I called EVGA and only mentioned that “one red led is on and I tried switching power cables” and the agent instantly said he’d issue an RMA. Judging by this, it sure seems this issue is common to the EVGA reps.
post edited by Jacob2me - 2021/03/26 22:07:26
#35
