Draggony
I recently made the upgrade from a GTX970 Strix card to the EVGA 3060 XC My issue is that when the fans kick on it makes a strange noise like somone just quickly flicked one of those springy door stops. It's super annoying and I hear it over videos I listen to whilst working. I actually thought it was my upstairs neighbors making noise but since realized a pattern and confirmed it makes a noise each time the cards fans spin up. Looking through the forum I noted people suggesting installing Precision X1 which I have and the problem persists. I'm using 3D editing software so my GPU is in use off and on and I hear that fan startup constantly again and again while doing anything. I'm used to my old Strix card having idle fans that would kick on while temps go up but it was dead silent. New fans are made poorly or something or is my card just broken? I could run the fans constant? or should I be worried about the cards longevity? I could too record the sound perhaps and post it here if that'd help somehow.
tabishsyed
Re: RTX 3060 XC fan noise
Thursday, July 01, 2021 5:10 AM
I have the same kind of issue. The fan makes a grinding like noise whenever it turns on.
tsbond
Thursday, July 01, 2021 5:11 AM
Check the screws under the fan make sure they are all seated?
KHL988
Thursday, July 01, 2021 5:24 AM
I am waiting for this model of graphics card. I wonder if there will be many fan problems? Or it is only a case.
wannagofast
Thursday, July 01, 2021 8:46 PM
I have had this card for a few weeks and have no such issues. Mine is cool and quiet. So I wouldn't be alarmed that it is a problem with them all. Clearly it is not. peace wanna
Sir_Sizzle77
Friday, July 02, 2021 8:25 PM
For referral at product registration: For discount at checkout: My Rewards Program Code: IR2IS16H62 Associate Code: MS709K401ICWSI5  Remember to upload an invoice after product registration.
DReckLS
Wednesday, July 07, 2021 3:45 AM
Draggony I recently made the upgrade from a GTX970 Strix card to the EVGA 3060 XC My issue is that when the fans kick on it makes a strange noise like somone just quickly flicked one of those springy door stops. It's super annoying and I hear it over videos I listen to whilst working. I actually thought it was my upstairs neighbors making noise but since realized a pattern and confirmed it makes a noise each time the cards fans spin up. Looking through the forum I noted people suggesting installing Precision X1 which I have and the problem persists. I'm using 3D editing software so my GPU is in use off and on and I hear that fan startup constantly again and again while doing anything. I'm used to my old Strix card having idle fans that would kick on while temps go up but it was dead silent. New fans are made poorly or something or is my card just broken? I could run the fans constant? or should I be worried about the cards longevity? I could too record the sound perhaps and post it here if that'd help somehow.
Same here. It's doing the exact same noise that you described
Pawcio55
Wednesday, July 07, 2021 12:12 AM
Same problem here as soon my card hits 57C. Seems like bios isn't configured correctly for fan stop feature as unlike any other cards i had before that keep fan running for 10-20 sec to cool card down the EVGA 3060 only spins for 1 sec so it will try to "cool" card shortly again. For now i using custom fan curve in PX1 that keeps fan spinning at 13% for idle temps (Lowest % that fan starts on).
post edited by Pawcio55 - Wednesday, July 07, 2021 12:21 AM
AMD Ryzen 5 3600, MSI B550-A PRO, 16GB Crucial Ballistix Sport LT 3200, EVGA GeForce RTX 3060 XC GAMING, EVGA SuperNOVA 550 G2, In Win 101
DragonStar9
Thursday, August 05, 2021 5:55 PM
Mine is doing the same thing. The fans alternate one at a time on and off at low load and one of them is making a sort of grinding, but not actual grinding, sound on start up. Seems like the sound a bad motor or inadequate power delivery to that one fan would be caused by at startup in my experience with electric motors. Either one can cause premature failure eventually if run in that way. My 3060 ti doesn't do this but the 3060 does. With Precision x1 I can set the fan to run constant but that's not how the card should act and doesn't solve the actual problem if a fan is defective and may fail prematurely. I think I'm going to contact EVGA directly.
rico_070
Monday, August 09, 2021 8:40 AM
i have the same problem i got a evga xc b3060 black edition and one of the fans wen it is at around 20/30% fan speed and than it ramps up it makes some kinda weird fart noise that only way i can discribe how it sounds i tough first it was me psu but no it the card it self i tested another card same one becaus i got 2 and me second one didnt make this noise so it something worng with the fan and it the one right behind the display port and hdmi that the one makin the weird sounds
post edited by rico_070 - Monday, August 09, 2021 8:49 AM
DragonStar9
Tuesday, August 10, 2021 7:14 AM
rico_070 i have the same problem i got a evga xc b3060 black edition and one of the fans wen it is at around 20/30% fan speed and than it ramps up it makes some kinda weird fart noise that only way i can discribe how it sounds i tough first it was me psu but no it the card it self i tested another card same one becaus i got 2 and me second one didnt make this noise so it something worng with the fan and it the one right behind the display port and hdmi that the one makin the weird sounds
Mine is the fan near the display ports too. I already RMAed it yesterday. One nice thing is EVGA seem to take warranty service seriously, which is one of the reasons I buy from them. Doesn't seem to be a widespread problem so hopefully the replacement will work good.
tmills28
Friday, August 13, 2021 10:44 AM
https: //imgur.com/a/gB1pJ1T Had the same issue. RMA'd it and the replacement still has grinding fans, but at more frequent and shorter intervals, it only seems to happen when idle. Not buying evga again.
post edited by tmills28 - Friday, August 13, 2021 10:51 AM
pepe631
Tuesday, August 17, 2021 9:35 PM
I have the same issue with my 3060 XC but in my case both of fans are doing that strange noise when they kick on. With Precision x1 I have set them to run both on 13%.
jtscott00
Saturday, August 21, 2021 1:22 AM
I just got mine Monday and it is doing the same thing. Left fan starts and stops randomly and makes a noise when it kicks on, about every 30 seconds or so. I think I'm going to RMA tomorrow.
DragonStar9
Monday, August 30, 2021 3:49 PM
UPDATE: I finally got my replacement 3060 installed. They shipped me a new one and it doesn't make the noise like the other. It might have a different fan profile because it usually seems to run or not run most of the time now, in stead of turning the fans on and off frequently every second or few seconds. If any issues arise with mine I will make another update but so far it seems the issue is resolved, at least in my case.
darklord2021a
Tuesday, August 31, 2021 11:48 PM
Thanks for the update. It's great they sent you a new one. This is why I love EVGA. They stand behind their product.
Krusher_r
Wednesday, September 01, 2021 5:12 AM
I've had my 3060 XC for almost 6 months now and no strange fan noises. Chances are mechanical problems will not work themselves out so it's a good thing you returned yours and have a good working one now. For anyone else it is possible there was a bad batch of fans at one point and considering EVGA's warranty I would just let them handle it--don't need to live with a bad/noisy fan IMO.
If you're looking for a discount on evga.com, use someone's associate code during checkout. Here's mine in case you need one quick: 4DNZU0G734GQHBW
ERICKRGG
Saturday, September 04, 2021 0:13 PM
Damn, mine is now doing this...
Sneaker
Saturday, September 04, 2021 9:50 PM
I just got the 3060 Ti XC and on the 2nd day I noticed the noise. At idle without the fans running when the card (slowly) hits ~43C it will kick on the fans every few seconds. Annoying! and bad for the fans and controller? My case fans run low at idle to keep noise down but I guess it's not enough to keep the card cool enough at idle. Now having to run Precision X1 so the fans run @ 15% at idle. Annoying!
c0unt3rfeit
Friday, September 10, 2021 3:14 PM
DragonStar9 Mine is doing the same thing. The fans alternate one at a time on and off at low load and one of them is making a sort of grinding, but not actual grinding, sound on start up. Seems like the sound a bad motor or inadequate power delivery to that one fan would be caused by at startup in my experience with electric motors. Either one can cause premature failure eventually if run in that way. My 3060 ti doesn't do this but the 3060 does. With Precision x1 I can set the fan to run constant but that's not how the card should act and doesn't solve the actual problem if a fan is defective and may fail prematurely. I think I'm going to contact EVGA directly.
This is exactly what mine is doing. How's the new card holding up? Was the RMA process easy?
BiOD0L3
Sunday, September 12, 2021 5:49 AM
That sounds like faulty fans with bad bearings (if the sound persisted at low or high fan speed). It can also be the motor itself engaging from a cold startup. If the sound IS the fan motor itself, then that's absolutely a manufacturing defect or a lack of internal lubrication. Did you get this fixed?
jsteven212
Sunday, September 12, 2021 6:32 AM
Draggony My issue is that when the fans kick on it makes a strange noise like somone just quickly flicked one of those springy door stops.
Sneaker I just got the 3060 Ti XC and on the 2nd day I noticed the noise. At idle without the fans running when the card (slowly) hits ~43C it will kick on the fans every few seconds. Annoying! and bad for the fans and controller? Annoying!
This sounds like the same issue we're having with the 3070ti and 3080ti. Tech support said it was a firmware issue with one of the motor controllers, but they havent had the time to fix it. If it is the same issue, then RMA will not solve the problem and we all just have to wait. More details can be found in these discussions here: https://forums.evga.com/3rd-fan-RPMs-fluctuate-when-fans-are-set-to-auto-firmware-bug-m3449092.aspxand https://forums.evga.com/EVGA-GeForce-RTX-3080-Ti-FTW3-Clicking-Noise-From-3rd-Fan-m3427686.aspx and many others that can be found with my recent posts
post edited by jsteven212 - Sunday, September 12, 2021 7:24 AM
Sneaker
Sunday, September 12, 2021 6:14 PM
Thanks for the info and links, Mr. Steven. Pretty broad fan issues. Sounds like the fan controller guy at EVGA needs to be fired
Kosut4
Sunday, September 12, 2021 8:12 PM
Hi. I bought a RTX 3070 ti FTW3 Ultra and i was having a clicking noise from the 3rd fan. The starts to click and making a reving sound like it was accelerating and immediately decelerating in a constant loop. Apparently this happens when this fan is allowed to vary its speed speed between 0 and 40%. I solved the problem using this curve with these settings in MSI Afterburner. Precision X1 didn't work for me. If this is your problem try these settings to see it if solves anything.
post edited by Kosut4 - Sunday, September 12, 2021 8:14 PM
Jumb0
Sunday, September 12, 2021 11:17 PM
Make sure everything is screwed in properly and check if there is something inside the graphics card.
Jumb0
Sunday, September 12, 2021 11:37 PM
If you had warranty maybe you can return it and see if it gets fixed? idk
BiOD0L3
Monday, September 13, 2021 8:19 PM
Did you ever get to the bottom of this??
bump909
Tuesday, September 14, 2021 1:10 PM
Just went online searching for why my 3060 TI XC was making the same exact noise as described and found this thread. It seems to only happens at low RPMs for me. I've noticed if I set the GPU fans to manual and ramp them all the way up to 100% and then set it back to BIOS controlled or a fan curve, the noise goes away for as long as I keep my PC on. I was tempted to look into an RMA, but as someone mentioned above, it sounds like it's a firmware issue? I can live with it for now if EVGA plans on having a fix. If anyone has any updates or anyone from EVGA could respond, that'd be awesome! Thanks!
bump909
Tuesday, September 14, 2021 1:15 PM
Also, FWIW, I only started experiencing the fan noise after I switched from an NZXT H1 case (GPU mounted vertically), to a Phanteks P200a case where the GPU is mounted in the traditional horizontal position.
Pecon
Wednesday, September 15, 2021 5:30 PM
Probably niche, but if you're having this issue and you're a linux user like me looking to sidestep this issue with manual fan control, I wrote a python script to do just that: github.com/Pecon/simplefancontrol-nvidia-linux
post edited by Pecon - Wednesday, September 15, 2021 5:31 PM
