Question regarding power to a GeForce RTX 2070 Super
Mazdek
2020/05/02 13:09:35 (permalink)
Just got a EVGA GeForce RTX 2070 Super for a new machine build.  With regard to the power connectors for the card, can I do this (see attached), or should I be using a second line from the power supply for the other six pin connector?
3 Replies Related Threads
    • Ribbons : 123
    Re: Question regarding power to a GeForce RTX 2070 Super 2020/05/02 13:12:27 (permalink)
    Best practice is separate PCIe power cables from PSU to each socket on the GPU
    - had to release your post from the filter - sorry for the delay
    Mazdek
    Re: Question regarding power to a GeForce RTX 2070 Super 2020/05/02 13:14:05 (permalink)
    OK, thanks!  :)
    Re: Question regarding power to a GeForce RTX 2070 Super 2020/05/03 10:44:20 (permalink)
    +1 to what Cool GTX said, but for your card using a single cable would be fine.
