Junior05
Hello there. Purchased at FTW3 a few days ago. Got the slave bios loaded up ok and the 127% slider is indeed available. On some of the heavier benches such as Firestrike Ultra and Superposition, for example, GPUz shows my card throttling because of power at only 110-115% pwr limit quite often. With the 127% setting shouldn't my card avoid power limiting throttling until it is well in the 120%+ power range?
Re: Question about 1080 Ti FTW3 throttling and power cap...
Sunday, May 28, 2017 0:31 PM
Junior05 With the 127% setting shouldn't my card avoid power limiting throttling until it is well in the 120%+ power range?
Yes.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Sunday, May 28, 2017 0:38 PM
What are your temps? Could you run GPU-z in the background on the sensors tab, and let it finish the benchmark, set all of the Temp monitors to Max, as well as power and voltage, then take a screen shot and post it on here or on Imgur. That may help find an issue that you aren't noticing right away.
Junior05
Sunday, May 28, 2017 1:14 AM
Hightest I've been able to get her up to is around 118% - 119% PWR before heavier throttling kicks in....
post edited by Junior05 - Sunday, May 28, 2017 1:26 AM
the_Scarlet_one
- Ribbons : 79
Sunday, May 28, 2017 1:34 AM
My best suggestion would be to email evga through a support ticket. Go to "My Products" and Submit a Ticket through there. Request the Secondary Bios file, and reflash the card and see if that helps alleviate the dynamic clocking issue at 119%
Junior05
Sunday, May 28, 2017 2:02 AM
Allright, I did just that. Alot of times this card throttles for power limit early 11X% range....
Opolis
- Ribbons : 7
Sunday, May 28, 2017 5:22 PM
Do you have priority set to temp or power limit? First I had priority set to power limit. I changed to temp as priority and was able to get a step higher overclock without bouncing off the power limit as before. Don't know if this is the fix but still something to try.
Junior05
Sunday, May 28, 2017 8:40 PM
Yeah, I just tried the priority thing. Really no difference there. Still typical power throttling in the 114-119% range. Once in a blue moon I have seen it his 120+ but rare...
Tuesday, May 30, 2017 9:47 PM
Andrew_K
Tuesday, May 30, 2017 10:05 PM
I'm actually having the same issue with a FTW3 I picked up. The card will run to 113-117% or so and also reports it's triggering the power limit and voltage limit at these points, and then it drops down to 80% or so power target shortly after for a brief second before attempting to boost back up again. This is on the 127% bios. Temps on the core hit 53*, memory 40*, power 40*.
Tuesday, May 30, 2017 10:08 PM
Andrew_K I'm actually having the same issue with a FTW3 I picked up. The card will run to 113-117% or so and also reports it's triggering the power limit and voltage limit at these points, and then it drops down to 80% or so power target shortly after for a brief second before attempting to boost back up again. This is on the 127% bios. Temps on the core hit 53*, memory 40*, power 40*.
I bet this has something to do with it.
FscuderiaX
Wednesday, May 31, 2017 1:08 AM
Sajin I bet this has something to do with it.
I bet you're right. I've noticed the same thing with my 1070 and 1080Ti. You won't always reach the power limit and usually throttling is caused by the voltage limit. I'm pretty sure raising the voltage slider helps counteract this and allows more time before hitting the voltage limit so you might see higher power %.
phil0sophy
Friday, September 07, 2018 5:12 PM
Sorry for the necro bump but I am having this exact same issue, can anyone from EVGA comment on what this might be?
- Ribbons : 135
Friday, September 07, 2018 5:35 PM
