Helpful ReplyPower problems after unplugging PC
Re: Power problems after unplugging PC 2018/07/21 18:45:05 (permalink)
Locutus494
Is this something that EVGA can repair if I RMA them my board?
Don't think so. I believe they only replace boards.
#31
Locutus494
Re: Power problems after unplugging PC 2018/07/25 19:15:16 (permalink)
Well, I was mistaken again! No chip was missing after all (thank God!) The pictures on the spec sheet and manual show that is just a blank spot that is unused. Turns out it was my power supply all along! Everything metered good on it, but a different PSU (for which I had to take it to a computer shop) worked fine. The guy there said there is some logic or detection on the 8-pin EPS connector, and that the PSU wasn't responding right. So I've got a new Corsair HX1200 on the way from Newegg to replace the no-name "TechNPS" branded bad PSU. I guess it's actually impressive that an unknown PSU lasted seven years at all. Silver lining: I guess it will be nice to upgrade to a fully modular PSU.
Fractal Design Define 7 XL, ASUS ROG Crosshair VIII Formula, AMD Ryzen 7 5800X, Crucial Ballistix MAX RGB 32GB DDR4 4000, EVGA RTX 3080 Ti FTW3 Ultra Gaming, 32" Acer Predator XB323U GX (2560x1440, 240Hz) & 30" Dell U3011 (2560x1600), 4TB Sabrent Rocket 4 Plus (OS), 1TB Samsung 860 Evo (games), 2x 2TB Western Digital Black Edition 7200 RPM 64MB Cache RAID 0 (data), Corsair HX1200 PSU, Windows 10 Pro 64-bit.
#32
Re: Power problems after unplugging PC 2018/07/25 19:21:15 (permalink)
#33
bdary
  • Ribbons : 116
Re: Power problems after unplugging PC 2018/07/26 06:43:28 (permalink)
Good to hear you got it resolved...
#34
quadlatte
  • Ribbons : 56
Re: Power problems after unplugging PC 2018/07/27 04:30:53 (permalink)
 thats why i test all possible parts before doing a rma
                                             Heatware: http://heatware.com/eval.php?id=72498
#35
