Plugging in 15 Pin SATA Power to D5 Next Watercooling Pump Kills All Power
USMC7312
2020/05/16 18:08:20 (permalink)
I was cleaning and rebuilding my PC. Priori to cleaning this same pump worked without fault. After finally getting everything all cleaned and put back together, I started to have a problem with getting my pump powered.
So when I insert the 15 pin SATA cable into the back of the D5 Next Pump, it seems to result in my PSU cutting all power.
The power light for the motherboard on/off does blink green.
Has anyone seen this behavior before and know how to fix it?
I did try a new cable but it did not help
Case: Fractal Design Define 6 XL
CPU: Intel 7800x Skylake
GPU: EVGA 2080 Super
Motherboard: EVGA X299 Dark
RAM: G.Skill Trident Z RGB 32 GB (4x8GB) DDR4 3200 (PC4 25600)
PSU: EVGA Supernova 1000 T2 80+ Titanium
Monitors: 2xSamsung UH750 28" 4K
Storage:
1. WD Black 250GB SN750 NVMe M.2 2280 3D NAND <--Windows Drive
2. WD Black 1TB SN750 NVMe M.2 2280 3D NAND
3. WD Blue 3D NAND 1TB Internal PC SSD <--Applications
Sound: EVGA Nu Pro
WIFI/Bluetooth: Intel Wireless-AC 9260 M.2
Cooling:
1. CPU Block: Watercool HEATKILLER IV PRO ACRYL HWLuxx Edition
2. Thermal Paste: Grizzly Kryonaut 12.5W/m-k
3. Radiator: Alphacool Nexxos Full Copper ST45 420mm
4. Radiator Fans: 3x140 mm Be Quiet
5. Pump: Aquacomputer D5 Next RGB
6. Reservoir: Aquacomputer Aqualis Base 450mL
7. Coolant: Mayhems x1 - UV Green Pre-Mix
8. Tubing: Primochill PrimoFlex Clear 3/8 ID x 5/8 OD - Crystal Clear
9. Software: Aquacool Suite
Keyboard: Razer Blackwidow Tournament Chroma V2
Mouse: Razer Basilisk
Anti-virus: Trend Micro Maximum Security
Windows: Windows 10 Pro 64 bit 1909:18363.592
post edited by USMC7312 - 2020/05/16 18:53:43
3 Replies Related Threads
    Re: Plugging in 15 Pin SATA Power to D5 Next Watercooling Pump Kills All Power 2020/05/16 19:43:38 (permalink)
    Did you do this again.
    USMC7312
    Re: Plugging in 15 Pin SATA Power to D5 Next Watercooling Pump Kills All Power 2020/05/17 11:13:12 (permalink)
    OMG! Don’t I feel like the arse...
    Thanks for the reminder!
    Re: Plugging in 15 Pin SATA Power to D5 Next Watercooling Pump Kills All Power 2020/05/17 11:30:05 (permalink)
    No problem.
