AnsweredNeed help for temp control issue
echo8624
2019/10/16 03:41:32 (permalink)
New graphic card bought in one week
in game or high demand software the temp will up to 80+
but only one fan will work
On precisionX1 only GPU temp can be dectatived
Do u guys know whats the issue?
Is it the hardware problem?
bob16314
  • Ribbons : 761
Re: Need help for temp control issue 2019/10/16 04:01:45 (permalink) ☼ Best Answerby echo8624 2019/10/16 06:41:05
With those bogus readings, I would uninstall Precision X1..Then restart (not shut down) your PC..Then delete the EVGA_Co.,_Ltd folder located in the C:\Users\User name\AppData\Local* folder..Then install Precision X1 again..Roll from there.
*You'll need to set the Windows folder View Options to Show hidden files, folders and drives.
echo8624
Re: Need help for temp control issue 2019/10/16 06:44:42 (permalink)
still no signal.. after reinstall, the problem is without the precision x1 and all run default, the card cant run the fan when high temp, like 84degree..
  • Ribbons : 122
Re: Need help for temp control issue 2019/10/16 06:46:17 (permalink)
How Do I Troubleshoot Precision X1 Issues
You can try to see if the fan socket is possibly partially off the header
With power Removed --> do the fans turn by hand & feel the same while turning ?
Shutdown, remove plug from the wall & hold the start button 20 -30 seconds - to discharge the capacitors, plug in & restart  (full power flush)
Is Windows 10 Fast Startup OFF, (should Be --> when upgrading drivers, firmware or hardware)
        Windows Central - How to disable Windows 10 fast startup (and why you'd want to)
         How-to Geek The Pros and Cons of Windows 10’s “Fast Startup” Mode
Also go Off line ---> Kill your security software & All other background software  - When installing X1
bob16314
  • Ribbons : 761
Re: Need help for temp control issue 2019/10/16 07:03:13 (permalink)
I recommend you Contact EVGA as I suspect the fan controller in the card is faulty and you need to RMA the card, or, return it to wherever you bought it from for a replacement/refund.
They may have an MCU Update that you can ask them about..There are some here, but I don't think any of them apply to your RTX 2080 Ti FTW3 Ultra and I don't think that's the issue anyway.
echo8624
Re: Need help for temp control issue 2019/10/17 01:44:13 (permalink)
Thanks all, Calling RMA now for fixing the issue :)
bob16314
  • Ribbons : 761
Re: Need help for temp control issue 2019/10/17 01:50:31 (permalink)
Let us know how it all works out..Good luck.
