Max safe temperature for "24/7" use for 2080 Ti?
Anudo
2019/03/25 18:00:33 (permalink)
By 24/7, I mean just normal every day gaming and not pushing extremes for benchmarks.  I saw that the max temperature for the 2080 Ti is 85 degrees Celsius, which is lower then the 1080 Ti at 95 degrees Celsius.
I ended up buying the 2080 Ti Black Edition (non-a chip) and it gets up to 80 degrees when playing graphic intensive games like Metro Exodus or Anthem (Free game bundle was great btw!). Staying around 5 degrees from max temperature makes me feel uncomfortable. I can change the fan curve but is it okay to run it like this stock?
Playing less graphic intensive games like Apex Legends, Rocket League or DOTA2 makes it run closer to 70 degrees Celsius.
edit: Added words for clarification
post edited by Anudo - 2019/03/25 18:12:41
7 Replies Related Threads
    • Ribbons : 282
    Re: Max safe temperature for "24/7" use for 2080 Ti? 2019/03/25 19:25:44 (permalink)
    Running 24 Hours a Day @ 85°C I would say No
    75°C -80°C over this it is time for a Hybrid Kit or Hydro Copper Water Block and a custom water loop.
    I like to keep mine at least below 60°C.
    "(non-a chip)" has nothing to with anything as far as how hot your card runs.
    post edited by bcavnaugh - 2019/03/25 19:33:58
    Re: Max safe temperature for "24/7" use for 2080 Ti? 2019/03/25 19:41:20 (permalink)
    89c is the max. Anyhting at/below that is fine, but of course lower temps are always better.
    steveo82
    Re: Max safe temperature for "24/7" use for 2080 Ti? 2019/11/15 07:43:25 (permalink)
    I would recommend water cooling that card or any other RTX, cuz they do put out some serious heat, if my 2070 heats my bedroom like a dang space heater, then I know the 2080 ti will be worse, TT core p90 open frame  helped so much on keeping things fresh air cooled, best case ive ever owned.
    Hoggle
    Re: Max safe temperature for "24/7" use for 2080 Ti? 2019/11/15 07:56:51 (permalink)
    Keep in mind that you will want to keep the card clean if it's running at 85C. As Sajin said you want to keep it under 89C which it is now but if dust builds up it could easily go above. It's best to spend a bit if time every couple months dusting the inside of the computer out.
    AHowes
    • Ribbons : 27
    Re: Max safe temperature for "24/7" use for 2080 Ti? 2019/11/15 08:06:53 (permalink)
    85C? I'd be freaking out if it was me. Max out the fans while gsming.. set up the fan profile in px1 to 100% the fans after 50c and see what happens.
    Asus Z390 ROG Extreme XI MB
    • Ribbons : 122
    Re: Max safe temperature for "24/7" use for 2080 Ti? 2019/11/15 08:14:45 (permalink)
    Turn up your Case Fans - Get the heat out of your case --> before that Card recycles it
    NVIDIA's Boost 4.0 will override everything to protect GPU temps ....
    Its pushing the Voltage to Max 24/7 that has been reported to possible cause issues
    Me, 24/7 working them HARD ..... beside I bought the EVGA Optional 10 yr Warranty for only $60 on my EVGA 2080 Ti (s)
    kevinc313
    • Ribbons : 22
    Re: Max safe temperature for "24/7" use for 2080 Ti? 2019/11/15 08:23:02 (permalink)
    Anudo
    Your case air flow setup is questionable or your TIM is bad.  And/or you're not using some sort of vsync / frame rate limiter.
