Helpful ReplyLow performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090
tmmy34
Re: Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090 2022/11/14 17:41:08 (permalink)
Hey guys. Update. Its game issue not hardware i think but not sure still. I almost resolved. You know what i do? Just switched ( restarted ) fast in game details to LOW and again to ULTRA,and fps gain to 10 fps +up and  usage goes up. Weird?
Anyway still i try windows 10.
post edited by tmmy34 - 2022/11/14 17:45:15
Pc:
9900K 5ghz ( llc level 5 idle 1.34-1.35v,load 1.313-323v)
2x16GB DDR4 GSKILL 3000mhz
Asus Prime Z390-A
Corsair 850RmX
Rtx 2080 Ti Aorus
#31
tmmy34
Re: Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090 2022/11/16 03:17:32 (permalink)
I compared fps in gameplay in Cyberpunk 2077 ( 1440P dlss quality,rt ultra ) with my Rtx 4090 on Ryzen 9 7950X DDR5 6000mhz. I have 12900K stock,ddr4 3600mhz.And i have the same fps . So its ok ,that cpus are comparable?
I guess SMT was fixed on ryzen
Pc:
Asus Prime Z390-A
Corsair 850RmX
Rtx 2080 Ti Aorus
#32
tmmy34
Re: Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090 2022/11/20 07:02:47 (permalink)
I used 1440,RT ULTRA,rest ultra for testing fps.
And you know? All 3-4 modes of DLSS not working.
Dlss is not working. I am gettin the same scores and fps on all 3 modes of dlss. Any ideas? my drivers is up to date. DLSS Quality,performance,ultra performance ,no fps gain in benchmark and game.
I compare benchmark scores with youtube user and he got 160fps on that settings in benchmark, when me 115fps because dlss is screwed. Any ideas?
Here someone with Rtx 4090 and hes dlss AUTO is "working" in benchmark:
https://www.youtube.com/watch?v=w870r8oRjGQ
He is getting at start 165 fps. I have 115fps.
I have 12900K its not because weaker cpu. Even someone with 10850K have working dlss and higher fps on rtx 4090. I know he have 13900K so what ? No offense ,but it should work with 12900K dlss easily. I mean between QUality,performance,ultra performance there is 0 improvement in fps. Not normal.
Pc:
Asus Prime Z390-A
Corsair 850RmX
Rtx 2080 Ti Aorus
#33
bill1024
  • Ribbons : 65
Re: Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090 2022/11/20 07:36:16 (permalink)
Is this with win10?
#34
tmmy34
Re: Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090 2022/11/20 07:39:06 (permalink)
still win 11 so install win 10 or just win 11 with 21H2? <not 22H2>
Pc:
Asus Prime Z390-A
Corsair 850RmX
Rtx 2080 Ti Aorus
#35
bill1024
  • Ribbons : 65
Re: Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090 2022/11/20 07:45:15 (permalink)
Good luck figuring it out.
#36
tmmy34
Re: Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090 2022/11/20 07:50:55 (permalink)
bill1024
So win 10 must try it . Ok
Pc:
Asus Prime Z390-A
Corsair 850RmX
Rtx 2080 Ti Aorus
#37
tmmy34
Re: Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090 2022/11/26 16:41:02 (permalink)
Without format i resolved. You know what i do?
GPU USAGE 90+_-98% and 80-100fps. In nvidiad panel i MADE from 1440P native go to DSR 2.25x + smothnes 50%, and 4k appeared . Now from there i go to DLSS AUTO and have 80-100fps everywhere with gpu usage 85-98%. All dlss modes are working now better than before.
But gsync not working with DSR. Maybe i must switch in desktop to 4k?
post edited by tmmy34 - 2022/11/26 16:43:08
Pc:
Asus Prime Z390-A
Corsair 850RmX
Rtx 2080 Ti Aorus
#38
