Lian Li Launches Modular and Small-Sized O11 AIR MINI | TechPowerUp Lian Li, announces the O11 AIR MINI, available in black and white. The new small tower case features an airflow focus design with dense mesh front, top and side panels, 3 pre-installed PWM fans, support for a wide array of fans and radiators configurations, and enough clearance for CPU tower coolers up to 170 mm tall. The O11 AIR MINI can support ATX power supplies, and thanks to its modular back panel, motherboards from Mini-ITX up to E-ATX.
With a combination of front, top, and right-side dense mesh panels, support for up to ten 120 mm fans, and filtered opening at the bottom, the O11 AIR MINI offers unrestricted ventilation. The two pre-installed 140 mm PWM fans at the front and a 120 mm PWM fan at the rear ensures a good foundation for thermal management.
Similar in size to the O11D MINI, the O11 AIR MINI can support ATX power supplies of up to 200 mm in length, enabling power-hungry systems without limitations. A modular back panel, which can be reconfigured from a 7-expansion slot setup for ATX motherboards to a 5-slot configuration for M-ATX and ITX motherboards, allows the O11 AIR MINI to install graphics cards up to 362 mm in length and high-performance CPU cooling towers up to 170 mm in height.
Depending on the back panel configurations and motherboard installed, the O11 AIR MINI features four mounting locations for 240 radiators, with three capable to support 280 radiators, support for up to ten 120 mm fans, or six 140 mm fans and four 120 mm, ensuring enough cooling for even the most demanding hardware.
Pricing & Availability
The black/white O11 AIR MINI will be available at an MSRP of 109.99 USD for the black version, and 119.99 USD for the white. In addition, a vertical GPU back panel accessory will be made available in black, white, PCIe 3.0, and PCIe 4.0 riser cable, to fully display graphics cards.
What a really great looking mini case that can even support motherboards up to E-ATX.
