daanlochs
Hey guys, Happy to have finally bought an EVGA product, the 1080 TI FTW3. (Awesome looking card.) So yesterday I installed it in my pc. After plugging in the displayport cable (hama 1,8 meters) and... nothing. The screen does not light up (Dell U3415W) so it appears that the screen does not get detected at all. I have another screen hooked to the VGA port and that works flawelessly. Afterwards I tested the HDMI port and that also works without issues. I have this problem with ALL of the displayports, so to me it would look like an issue with either the cable or the screen. After doing some research I checked the displayport setting on the screen and it has been enabled. Any help or ideas is welcome! Daan
arestavo
- Ribbons : 76
Re: Issue with displayport cable / port / screen with 1080 TI FTW3
2017/05/22 05:34:32
Try a different DP cable - preferably one that is VESA certified because ones that aren't sometimes have problems like you're experiencing.
Quad5Ny
- Ribbons : 9
2017/05/22 06:05:33
Buy a new cable and report back. There has been a bunch of people having issues with dodgy DP cables on Pascal cards.
Just make sure to get one from a reputable company (AmazonBasics for example).
ArmeniusLOD
2017/05/22 06:20:56
daanlochs
2017/05/22 06:44:54
Alright, will do. I will take a cable from work with me tonight which is certified and test to see if that will work. *Edit* Also wanted to add in that I tried to "faulty" cable on my work laptop and another Dell screen and that it does work there.
post edited by daanlochs - 2017/05/22 06:52:29
happyguy82
2017/05/22 07:21:28
sadly unlike HDMI where a single 1m cable can cost up to £1,500 those audiophile companies don't make DisplayPort cables. There aren't many very very good ones around. I got one from Lindy and am happy with it. Lindy confirmed Pin-20 is disconnected on it. Make sure this is the case with whatever DP cable you get to prevent short circuit.
ASUS Z270 Maximus IX Formula / i7-7700K 4.5ghz / EVGA 1080 Ti FTW3 GAMING / 64GB G.Skill Trident Z 3200MHz @ CL 14 / Samsung 960 Pro 512GB / Corsair AX1200i / Window 10 Pro 64-Bit 3DMark ResultsTime Spy 1.0 SLI ENABLED = 13,575 http://bit.ly/2rEWbTTFire Strike 1.1 Extreme Edition SLI ENABLED = 19,563http://bit.ly/2rqdhb6Fire Strike 1.1 Extreme Edition SLI DISABLED = 12,750http://bit.ly/2qL2IMW
Systom
2017/05/22 12:12:38
I'd check cables first and then dig into drivers afterward, and then, just trying it on something else entirely if possible. (this would be ideal to test up front though) I've never had a problem with DP before until I got a 1080ti, coming from a 1080...after I installed that card, my screen would randomly turn off and back on, I would swap ports and it would seemingly be OK for a little while and then it would happen every now and then. I've always "cheaped out" with amazon/cablematters cables, I have since bought a more expensive but reliable cable from Accell and have had ZERO problems since. 3440x1440 100hz, 6' cables is what I have always used for all cables.
CPU & GPU: AMD Ryzen 9 5900X / Nvidia RTX 3080 FE (Both EK Water Blocks)MB & PSU: ROG Crosshair VIII Formula X570 / EVGA T2 Titanium 1000wSSD & RAM: Samsung 980 Pro 1TB & Western Digital Black SN850 1TB / G.Skill Trident Z Neo C14 3600MHz 4x8GB (32GB) Case & Fans: Lian Li O11 Dynamic / x9 EK-Vardar X3MRads: Black Ice Nemesis 360GTX 360mm x 54mm / Magicool 360S G2 Ultra 360mm x 45mm
ZeroAffex
2017/05/22 12:36:32
Try a different end (sounds funny but sometimes works). If that doesn't work, most like need a new cable. I'd recommend the company "Cable Matters" which can be found on amazon and is relatively cheap, been using them for a decade now and never had issues with their cables. Sorry to hear and best of luck.
2017/05/22 13:05:57
Accell DP cable is what I use, it is Not expensive - Nibbler specs in signature Shop around for best price
2017/05/22 19:57:31
daanlochs Alright, will do. I will take a cable from work with me tonight which is certified and test to see if that will work. *Edit* Also wanted to add in that I tried to "faulty" cable on my work laptop and another Dell screen and that it does work there.
Sounds like you will need to rma the card.
daanlochs
2017/05/23 06:21:41
God I really hope not... I have had to wait for 2 months before I was able to buy it and have it delivered in Belgium... Pfff. Will do one final test today, if that fails I will RMA it. (Tested HDMI Yesterday, didn't work.) Thanks, Daan
2017/05/23 10:46:02
What test would that be? Testing the card in another pc?
ZeroAffex
2017/05/23 11:38:38
Did you try using the motherboard port? Did you get a connection?
daanlochs
2017/05/24 10:17:31
Okay, good news, after testing 3 more Displayport cables, the last one worked!!! :-) (I also installed XOC, don't know if that was related to the problem or not, but I doubt it.) Tested the HDMI cable I tried on another screen and it seems like that cable was also broken. So like people where mentioning above, don't buy cheap cables, the card is quite sensitive to that.
2017/05/24 11:31:49
