kram36
The Destroyer
- Ribbons : 72
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Re: Intel® Management Engine Critical Firmware Update (Intel-SA-00086)
2017/12/03 09:50:58
kram36
The Destroyer
- Ribbons : 72
2017/12/03 09:57:19
the_Scarlet_one
- Ribbons : 79
2017/12/03 10:01:21
It is the same tool, so intel may have updated the page. Either way, it is good they are releasing information.
529th
2017/12/03 10:16:56
How Vulnerable is an X58 system with a Westmere?
the_Scarlet_one
- Ribbons : 79
2017/12/03 10:17:46
Check with the program provided.
kram36
The Destroyer
- Ribbons : 72
2017/12/03 10:28:16
the_Scarlet_one It is the same tool, so intel may have updated the page. Either way, it is good they are releasing information.
Intel updated the detection tool to a newer version, plus the page I linked gives information on what to do about it. Which is to contact your "system or motherboard manufacturer" for the fix.
owcraftsman
- Ribbons : 60
2017/12/03 19:36:08
The tool only tells you you need an update it's up to your board mfg. to produce the bios update. I'd venture to say nearly all are affected and everyone needs to be monitoring the board mfg. for an updated bios. There may be a IME driver update to follow but it's a hardware device controlled by firmware with software agents, so firmware is required to make changes. It's always confused me why we have no control over what amounts to a mini PC within our PC. The conspiracy theorist inside me says it's a government issued kill switch but I want to believe otherwise. Anyway you look at it, it is a backdoor.
5800X3D | ROG Crosshair VIII Hero w/EK-Q-M-Full | Trident Z Neo 4x8 3600 C16 | EVGA RTX 3090 FTW3 Ultra w/EK-QV2-ABP +150 CC/+1000 MC | LG 34GP83A-B UW-QHD/2-Asus PB278Q | EVGA Supernova 1000 G2 | Corsair 1TB MP600 (OS) & 970 EVO 1TB M.2 (Games) | Custom Phanteks Enthoo Luxe | NexXxoS UT60 1080mm Nova | 2x D5 w/BP-2D5TOPPEX-BK | Win-10-pro 21H2 RIG PICS
EVGA Affiliate Code GMER9XL4N
EVGA_Lee
Moderator
- Ribbons : 14
2017/12/05 11:37:17
As an update, we plan to roll out BIOS updates for the following motherboard/laptop chipsets over the next month to address this specific issue: In no particular order: - X299
- E299 EVGA X299 Dark
- E297 EVGA X299 FTW K
- E295 EVGA X299 Micro ATX
- Z370
- E379 EVGA Z370 Classified K
- E377 EVGA Z370 FTW
- E375 EVGA Z370 Micro ATX
- Z270
- E279 EVGA Z270 Classified K
- E277 EVGA Z270 FTW K
- E272 EVGA Z270 Stinger
- Z170
- E179 EVGA Z170 Classified 4-Way
- E178 EVGA Z170 Classified K
- E177 EVGA Z170 FTW
- E172 EVGA Z170 Stinger
- Notebooks:
- SC17 980M
- SC17 1080 4KG
- SC17 1070
- SC17 1070 4KG
- SC15 1060G
Please note that by providing a BIOS update, this does not mean that you are necessarily in any imminent danger from the reported vulnerability. However, we will encourage you to update your motherboard BIOSes when these are available.
kram36
The Destroyer
- Ribbons : 72
2017/12/05 11:39:38
Nice to see EVGA addressing this.
- Ribbons : 270
2017/12/05 11:55:06
I don't have Intel Management Engine software installed on my Razer Blade laptop. As such, the detection tool says software version is unknown and therefore vulnerability status is unknown. What does that mean? In what way does the software affect the Intel Management Engine hardware? Is the hardware still vulnerable without the software?
Bobmitch
- Ribbons : 47
2017/12/05 13:57:00
EVGATech_LeeM As an update, we plan to roll out BIOS updates for the following motherboard/laptop chipsets over the next month to address this specific issue: In no particular order:
- X299
- Z370
- Z270
- Z170
- Notebooks:
- SC17 980M
- SC17 1080 4KG
- SC17 1070
- SC17 1070 4KG
- SC15 1060G
Very much appreciated...
MSI MAG X570 Tomahawk; Ryzen 9 5950X; Asus TUF RTX 4070 TI OC; Corsair H115i Pro; 32 GB Crucial Ballistix Elite DDR4-3600; Western Digital Black 4 TB SN850X NVMe; Creative SoundBlaster Z; Corsair HX 850i; Lian Li Lancool II; EVGA Z15RGB Keyboard; and Razer Viper 8K MouseHeatware: http://www.heatware.com/eval.php?id=72402 Affiliate code: 1L2RV0BNQ6 Associate Code: UD82LJP3Y1FIQPR
