Intel Management Engine Vulnerability
smackiethefrog
2017/11/22 09:17:15 (permalink)
 I have run Intel's SA-00086 detection tool on my system with a Z170 FTW running UEFI v2.01. The result shows the firmware as vulnerable. Are there any plans to issue patched ME firmware for this system?
post edited by smackiethefrog - 2017/11/22 09:25:11
11 Replies Related Threads
    nowcontrol
    Re: Intel Management Engine Vulnerability 2017/11/22 18:40:58 (permalink)
     I got the same result
    EVGA Z170 FTW / EVGA RTX 3070Ti XC3 ULTRA
    Intel Core i7-6700k / Corsair H115i RGB PLATINUM
    Corsair Dominator Platinum RGB 32 GB @ 3200MHz [C16]
    Corsair HX850i / Corsair Carbide Air 540
    WD BLACK SN750 [500GB]
    Anewbis
    Re: Intel Management Engine Vulnerability 2017/12/03 02:46:22 (permalink)
    I expect this to go unpatched for at least 4 months, like the last one.
    Reading over the warranty, one might be able request an RMA for a non-vulnerable board, aka an upgrade. It would rest on whether Intel ME or the chipset are considered third-party software/equipment. If so, they could theoretically write off any warranty as non-valid at their discretion, telling you to take it up with Intel with no hard evidence, or to claim capacitors were not made "in-house" if financially required to go so far.
    Unfortunately, almost no company wants to pay for anything that goes wrong and the only one without something substantial to offer is you. After being forced to sign various bead agreements to even use the end-products, you have nearly no rights. Capitalizing on an advantage, one would call that. Good business another might say.
    You know what? Let's get rid of consumer warranties, but keep the business ones. Imagine the mountainous profits at low-risk! We'd be free to cut costs on security, with the added bonus of pushing home user to upgrade with plausible deniability. Sure business for the whole supply chain and the consumer keeps spending. There's bound to be kickbacks from the NSA for that, too (at very least non-interference).
    • Ribbons : 135
    Re: Intel Management Engine Vulnerability 2017/12/03 22:06:59 (permalink)
    smackiethefrog
    There's a new IME driver on the support page for your motherboard that should fix this issue.  Here's the direct link
    http://cdn.evga.com/Drive...10_64_11.6.13.1212.zip
    rsabatino
    Re: Intel Management Engine Vulnerability 2017/12/05 02:33:07 (permalink)
    even with the update it says my system is vulnerable .
    Operation System   Microsoft Windows 11 Pro    Processor   AMD Ryzen 9 5950X 16-Core Processor    Memory   24.2 GB Free (31.9 GB Total)    Graphics Card   NVIDIA GeForce RTX 3070 Ti (8.0 GB)    Monitor   HP 32 Display (1920 x 1080 @ 60 Hz)    Disk Storage   5240.5 GB Free of 6542.2 GB    Audio   NVIDIA High Definition Audio    Motherboard   ASUSTeK COMPUTER INC. (ROG CROSSHAIR VIII HERO (WI-FI))    Mouse   Razer BlackWidow V3 Tenkeyless    Keyboard   Razer Viper
    • Ribbons : 135
    Re: Intel Management Engine Vulnerability 2017/12/05 10:42:10 (permalink)
    rsabatino
    Did you check and see if there is a newer IME version for your chipset? Seriously EVGA should be updating this. I've updated my X99 to the latest and it's good to go.
    You should find what you need here if you're comfortable updating yourself.
    https://www.win-raid.com/...-amp-System-Tools.html
    post edited by HeavyHemi - 2017/12/05 10:47:08
    EVGA_Lee
    Moderator
    • Ribbons : 14
    Re: Intel Management Engine Vulnerability 2017/12/05 13:02:27 (permalink)
    As an update, we plan to roll out BIOS updates for the following motherboard/laptop chipsets over the next month to address this specific issue:
    In no particular order:
    • X299
      • E299 EVGA X299 Dark
      • E297 EVGA X299 FTW K
      • E295 EVGA X299 Micro ATX
    • Z370
      • E379 EVGA Z370 Classified K
      • E377 EVGA Z370 FTW
      • E375 EVGA Z370 Micro ATX
    • Z270
      • E279 EVGA Z270 Classified K
      • E277 EVGA Z270 FTW K
      • E272 EVGA Z270 Stinger
    • Z170
      • E179 EVGA Z170 Classified 4-Way
      • E178 EVGA Z170 Classified K
      • E177 EVGA Z170 FTW
      • E172 EVGA Z170 Stinger
    • Notebooks:
      • SC17 980M
      • SC17 1080 4KG
      • SC17 1070
      • SC17 1070 4KG
      • SC15 1060G
    Please note that by providing a BIOS update, this does not mean that you are necessarily in any imminent danger from the reported vulnerability.  However, we will encourage you to update your motherboard BIOSes when these are available.
    rsabatino
    Re: Intel Management Engine Vulnerability 2017/12/05 13:51:14 (permalink)
    rsabatino
    yes. I got the update from evga.
    rsabatino
    Re: Intel Management Engine Vulnerability 2017/12/05 13:52:14 (permalink)
    EVGATech_LeeM
    • X299
    • Z370
    • Z270
    • Z170
    • Notebooks:
      • SC17 980M
      • SC17 1080 4KG
      • SC17 1070
      • SC17 1070 4KG
      • SC15 1060G
    thanks I cant wait I'm so excited.
    orcaman98
    Re: Intel Management Engine Vulnerability 2018/07/26 04:40:57 (permalink)
    Can anyone tell me if the X58 is vulnerable or if an update is planned? The tool tells me it gets an invalid response and can't determine if my system is vulnerable or not. My part number is 132-GT-E736.
    mike406
    • Ribbons : 13
    Re: Intel Management Engine Vulnerability 2018/07/26 19:40:44 (permalink)
    orcaman98
    X58 is not vulnerable.
           Associate Code: 6KIMUJ06W8WFDR5 (5-10% off your purchase)
    orcaman98
    Re: Intel Management Engine Vulnerability 2018/07/27 05:17:50 (permalink)
    Thanks!
