himmatsj
So I realize that the reason I cannot maintain a stable clock speed in benchmarks is due to the fact that the card is throttling. I always thought it was thermal throttling, but today I sat down and analysed the graphs, and I realize it is the power that is being throttled. This is because I am far away from 80C but I am already seeing heavy down clocking, from 1418MHz to 1359MHz in Firestrike. In fact, right when the benchmark loads up I have 1392, then increases to 1418, then oscillates between 1405 and 1359. The nature of this fluctuation makes it seem clearly like a power issue. So, I go to MSI AB and increase power target to 110%. Nothing. No difference at all! I further tested with Furmark, to see if I was getting extra power or not. Again, not the case. so what's the issue here? Why is increasing the power limit not stabilising the clockspeeds and why are they fluctuating? Why does it seem like no extra power is actually being delivered?
Re: Increasing Power Limit on GTX 960 SC doesn't actually increase available power?
2016/06/28 11:14:55
Increasing the power target doesn't give the card more power. Increasing the power target allows the card to draw more power if needed. If you're still throttling at 110% then you'll most likely need to mod the vbios on the card to fix the problem. Stock 110% power target watts is most likely set too low in the first place.
himmatsj
2016/06/29 09:23:30
Sajin Increasing the power target doesn't give the card more power. Increasing the power target allows the card to draw more power if needed. If you're still throttling at 110% then you'll most likely need to mod the vbios on the card to fix the problem. Stock 110% power target watts is most likely set too low in the first place.
Ok, but if the card is at 100% power, when I increase it to 110% it should draw that extra power, no? My problem is, even when I do that, I DO NOT see any improvement at all. This time, I installed GPUZ and looked at the Perfcap graph. I ran Hitman benchmark. As was my suspicion, Power is the most common perfcap. The other is Vrel, but I assume this is not an issue cause Vrel was when my clock was at max. When my clock drops unexpectedly low, it stated power as the reason. Temperature was not an issue at all.
2016/06/29 10:07:54
himmatsj Ok, but if the card is at 100% power, when I increase it to 110% it should draw that extra power, no?
Only if the card needs it. When the card is hitting power perfcap is it using all 110%?
himmatsj
2016/06/30 08:12:37
No, when it is hitting Perfcap it uses 100%. There is no difference at all when I compare the power consumption graph before/after increasing from 100% to 110%. [The power % usage actually does got to about 103% when it spikes, but this is the same before and after I increase to 110% and I am told it is normal to see slight spikes over the designated power limit value] Clocks do not increase, power usage % remains the same, temps do not see an increase etc. Then I do the reverse. I drop power to 90%. Instantly I see lower power usage %, lower clocks and lower temps. I then downloaded the BIOS of my GPU and checked it using Maxwell Bios Tweaker II. And it shows, my 100% power target as 128 watts (matches EVGA's rating) and 110% as the max at 141 watts. So the allowance is there in the cards BIOS. But why is increasing the power limit via either of MSI AB or EVGA PX not working? Can someone please hazard a guess? So long story short, is there a "hidden" setting that needs to be enabled/disabled to actually allow the GPU to draw that extra 10% of power?
post edited by himmatsj - 2016/06/30 08:19:21
EVGATech_JaesonW
EVGA Tech Support
- Ribbons : 5
2016/06/30 09:05:00
Like Saijin said, increasing the power target allows the card the possibility of drawing more power, not that it necessarily will. Generally unless you're pushing a hard overclock, you're not going to see the card draw extra power from increasing the power target, and even then it may not if the drivers and card determine it's not necessary.
himmatsj
2016/06/30 09:12:53
EVGATech_JaesonW Like Saijin said, increasing the power target allows the card the possibility of drawing more power, not that it necessarily will. Generally unless you're pushing a hard overclock, you're not going to see the card draw extra power from increasing the power target, and even then it may not if the drivers and card determine it's not necessary.
I'd say overclocking 123MHz on the core (boosting till 1541MHz) and overclocking +400MHz on the memory would be considered a "hard" overclock for the 960 SC. The thing is, I have compared the graphs before/after (via MSI AB and Nvidia Inspector) and they're hitting the power limit at the same points. The GPU doesn't use the 110%, and there is zero performance increase after increasing to 110%. Now, the moment I reduce the power target to just 98%, I can see the clock speeds decreasing. Performance decreases slightly. The GPU now uses up 98% power on the graphs. So I am 100% certain it hits the power limit in the case I mentioned above, and I am saying this, when I set it to 110% I don't believe it gets "applied" to the GPU, for whatever reason.
2016/06/30 10:10:45
Try using a older driver version such as 347.88 to see if your results change.
himmatsj
2016/07/01 05:46:47
I contacted EVGA support about this. The Taiwan office replied. He showed me two screenshots saying that "things are working". First screenshot, he sets a GTX 980 Classified to 110% power target and shows a power reading during a benchmark at 111.4%. So it's working. Then the second screenshot he shows me a GTX 960 SC (same as mine) and sets power target to 100%, and the power reading during the benchmark shows 97.4% and he says "EVGA PX functions properly" and calls it a hardware limitation. What is that supposed to mean? If there is a hard limit at 100%, why then even allow the "illusion" that we can set the power target to 110%? I even confirmed with GPU Shark, again it shows my power never exceeding 100% even when I set the limit to 110%, and it keeps showing "Power Limit Reached" under the limiting policies. Now I hope EVGA can let me know why on Earth is the GTX 960 SC hardware limited to 100% of power limit only, when the BIOS clearly shows that there is an allowance for a further 10%. EDIT: It's really not a big deal, but now that I've gone down this rabbit hole of trying to understand how a GPU works and its limiting factors, I would like to know from EVGA why/how the model of the GTX 960 I have cannot go past 100% power even when the limit is raised by 10% under a condition where the GPU is clearly power limited.
post edited by himmatsj - 2016/07/01 05:51:29
himmatsj
2016/07/03 22:40:01
Ok, to update, I got another reply from EVGA Taiwan. Hi User This GTX960 SC hardware restrictions. (Asked RD) We do not have permission to open GPU set (because this is Nvidia specifications) Very regrettable , We can do, the next version of EVGA PX Recovery GTX960 SC power target to 100% First of all I don't understand what's being said exactly. It seems to be that Nvidia asked them to lock it to 100%, even though software like EVGA PX and MSI AB and the BIOS itself allows for an additional increase of 10%?
Can somebody from EVGA Tech Support US or EU please confirm this? This then begs the question, how many other EVGA GPUs are actually locked to 100%, and the 110% or 115% increase in MSI AB/EVGA PX is merely cosmetic?
bsmegreg
- Ribbons : 6
2016/07/03 23:25:05
It would not be surprising if NVIDIA layed down the law with EVGA and said 'you will do it this way'. Most of the time they give some free reign to EVGA allowing them to do ACX cooling, factory OC's, etc.
Basically I guess EVGA was asked to make the firmware unresponsive to the power target increase on that model. I have a GTX 970 SC 2974-KR and its firmware is unresponsive to core voltage increases. (But it responds to power target)
himmatsj
2016/07/05 12:28:09
Yeah, I just want to know from the EVGA support staff on this forum, why did they have to disable increasing the power limit? And how often do they do this? Was it a one off scenario?
himmatsj
2016/07/07 05:33:20
Can somebody from EVGA Support please respond?
arestavo
- Ribbons : 76
2016/07/07 05:52:30
himmatsj
2016/07/07 06:17:37
arestavo
himmatsj Can somebody from EVGA Support please respond?
https://www.evga.com/about/contactus/ if you are wanting a EVGA tech rep to respond for sure.
Thats how I contacted them and got a reply in broken English as posted above from Taiwan office. When asking for clarifications, he replied "Sorry my English is not good".
- Ribbons : 270
2016/07/07 08:44:59
My understanding of his words are this: They cannot raise the power target beyond 100% for that card due to NVIDIA restrictions. In the next version of Precision, they will try to make Precision not allow you to increase the slider over 100% as to no longer confuse you.
himmatsj
2016/07/13 05:15:23
I would like to know, are all SC cards like this? I'm very interested in the GTX 1060 SC, but if it is going to be hard locked to 100% power I may have to look elsewhere.
Dr.Death
- Ribbons : 9
2016/07/13 14:22:31
''Can somebody from EVGA Support please respond?'' lol... you should know better by now you have not notices a trend in that at these forums ?? mind how or what they answer to and when they never to be seen or heard then 2+2 may = 4 on that statement ''Thats how I contacted them and got a reply in broken English as posted above from Taiwan office. When asking for clarifications, he replied "Sorry my English is not good".'' and is it not that evga is a U.S based company and you had to deal with that ??? go figure I guess there down to around ASUS levels now a days ??
himmatsj
2016/07/14 04:14:59
I have faith in EVGA. Their knowledgable USA support reps are on these forums. They have answered my queries helpfully before. Their Support email redirects me to Taiwan maybe because I live in Asia despite actually buying EVGA from USA Amazon.
Dr.Death
- Ribbons : 9
2016/07/14 06:27:02
- Ribbons : 270
2016/07/14 07:44:27
Dr.Death heres a example of what I mean if its trivial maybe ? like this link and plenty like it never show up ? http://forums.evga.com/What-is-the-difference-m2512646.aspx or like here they cant even give a straight answer one evga guy tells his this and then one tells him that ?? they don't even seem to have a clue on there own product ? ''Ok,an update, since the EVGA reps here are not responding to this thread, which is slightly concerning in itself,'' http://forums.evga.com/New-980-ti-hybrid-radiator-fan-constantly-on-full-speed-m2453739.aspx you must not follow much to not see the trend anyway good luck
This is a user-to-user forum and you should never expect an EVGA representative to show up in the forum and answer a question. They browse the forum when they have the time, but it isn't their primary job. If you want an answer from an EVGA representative directly, use one of the methods listed here. Did you notice that the "EVGA Forum" is not listed on the "EVGA Contact Us" page not even one single time as a method for contacting EVGA?
post edited by ty_ger07 - 2016/07/14 13:40:05
Dr.Death
- Ribbons : 9
2016/07/14 14:07:41
why are you telling me all that quoting my reply ??? I'm not the one asking for a evga rep to answer ??? lol..... I know the score lol... you need to remark to the OP not at me
post edited by Dr.Death - 2016/07/14 14:09:52
- Ribbons : 270
2016/07/14 15:38:43
Dr.Death why are you telling me all that quoting my reply ??? I'm not the one asking for a evga rep to answer ??? lol..... I know the score lol... you need to remark to the OP not at me
You were agreeing that EVGA is following a trend of not responding. I was pointing out that your examples of "not responding" are in the forum where EVGA is not expected to respond. Is it that hard to understand a point and counter point? Maybe you forgot your own argument already.
