s.redkin
After some kind of update, either Windows or BIOS, the computer's energy consumption became 120 watts instead of 80 watts. What can be wrong? Has anyone come across this? The hardware has not changed. Windows 10-64 bit, 1903 with the latest updates. The last two were deleted, but the problem remained. I did not begin to delete further. I tried on the previous BIOS, the same thing.
7820x delided-Evga x299 Dark, Noctua NH-D15, Corsair Venegance 3446 32 Gb, Intel Optane 900P 280 Gb, Saphire Radeon 5700XT, SB Creative AE-5, Seasonic Prime Platinum 650W, Phanteks Enthoo Luxe 2
DEJ915
- Ribbons : 11
Re: Idle power consumption
2019/10/13 13:46:14
Where are you measuring your power consumption? Software reading are not always correct.
Hoggle
2019/10/13 14:22:12
I also would want to know how the power is being measured since some times software and green plugs are rounded up and down to give the user a comparison they can visualize like your using the energy of two 60W lightbulbs or ten 60W equivalent LED! You might though want to check the Windows power settings and make sure something didn't get changed and everything is still set up correctly. I would just type "Troubleshoot Settings" in the Windows search bar and then click on "Power" and run the troubleshooter. It will make sure everything is set to help save energy.
s.redkin
2019/10/13 22:16:26
Power is measured by a wattmeter in the socket where the system unit is connected.
jollydet
2019/10/14 10:31:40
Check you have C-States enabled in bios and as hoggle mentioned check your powerplan settings if you have high performance enabled your idle draw will go up
s.redkin
2019/10/14 10:45:10
C-States is enabled, power plan - balanced.
2019/10/14 10:45:43
What is Most Active in Device Manager ?
s.redkin
2019/10/14 10:49:27
Nothing.
jollydet
2019/10/14 10:50:13
☄ Helpfulby s.redkin 2019/10/14 10:53:34
Something kicking your gpu out of idle state? Check gpu usage with afterburner or hwinfo64 make sure its not the culprit
post edited by jollydet - 2019/10/14 10:53:11
s.redkin
2019/10/14 10:58:51
5700XT, drivers updated. May be it. But HWInfo 31 W GPU, 28 W CPU. And what else?
2019/10/14 11:06:09
what is the idle MHz of your GPU ? scan your system for malware What is connected to your PC ?
jollydet
2019/10/14 11:06:17
s.redkin
2019/10/14 11:08:36
6MHz
jollydet
2019/10/14 11:09:44
s.redkin 6MHz
6mhz that cant be right, also your attached images for both posts are not visible.
s.redkin
2019/10/14 11:10:20
s.redkin
2019/10/14 11:11:55
jollydet
s.redkin 6MHz
I do not know why.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2019/10/14 11:37:31
You do not have enough posts currently. The forum software is blocking images from posting just in case it is spam.
s.redkin
2019/10/14 11:40:44
2019/10/14 12:02:12
Does gpu-z also show the card running at 6 mhz at idle?
s.redkin
2019/10/14 12:20:15
2019/10/14 12:27:54
☄ Helpfulby s.redkin 2019/10/14 12:36:11
2019/10/14 13:28:49
I'm thinking there is some process running in the background that is causing the issue.
s.redkin
2019/10/14 13:30:51
2019/10/14 13:33:18
☄ Helpfulby s.redkin 2019/10/14 22:20:01
2019/10/14 14:05:17
☄ Helpfulby s.redkin 2019/10/14 22:20:04
Microsoft has other things that will run in background: drive indexing & OneDrive Also Any software that starts on BOOT & has auto update ---> Do a "Clean BOOT" or even in Safe Mode ... does it still happen ?
s.redkin
2019/10/15 11:13:46
☼ Best Answerby Cool GTX 2019/10/15 11:29:09
I solved the problem: the frequency of the video card's memory was not reset to idle when the vertical frequency of the monitor was 75 Hz. At 60 Hz it worked. The new driver was to blame. Installed the recommended driver and it worked.
2019/10/15 11:15:11
☄ Helpfulby s.redkin 2019/10/15 11:19:36
2019/10/15 11:30:39
glad you found the cause - Monitor freq
s.redkin
2019/10/15 11:42:41
thanks everyone
jollydet
2019/10/15 13:17:00
