How many water blocks can a Swiftech MCP655-B pump handle?
kram36
The Destroyer
  • Ribbons : 72
2018/05/17 13:38:30 (permalink)
I have a Swiftech MCP655-B pump and I'm wondering if it can handle 1 cpu block and 4 gpu blocks running through 1 rad?
Thanks!
8 Replies Related Threads
    Re: How many water blocks can a Swiftech MCP655-B pump handle? 2018/05/17 13:50:33 (permalink)
    Would be a good question to ask swiftech tech support... help@swiftech.com
    kram36
    The Destroyer
    • Ribbons : 72
    Re: How many water blocks can a Swiftech MCP655-B pump handle? 2018/05/17 13:58:21 (permalink)
    It's a Laing D5 pump, which Swiftech has just put their name on. People have the Laing D5 pump under several different manufacture names and was hoping I could get some real world experience from members here.
    • Ribbons : 122
    Re: How many water blocks can a Swiftech MCP655-B pump handle? 2018/05/17 14:18:30 (permalink)
    Nibbler in my signature only has 3 GPU, CPU going through 2 radiators with no issues; my hoses are 1/2 inch ID.
    As long as that radiator has the btu capacity it should work fine
    Check my thread: Ready to try water cooling. Where to start? Library of links-basics to expert
    Link 4 is a good read : Choosing the Correct Water Cooling Pump
    Link 6 about pump tops, they can make a big difference in flow and pressure
    kram36
    The Destroyer
    • Ribbons : 72
    Re: How many water blocks can a Swiftech MCP655-B pump handle? 2018/05/17 15:40:38 (permalink)
    Alright, that's good info. I'm using 1/2" ID tubing.
    Not using a pump top, but my pump is mounted directly to a XSPC D5 Dual Bay Reservoir V2.
    I am thinking about using these Bitspower Aqua Link fittings in a serial setup for the video cards, so that would be 3 of them. I don't see any specs for the ID, but they look a bit smaller on the ID then 1/2" to me.
    The video card block are the EVGA 400-HC-5599-B1 blocks, 4 of them.
    The cpu block is a Swiftech Apogee HD block.
    The rad is the XSPC EX360 Crossflow Radiator V2.
    I don't see a flow or pressure issue with this combination, but I don't see a btu capacity on the rad?
    notfordman
    • Ribbons : 28
    Re: How many water blocks can a Swiftech MCP655-B pump handle? 2018/05/18 15:42:46 (permalink)
    I was hoping your res. had a flow indicator. I have run 2 cards and CPU block with 2 rads, with that pump. It's actually pretty powerful, I wouldn't hesitate to use for a multi block system. I'm using a EK res. that has the little wheel to indicate flow.
    There used to be a couple great sources Skinnylabs[ it seems to be caput] and Martins Liquid lab. CoolGTX's thread is a great resource also. There is a flow rate estimator that should give you and idea. It is a bit old. Hope it helps.
    http://martinsliquidlab.petrastech.com/MartinsFlowRateEstimator.html
    His main site also: http://martinsliquidlab.petrastech.com/
    • Ribbons : 122
    Re: How many water blocks can a Swiftech MCP655-B pump handle? 2018/05/18 16:02:08 (permalink)
    Your "pump top" is built into the reservoir housing
    Serial is more restrictive as it increases per GPU block
    If your planning on OC your Rig one 360 Rad will Not get the job done
    Rule of thumb for 35 - 45 mm thick radiator 1 section of 120mm per block plus 1 additional
    So with 5 blocks (4 GPU & 1 CPU) you should look for a bigger radiator or additional radiators
    Moving to 140mm size will increase area and cooling, if it will fit in your case
    120mm X 360mm = 43200 sq mm of area
    140mm X 420mm = 58800 sq mm of area
    Fins per inch, thickness, size and material all play into heat dissipation; along with fans and pump flow rate
    Watts to BTU per hour conversion
    1 Watt = 3.412141 BTUs per Hour
    TDP & Calculating Delta-T (scroll down the page)
    Radiator Size Estimator XSPC EX 360 Radiator Review
    Radiator Review Round Up 2016
    Review these:
    MartinsLiquidLab/index.html
    MartinsLiquidLab/XSPC-RS360-Radiator-Review.html
     Radiator Thermals and Radiator Calculators by Martin
    Water Cooling Radiator Comparison: Thickness vs Fin Density
    [Bundymania User Review] Triple Radiator (360) Roundup with 22 Rads !
     not sure the overclock.net links are working once you land on the first page (my link) the calculator link seem to send one to a generic page, not sure why
    kram36
    The Destroyer
    • Ribbons : 72
    Re: How many water blocks can a Swiftech MCP655-B pump handle? 2018/05/18 18:23:16 (permalink)
    The reservoir doesn't seem to affect the pump flow rate as the pump flows 1200 LPH whether mounted to the reservoir or not.
    I do have a Coolgate Triple 140mm Ultimate Heat Exchanger Radiator that fits in my case just fine.
    I use a Xigmatek Elysium case.
    post edited by kram36 - 2018/05/18 18:38:03
    turbomadman
    Re: How many water blocks can a Swiftech MCP655-B pump handle? 2018/05/24 19:53:06 (permalink)
    I like the D5 pumps for longevity, quite operation, and for me no leaks in 7 years or so. Here is my loop for you to compare: Two D5's in an EK dual mount with reservoir - 420 rad 60mm thick - cpu 1 - cpu 2 - full mobo water block - gpu water block 1 - gpu water block 2 - 280 rad also 60mm thick linked with 1/2" ID hose. One pump was enough but I added the second one just to make the loop flow effortlessly and for redundancy in case one pump breaks. This system was originally built for GTX 580 4 way sli.
    You should be ok with what you have. If you want to build it once then I would add another 240 rad and add the second pump if you can.  Let us know how it turned out.
