GeForce RTX 2080 TI FTW3 ULTRA HYBRID Pump replacement
mrmgaming
2023/03/18 14:37:11 (permalink)
The pump on my 2080 TI FTW3 Ultra Hybrid sounds as if it about to fail. The card performs great. Can the pump and radiator assembly be replaced? If so, any suggestions?
I do still have my previous 1080 ti Hybrid which the 2080 replaced when the HDMI out failed. The radiators look the same.  Could I replace 2080 pump and radiator with the one from the 1080? It seems like a solution but I thought I would see if anyone had knowledge.
2 Replies Related Threads
    philhalo66
    Re: GeForce RTX 2080 TI FTW3 ULTRA HYBRID Pump replacement 2023/03/19 02:07:31 (permalink)
    the block itself is just an asetek aio with a custom mounting bracket. in theory it should fit your 1080 Ti pump provided they mount the same way. i had to replace the aio on my 2080 Ti hybrid as well because the pump went bad so i got a real good look at the block.
    POWDERED DONUTS MAKE ME GO NUTS!
    • Ribbons : 122
    Re: GeForce RTX 2080 TI FTW3 ULTRA HYBRID Pump replacement 2023/03/23 08:24:14 (permalink)
    I'm thinking the 1080 ti & 2080 Ti had different mounting pattern (hole placement on PCB)
    Is your 2080 Ti under Warranty? (did you but the extended warranty)
    The Die is bigger on the 2080 Ti  --> die measures 31 mm x 25 mm, or 775 mm²
    --> 1080 ti ---> the GP102 graphics processor is a large chip with a die area of 471 mm²
    Saves 3%-10% @EVGA.com use Anyone's Associate code -->https://www.evga.com/associates
