MCorey
Hi all, Gave a friend my old GTX 970 and Samsung Odyssey WMR headset. When the headset turns on, his monitor goes black. Turns out he's got 450 watt PSU and the 970 should have a 500 watt. Does this sound like an insufficient power issue to you? Just trying to figure out the problem and narrow things down. Thanks for any feedback!
Case: Corsair Carbide Series 100R Silent Edition Quiet Mid Tower Motherboard: EVGA Z370 Classified K Video: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING, 08G-P5-37 CPU: Intel BX80684I78700K 8th Gen Core i7-8700K 6 Core 3.6 GHz Memory: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz PSU: CORSAIR CMPSU-750TX 750W Cooling: Cooler Master Hyper RR-212E-20PK-R2 LED Burner: Sony Optiarc Black 5X BD-ROM 12X Speakers: Logitech X-540 5.1 Monitor: 1) LG 27UD58-B 27-Inch 4K + 2) LG 27UD68-W 27-Inch 4K + 3) Acer SB220Q bi 21.5 OS: Windows 10/64bit Home VR: HP Reverb G2
Re: GTX 970 FTW Power Issue?
2019/09/19 11:23:52
The monitor stays black with the headset on? If he turns the headset off does his monitor come back on?
post edited by Sajin - 2019/09/19 11:29:51
MCorey
2019/09/19 12:40:13
He says when he unplugs the headset, the monitor stays blank. WMR may still be running, though...? No way to know or to shut it down with a blank monitor.
2019/09/19 13:02:33
If the fan on his gpu isn't spinning up to max speed when the screen goes black then it isn't a power issue.
2019/09/19 13:59:38
Samsung Odyssey WMR headset - how is this connected ? Has Nvidia Control Panel been setup ? Does it show up as a Second monitor ?
MCorey
2019/09/19 15:33:26
"If the fan on his gpu isn't spinning up to max speed when the screen goes black then it isn't a power issue." I'll ask and get back to you. "Samsung Odyssey WMR headset - how is this connected ? Has Nvidia Control Panel been setup ? Does it show up as a Second monitor ?" He has the monitor to the DVI port and the headset to the HDMI (required - also second connection to USB 3). I'll ask about the Nvidia control panel. He's a serious PC noob so I'm trying to keep this as simple as possible. Not sure he'll know, but let's see. Thank you both for your ongoing help. I'm trying to create another person to experience VR with! If necessary I can let him try the EVGA GTX1080 I have (it died and I sent it back, but in the mean-time I had already gotten a new 2070 so I never reinstalled the 1080). I believe that has lower power demands? Trouble is I'd have to drive quite a way to do the install and also that one still has pretty good value, so I'm hoping I can at least let him wet a toe in the VR world with the 970. I know it works for VR because I used the combo myself for quite awhile, but I have a beefier PSU (if, indeed, that's the problem).
2019/09/19 16:32:59
A 970 has lower power draw then a gtx 1080.
wmmills
- Ribbons : 40
2019/09/19 23:15:20
MCorey
2019/09/20 17:52:08
"A 970 has lower power draw then a gtx 1080." Damn. Suppose I should have checked that before I said anything. "What make and model is the psu on the PC?" EVGA (!) B3 450 W 80+Fully Modular ATX Power Supply. A mutual friend assembled the system for him but I have the list of parts. Concerning the questions about the fan and whether it shows as second monitor, I showed my friend the questions and he asked me, "so what's the answer?" LOL. I think I'm going to end up doing a house call, but I'm appreciating people continuing to take an interest. Think that PSU should be OK? He's always been on consoles so he's REALLY a PC newb and isn't used to the trouble-shooting we take for granted.
2019/09/20 18:20:04
MCorey Think that PSU should be OK?
Not really. He should be running a 500w gold unit. Instead of a 450w bronze.
MCorey
2019/09/20 18:47:35
Well dayum. I'm a pal, but I'm not sure I'm such a pal I'd want to swap out a PSU. Annoying! :)
wmmills
- Ribbons : 40
2019/09/20 20:45:48
MCorey Well dayum. I'm a pal, but I'm not sure I'm such a pal I'd want to swap out a PSU. Annoying! :)
Lol, welcome to the world of being "that PC fixer guy". Its thankless and you get all the complaints, no matter what, like customer service from hell. The best part is when you fix the pc for them, they sit down, start using it and usually say thanks and ignore you after that. Don't tell anyone where you live and be really careful who you give your cell to!
MCorey
2019/09/29 07:59:31
Haha, wmmills. Well, here's a question. Since the PSU he has is a "fully modular" model, is it possible to get a more powerful unit that is also modular, detach the cable connections, swap out the bricks, and then just plug the power connections back in? He may be able to do that himself. I've never had a modular PSU so I don't know.
bob16314
- Ribbons : 761
2019/09/29 13:21:15
MCorey Well, here's a question. Since the PSU he has is a "fully modular" model, is it possible to get a more powerful unit that is also modular, detach the cable connections, swap out the bricks, and then just plug the power connections back in? He may be able to do that himself. I've never had a modular PSU so I don't know.
Maybe, maybe not. Cables of some units of the same manufacturer are compatible with other units and others are not, resulting in the 'magic smoke' when powered on. You would need to contact the manufacturer or go to their website to find out what cables are interchangeable with what units, such as in this compatibility guide from EVGA. Pinouts on the PSU are many times different, as stated above..Component-end pinout is industry standard except for some proprietary units such as those from Dell, HP and other weirdo PCs. If ever in doubt, you can turn the unit on for bench testing and use a voltmeter on the component ends to be sure all the power and grounds (COM) are correct..See the PSU Paper Clip Test (ground the PS_ON pin 16 of the 24-pin mobo connector to turn on the PSU)..If you're fairly good you can remove pins from connectors and put them where they're supposed to go, if necessary.
MCorey
2019/09/29 13:24:10
Thank you. I would not have known that. I'm sort of a "if it fits it must be OK" kinda guy. IOW, I know enough to be dangerous I guess. Well, he has an EVGA PSU right now, can the EVGA folks here perhaps recommend a beefier supply that's compatible cord-wise with the EVGA B3 450 W 80+ Bronze Fully Modular ATX (Part# 220-B3-0450-V1)? Something with room for the future?
post edited by MCorey - 2019/09/29 13:27:05
bob16314
- Ribbons : 761
2019/09/29 13:43:20
MCorey Well, he has an EVGA PSU right now, can the EVGA folks here perhaps recommend a beefier supply that's compatible cord-wise with the EVGA B3 450 W 80+ Bronze Fully Modular ATX (Part# 220-B3-0450-V1)? Something with room for the future?
He should use the OuterVision Power Supply Calculator to see a good estimate of what wattage his PC is currently using and state what hardware upgrades, such as a graphics card, he may be thinking of in the future and go from there..Post back with the results.
